Author Topic: What is your preferred backlight color and why? Is white suitable?  (Read 6158 times)
Offline dankestofmemes
« on: Thu, 19 February 2015, 08:04:53 »
is white uncomfortable at night or is it fine?
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: What is your preferred backlight color and why? Is white suitable?
« Reply #1 on: Thu, 19 February 2015, 08:08:03 »
I always thought that white was a little too bright at night, but then again many bright colors are, like cyan or light green.
Offline Oobly
« Reply #2 on: Thu, 19 February 2015, 08:10:06 »
I like white and it's fine for me at night when I lower the brightness. Don't actually use it that often, though.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline exitfire401
  • The Force is Re/\l
« Reply #3 on: Thu, 19 February 2015, 08:14:13 »
Depwnds on the theme I'm going for. I have a lime/slime green on my race 2, my sprit 60% is going to have slow color changing leds, and my TX1800 is going to start off with the same leds as my race, but will change depending on what cap set i decide to have on at the time.
Offline Dark_wizzie
« Reply #4 on: Thu, 19 February 2015, 09:19:40 »
I prefer red or blue. I have red right now, looking to try out blue.  :)
Beep Boop
Offline Jotokun
« Reply #5 on: Thu, 19 February 2015, 10:26:23 »
I'm not much of a backlight person, but I don't mind if a keyboard has lighting as long as it's not blue. Those things are way too bright regardless of the set brightness, and I already have to cover up all the other blue LEDs manufactures are shoving into stuff for power/status indication as is.
On the opposite end, amber and red are really nice and subtle. Not retina burning at all. And with white, you can use plastic covers to change them so they're quite flexible. If a board I found an interest in just happened to be backlit, those would be my color choices, in that order.
« Last Edit: Thu, 19 February 2015, 10:28:25 by Jotokun »
85 IBM Model F "120" ANSI-Modded | 86 IBM Model M | Cherry G84-4100 | TG3 Data911 (MX Blacks) | 90 Apple Extended II (Linear modded Cream ALPS) | 95 Apple Extended II (Dampened White ALPS)
Offline Tempest790
« Reply #6 on: Thu, 19 February 2015, 10:55:26 »
Red or blue.  I really like the blue used on my Ducky Shine II with white keycaps.  It's almost a blue/ultra-violet color.  Very nice.  Red has less glare and is easy on the eyes in a dark room.
Offline plegnic
  • Treble Booty. Bass Guitar.
« Reply #7 on: Thu, 19 February 2015, 11:01:47 »
Red/Orange is probably my favorite, especially at night. White is just fine though as long as you can adjust the brightness. If the white bothers you, you can always get some of those colored LED covers which change the color and reduce the brightness a lot.
Planck MIT layout [MX Clears] (in-progress) | QuickFire Storm TK [MX Brown] | Poker II [MX Blue]
Offline Dark_wizzie
« Reply #8 on: Thu, 19 February 2015, 12:57:25 »
Unfortunately the covers won't work with the Vortex keycaps I plan to get.  :(
Beep Boop
Offline Sygaldry
  • Edema Ruh
« Reply #9 on: Thu, 19 February 2015, 13:08:22 »
Cyan or Ice Blue for me. Sky Blue is okay too.
null
« Reply #10 on: Thu, 19 February 2015, 13:26:26 »
I think green is a bit too harsh. But for the most part I love any backlight that matches the board. Any color can be fine as long as the brightness is right.
Offline Eiji
  • Saa eins zwei drei.
« Reply #11 on: Thu, 19 February 2015, 13:33:12 »
I've only used white backlight, and even then I usually had it on a fairly dim level. I wonder if there's any teal-ish colored LEDs out there though.
Offline Lu_e
« Reply #12 on: Thu, 19 February 2015, 14:41:35 »
Note: I don't have LED's but if I did;
Red, because my eyes are sensitive aaaand:
"Red is the illumination color of choice because it is the lowest wavelength light and as a result has the smallest impact on nightvision (regular nightvision, the kind without goggles or fancy equipment).  This is the same reason that hunting flashlights are red, as well as many lighting and illumination devices designed to operate at night."
http://www.quora.com/Why-are-submarine-operating-rooms-kept-dark
Just say NO to ABS keycaps
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #13 on: Thu, 19 February 2015, 15:40:14 »
Red because I'm always angry patriotic.
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #14 on: Thu, 19 February 2015, 16:10:19 »
I like Pink and Cyan/Sky blue as long as they aren't too bright as I like it when LEDs create the underglow effect on caps.
Offline Booper
    • omniclectic.com
« Reply #15 on: Thu, 19 February 2015, 16:24:14 »
No love for purple in here?! I wanted purple, but I went with white and got some color covers so I can keep my options open.
The led covers didn't fit well initially, but I sanded them down and they are fine now.
White is the most practical choice IMO since a color would limit my options when it comes to matching new keysets.
boop!
Offline wyatt8740
  • Machine code enthusiast
« Reply #16 on: Thu, 19 February 2015, 17:24:11 »
On my white backlit keyboard, a Logitech K800 (no, I did not spend that much, I obtained it from a co-worker), I can adjust the brightness. Most keyboards you can add a potentiometer (variable resistor) to let you dim the light if you find it overwhelming.
On a black keyboard, I like white backlight.
If I were to get a white keyboard that I could backlight, I'd really like to see it with a deep shade of violet light.
I don't usually collect things, but when I do, they're from the 70's, 80's, and 90's. My typing speed: 79 WPM
IBM Model M 1386303, 1987 / IBM Model M 1391401, 1993 / IBM Model M 59G7980, 1993 / Unicomp "Mini M" UT40E7A (modded), 2021 / Dell AT101W, 1994 (Black Alps) / Apple Extended Keyboard (Orange Alps), 1987 / Sun Type 5, unknown year (Rubber Dome)
Offline daerid
    • Rossipedia
« Reply #17 on: Thu, 19 February 2015, 18:41:04 »
See sig
Offline Oobly
« Reply #18 on: Fri, 20 February 2015, 02:32:39 »
Red is the least irritating for me, blue the most.
I find blue light to be very piercing and harsh, whereas red is soft and easy on the eyes.
White works well with any keycaps / board colours and isn't as harsh as you might think.
Offline Ludovician
« Reply #19 on: Fri, 20 February 2015, 02:41:32 »
The best backlighting is nonexistent backlighting.
Typing speed:
My collection:
HHKB Pro 2 (Blank, white) | HHKB Pro 2 Type-S (Blank, white) | Topre Realforce 87UB silent-modded (not currently functional) | Das Keyboard Model S Professional Silent (MX Brown) | IBM Model M 1391401 - 9th January 1991 (Bolt+Floss-modded) | Apple keyboard m0116 (Orange Alps) | Unidentified DIN Keyboard (White Alps) | ADDS 1010 (Green Alps) | AEK II (Linear-modded, USB-converted) | IBM PC-AT Model F | Noppoo Choc Mini (MX Black) | Amstrad PC2286 | BigKeys LX | IBM Model M 1391401 - 6th September 1990 | IBM Model M2 1395300 - 28th February 1991 | Leopold FC660C | Cherry G80-11802 (MX Brown) | Matias Tactile Pro (Simplfied grey Alps) | Razer Blackwidow (MX Blue) | Novatouch 55g | Focus FK-2001 (White alps) | DSE Multitech (Blue alps) | Dell AT101W (Matias quiet) | Pok3r (White w/Clears) | KBP V80 (Blue Alps)
Pending:
Infinity kit
Offline pesky brat
« Reply #20 on: Fri, 20 February 2015, 14:57:50 »
Yep, backlighting is just unnecessary in most scenarios. Turn your damn lights on you cave dwellers!
Offline radish
« Reply #21 on: Fri, 20 February 2015, 15:48:20 »
i would think white + tinting stickers for various colors....
white can change to be any other color... no other color can do that.
LZ CP
Offline Defect
« Reply #22 on: Fri, 20 February 2015, 16:33:53 »
Red if you actually leave it on while typing (why?).  Low energy, least likely to **** with your vision.
But mostly its for taking photos so...any color :)
Offline quake4mhg
« Reply #23 on: Fri, 20 February 2015, 21:16:41 »
White. It really related to my job. I watch too much color on screen, need a rest  on eyes. Both at dim working environment at office or playing night maps in Insurgency or Arma 3 with lights off.
« Last Edit: Fri, 20 February 2015, 21:19:12 by quake4mhg »
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #24 on: Fri, 20 February 2015, 21:57:20 »
The blue, purple and pink of the Ducky Mini is glorious...
Offline tbc
« Reply #25 on: Fri, 20 February 2015, 22:09:46 »
blue ftw
death to red
green looks like puke
Offline dante
« Reply #26 on: Fri, 20 February 2015, 22:09:52 »
As close to Wyse Dumb Terminal Amber as possible.
Offline ablooga
« Reply #27 on: Fri, 20 February 2015, 22:12:17 »
so firing a soft and easy red laser pen into your eyes won't hurt? I beg to differ
Offline davkol
  •  Post Editing Timeout
« Reply #28 on: Sat, 21 February 2015, 05:52:46 »
Not blue. Blue LEDs are generally brighter than others (may damage eyes) and blue light disrupts circadian rhythms.
Best is none though. Ambient light in the room, touch typing and optional doubleshots with a contrasting legible font FTW! Aesthetically, thick keycaps that don't let any shine through and a plate that reflects dim white/red/green light look neat.
Offline Chromako
  • Worshipper of the Topre and IBM Gods
« Reply #29 on: Sun, 22 February 2015, 07:15:35 »
None! Topre and Buckling Springs don't have backlighting, silly.  :D
Okay. Seriously. When there is backlight, I like white's aesthetics (I guess I've grown up around too much Apple gear), but for functionality and to lessen eye strain, preserve night vision, and not mess with your circadian rhythm, I'd go with red.
Thou Shalt Not Violate Causality, Nor Shalt Thou Invert Thy Spacebar.
Offline Bakgrund
« Reply #30 on: Sun, 22 February 2015, 07:22:04 »
White is the best in my opinion, on most keyboards you can dim it so it won't be an issue at night. I think green/red/blue are too obnoxious and immature, I like to keep things clean.
Quickfire Rapid    Quickfire Rapid
Mx Browns          Mx Reds
Ducky thick PBT   Stock caps
Offline Chromako
« Reply #31 on: Sun, 22 February 2015, 07:25:28 »
I think we're talking about comparing harshness with equal lighting intensity (cd/m2). Bringing lasers and coherent light into this is like equating rubber mallets with machetes, or apples and garlic (oranges?). Very different situations here.
Offline Defect
« Reply #32 on: Sun, 22 February 2015, 07:39:52 »
Better than a green laser that would burn through your eye.  But we are talking LED light, not laser.
Either way, scientifically Red would be least disruptive.
That's why submarines, cop cars (and Audi's), and dark rooms use red lights.
Offline spale
« Reply #33 on: Sun, 22 February 2015, 07:50:56 »
I used to love backlight,  and could not ever imagine the keyboard without one. My favorite colour was white.
And then I entered Topre world,which does not have any kind of LEDs. Finally, after some time, I concluded that backlight is one really unnecessary thing, people  need to work in properly lighted conditions.
