Author Topic: [GB] Gateron Switch (CLOSED)  (Read 1110905 times)
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: [GB] Gateron Switches
« Reply #300 on: Sun, 22 February 2015, 11:44:37 »
Is there any way for me to change my order? I think i'd rather swap my 100 clears and 100 reds for 200 blacks
Done
« Reply #301 on: Sun, 22 February 2015, 12:00:43 »
Okay, just changed my order to 800 blacks, seeing as they will most likely hit the 0.16 price point. :D
Offline ccc24
  • HHKB , Ergodox
« Reply #302 on: Sun, 22 February 2015, 12:27:35 »
The blacks with a comeback  :cool:...I might have to order some more
Offline hermith
« Reply #303 on: Sun, 22 February 2015, 12:28:54 »
So the price point changes at 20k? And they are on a switch quota?
Offline snipars
« Reply #304 on: Sun, 22 February 2015, 14:06:05 »
Done
thanks, sorry for the trouble
Duck Octagon + Gateron Black |HHKB Pro 2 | Poker 2 + Vintage Black + Tex case | Unicomp Ultra Classic | WASD V2 |
« Reply #305 on: Sun, 22 February 2015, 14:06:49 »
I changed my order of browns to blacks, also, not that I want many of them.
Offline ideus
  • Björkö.
« Reply #306 on: Sun, 22 February 2015, 15:13:38 »
Proposal:
Drop brown and reds, and ask people to join blues, blacks and clears instead. This may take the three colors over 20k.
Well, browns I couldn't really justify dropping. Reds on the other hand is always a possibility since those would have to end up being vendor bought anyway for around $0.30-0.35
To drop one color at least may help the other four to reach 20k easily, but I think that should be done soon.
Offline XzisT
« Reply #307 on: Sun, 22 February 2015, 15:51:48 »
Super glad I read the comments on Massdrop before committing. I even had my paypal buy button up.
Gots me 200 on blues.  ;D
Offline heedpantsnow
  • Old enough to know better
« Reply #308 on: Sun, 22 February 2015, 16:27:03 »
So why is everyone ordering clears?  They're basically unusable without a spring swap. And if you have to swap springs, why not just get Browns??
I'm back.
Offline Fnzzy
« Reply #309 on: Sun, 22 February 2015, 16:36:13 »
I like them for the aesthetics. My current setup is Clears for alphas and linears for modifiers. With Gateron clears I can use this setup and have both switch types in the same color, just have to put mx clears in the Gateron switch housing.  ;D
Offline whentheclouds
« Reply #310 on: Sun, 22 February 2015, 16:45:30 »
assuming both switches are lubed and have the same spring weight, would there be much difference between black and clear?
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #311 on: Sun, 22 February 2015, 16:57:22 »
I updated my order!
can you delete my first one? sorry for the trouble!
Offline melkenshawn
« Reply #312 on: Sun, 22 February 2015, 17:32:51 »
hold up hold up hold up. Why isn't there more interest in Browns? Isn't it essentially smoother ergo clears? Unless i'm reading the reviews wrongly.
Offline azhdar
  • Praise the AZERTY god
« Reply #313 on: Sun, 22 February 2015, 17:34:27 »
Hardly more tactile than mx browns.
Azerty Propagandiste
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #314 on: Sun, 22 February 2015, 19:04:27 »
Done
no trouble :thumb:
Yep. I'm not sure what you mean by switch quota
You certainly should ;)
this, pretty much
more people should follow this man's lead. The more switches the better!
nope, they should be essentially the same
I updated my order!
sure thing :thumb:
Very similar, yep
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #315 on: Sun, 22 February 2015, 19:26:02 »
Updated the numbers in the OP. Blacks and Clears are both getting really close to the 20k mark!
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #316 on: Sun, 22 February 2015, 19:43:33 »
Red switches have been removed. Please adjust your order accordingly
« Last Edit: Mon, 23 February 2015, 08:07:30 by hwood34 »
Offline Vintage
« Reply #317 on: Sun, 22 February 2015, 23:05:58 »
wow! Doing great  on the orders and my order is not even in yet! Sweet.
btw, the Clears are completely linear 30g switches, right?
CM QFR w/ MX Reds  | Logitech G900
Offline ideus
  • Björkö.
« Reply #318 on: Sun, 22 February 2015, 23:11:46 »
and if everyone could upvote the r/mk post to get it visible: http://www.reddit.com/r/MechanicalKeyboards/comments/2wtog3/buyinggateron_gb_red_switches_have_been_removed/
This GB is going to be an historic success. Discrete MX switches rock, and their Gatorade clones too. Prepare your irons pals.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #319 on: Sun, 22 February 2015, 23:13:06 »
35g
Offline hermith
« Reply #320 on: Sun, 22 February 2015, 23:50:44 »
Was supposed to write "on a per switch quota", as in if Clears hit 20k thef drop to 0.16, but if Browns don't they stay at 0.26?
Anyway I have changed my order, you can delete the first one I put in. :)
Offline hj-s
« Reply #321 on: Mon, 23 February 2015, 01:26:13 »
So i want to change my 30 reds to 40 blacks. Should i submit new order or just pm?
Offline azhdar
« Reply #322 on: Mon, 23 February 2015, 01:43:58 »
Both :)
Quote from: hwood34
For order changes, just submit another order and pm me to let me know.
« Last Edit: Mon, 23 February 2015, 07:05:25 by azhdar »
Offline TDub
« Reply #323 on: Mon, 23 February 2015, 02:13:01 »
Almost doubled my order to 250 blacks, browns and blues. Can you pls delete my old order? Thanks!
Offline primered6
« Reply #324 on: Mon, 23 February 2015, 04:16:49 »
Re-submitted my order..
Now with 200 Blacks and 200 Browns.
Really want these :D
GNU Terry Pratchett.
Offline SpikeBolt
  • √(4) != -2
« Reply #325 on: Mon, 23 February 2015, 04:51:04 »
Really wanted the Gateron reds :\ Now I'm unsure if I should order blacks, clears or cancel my order and get reds from massdrop...
Offline db268
« Reply #326 on: Mon, 23 February 2015, 06:36:13 »
I'm new to this GB thing and I have a doubt: I don't really understand what order in 10s mean so, if I want to order 140 switches, should I fill the form with 14 or with 140?
thank you
Offline azhdar
« Reply #327 on: Mon, 23 February 2015, 06:38:16 »
thank you
you enter 140 , easier for him to work with "decades" (is it correct english wording?) rather than deal with random numbers.
Offline db268
« Reply #328 on: Mon, 23 February 2015, 06:53:46 »
Thank you.
Is it possible to cancel my order so I can make a new one?
Offline azhdar
« Reply #329 on: Mon, 23 February 2015, 07:06:12 »
Thank you.
Both :)
Quote from: hwood34
Offline ideus
  • Björkö.
« Reply #330 on: Mon, 23 February 2015, 07:09:18 »
19 hundred clears more to reach the first 20k mark, only.
Offline azhdar
« Reply #331 on: Mon, 23 February 2015, 07:14:35 »
And we've done only 5/23 days of the opening of this group buy.
Offline ideus
  • Björkö.
« Reply #332 on: Mon, 23 February 2015, 07:17:50 »
Now the democratization of MX switches has just begun. GH members will enjoy the freedom to try as many switch types as they want, all they need is a hot iron.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #333 on: Mon, 23 February 2015, 07:48:53 »
Just a heads up, the fee has been adjusted to include freight shipping from Gateron to Shadovved which I somehow forgot about
Offline ideus
  • Björkö.
« Reply #334 on: Mon, 23 February 2015, 07:54:01 »
It is perfectly fine, thank you for the heads up.
Offline Ngt
« Reply #335 on: Mon, 23 February 2015, 08:21:34 »
I don't remember how the OP was before but are you referring to the 3.5$ handling fees?
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #336 on: Mon, 23 February 2015, 08:22:10 »
Yep, it was upped from $2 to $3.5
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #337 on: Mon, 23 February 2015, 08:22:31 »
Only 400 away from the 20k mark for clears!
Offline Permeability
« Reply #338 on: Mon, 23 February 2015, 08:22:38 »
Yep, it was $2 before, so $1.5 for freight costs
Keyboards:
'The Cheat' - lubed 62g Clears
Ducky Shine 3 TKL lubed 45g Reds (Work)
Offline Ngt
« Reply #339 on: Mon, 23 February 2015, 08:26:15 »
Alright thanks. It is perfectly fine anyway.
Offline ideus
  • Björkö.
« Reply #340 on: Mon, 23 February 2015, 08:26:33 »
I might double my order soon, the budget was there already so no reason for "savings".
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #341 on: Mon, 23 February 2015, 08:31:11 »
So even though I haven't replied to a few of the PMs I got recently, rest assured that every order has been updated
Offline VanGhost
« Reply #342 on: Mon, 23 February 2015, 08:54:11 »
Yeah, we don't need no stinking savings!
« Reply #343 on: Mon, 23 February 2015, 10:15:55 »
Just a heads up for everyone. I don't know if this affects anyone's decision on whether or not to buy these switches.
I built my JD45 prototype with Gateron blacks this weekend. Sorry, no pics yet. The Gateron blacks are very smooth, with no gritty feeling like MX switches have when new and stock. The stiffness of the springs in the blacks feels like a 67-68g Korean spring. If you like linears, but want just a touch lighter than stock MX blacks, these are a great option to use stock, with NO LUBING OR SPRING SWAPPING REQUIRED.
Also, the PCB mount pins on the underside of the switch housing DO NOT REQUIRE MODIFICATION TO USE WITH PCB MOUNT HOLES IN A PCB. They require just a bit more force to install into the holes than a standard MX switch, but once you push them in, they are VERY SECURE. If you pull the switch out and re-seat it, it feels just like a stock MX switch with regard to tightness of the PCB mount pins. There are little "micro fins" on the PCB mount pins of the Gaterons which help secure the switch even more tightly than an MX switch the first time it is installed in a PCB. Once these are compressed and pulled out, they are basically at Cherry spec, so they should be the same as new stock MX switches.
I was skeptical at first, of using a "clone" switch in place of my trusty MX switches. But I am buying these with no hesitation to use in all my future builds. If I could afford to buy 5,000 of them at once, that's how many I would buy.
BUY THESE SWITCHES.
« Reply #344 on: Mon, 23 February 2015, 10:20:47 »
BUY THESE SWITCHES.
This is good to know.
Now I need to put cherry mx clear stems in my the gateron housings I have and see how they feel.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #345 on: Mon, 23 February 2015, 10:20:58 »
BUY THESE SWITCHES.
Nice review! Added it to the OP :thumb:
Offline Fire Brand
  • Keeper of Rainbows
  • BISCUITS!
« Reply #346 on: Mon, 23 February 2015, 10:33:48 »
BUY THESE SWITCHES.
Can someone make a stick thing that says JD approved? c:
My Youtube Channel ~
Keyboards owned
My classified thread :3
Offline ideus
  • Björkö.
« Reply #347 on: Mon, 23 February 2015, 10:35:36 »
BUY THESE SWITCHES.
This sounds like sourcing "old blacks".
Offline billnye
  • ability man
« Reply #348 on: Mon, 23 February 2015, 10:35:42 »
hwood do you offer any kind of warranty on these switches?
Offline Fire Brand
  • BISCUITS!
« Reply #349 on: Mon, 23 February 2015, 10:46:48 »
.-. Bill please, no trolling now
Keyboards owned
