Author Topic: So you bought a new keyboard, tell the next person why they shouldn't buy it  (Read 15578 times)
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
Congrats, you've descended into wallethack and you've spent your hard earned money on a new keyboard. Even if you like this new board that you've bought, tell the next person why they shouldn't (was it over-hyped,bad value, ping, rattle etc?) buy it.
Offline wyatt8740
  • Machine code enthusiast
Don't buy an AT101W, unless you plan to replace the switches or use it for the mounting plate.
The 101W's black Alps suck.
(thankfully, mine was free - I'm just spreading the word that no one should pay more than $0.00 on one.)
I have since started going through the switches and removing the tactile plates to see if I can make a nice linear switch.
I don't usually collect things, but when I do, they're from the 70's, 80's, and 90's. My typing speed: 79 WPM
IBM Model M 1386303, 1987 / IBM Model M 1391401, 1993 / IBM Model M 59G7980, 1993 / Unicomp "Mini M" UT40E7A (modded), 2021 / Dell AT101W, 1994 (Black Alps) / Apple Extended Keyboard (Orange Alps), 1987 / Sun Type 5, unknown year (Rubber Dome)
Offline FrostyToast
  • Litshoard
Don't buy an SSK.
Model Fs just make these things feel like ****e.
I just feel silly for spending so much on a board that doesn't get used often at all.
Quote from: elton5354
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
Don't buy an HHKB, sometime the tactility gets annoying.
Offline wyatt8740
Don't buy an SSK.
Well, if you don't want yours... I'll trade my AT101W and a few dollars for your SSK ;)
I haven't been spoiled by a Model F yet, so it'll be okay for me.
Offline billnye
  • ability man
Don't buy a 360 Corsa.
You have to, like, assemble it all yourself.
It doesn't even come with switches
And it uses some weird cable (it's not USB idk what it is)
Plus shipping from Korea was so expensive :'( :'(
Offline brimborion
  • Likes Matias Switches
Don't buy a KB Paradise v60 MTS. If you have to switch to a full size your fingers will be in the wrong place, and it's Matias so there are many fewer keycaps available. It's not PBT so you'll end up swapping it out for something that has PBT caps anyway, because even if you find Matias compatible caps they won't have the correct fn layer legends.
Plus the v80 TKL MTS is on its way and that's probably what you really wanted all along.
Buckling Spring: 42H1292,  1391401, Unicomp Linux 101, Customizer 104 | Cherry Blue: Rosewill RK-9000, Das Keyboard S Pro | Cherry Black: Wyse/Link 840358-30| Rubber Dome: various Key Tronic, HHKB Lite, HHKB Lite 2, KB-8923, 71G4644 | Topre: Type Heaven | ALPS: Matias Mini Tactile Pro, 2xKBP V60
Don't buy a GH60, you'll wait two years or more to get a board that's not even all that great anymore.
Also, don't buy a Kingsaver.  Alps are awesome, but caps for it are practically impossible to find and TKL is inferior to 60%.
Don't buy that keyboard that nubbinator made...oh, wait. ;)
Offline FrostyToast
  • Litshoard
Also, don't buy blue ALPS. Just give them all to me.   ;D
Although seriously, be careful how much you pay for a blue ALPS keyboard. After all, you are pretty much paying for just the switches.
Anything over $100 is quite steep and even though I paid much, much more than that for mine, I still recommend being patient as it isn't worlds apart from other clicky switches.
Offline Whats_Dat
Re: So you bought a new keyboard, tell the next person why they shouldn't buy it
« Reply #10 on: Thu, 19 February 2015, 17:51:14 »
Don't get a IBM Model M, waiting for the ps2 adapter is infuriating and some of the top key caps(What do you gall the ones over the stem??) can be slightly mis aligned.(At least on mine) It annoys the ***p out of me.   :D
//Datalux_Space_Saver// //IBM_Model_M_49_Key_Pad//
//IBM_Model_M// //Focus_KeyPro_FX-9000//
Offline tbc
« Reply #11 on: Thu, 19 February 2015, 17:51:36 »
don't buy an mx green board because they are just a little heavier than blues.  they are like 3x as heavy.
« Reply #12 on: Thu, 19 February 2015, 17:55:08 »
I promise I won't ruin your credit, just ding it a little.  And I'll be signing you up for those GBs you were going to do anyways.
About to go make some posts as swill, BRB.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #13 on: Thu, 19 February 2015, 18:17:53 »
Don't buy a B87. it... uh... took a while to get here...
Offline JinDesu
« Reply #14 on: Thu, 19 February 2015, 18:19:47 »
Don't buy the KBT Race S if you want to use keycap sets.
Someday somebody will best me, but it won't be today, and it won't be you.
Proud owner of a Filco Majestouch Cherry MX Blue Tenkeyless, KBT Race S, & Realforce 101
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #15 on: Thu, 19 February 2015, 18:39:44 »
Because they can't?  After all it's yours.  What a silly question!
« Last Edit: Thu, 19 February 2015, 21:32:02 by Snowdog993 »
Offline Nai_Calus
  • CLACK
« Reply #16 on: Thu, 19 February 2015, 20:04:37 »
Don't buy a WASD Code, Costar stabilizers are Satan.
- IBM 4704 Model F 107-key "Bertha"
Other boards: Kinesis Essential, Infinity(G.Clears), Ergodox(MX Blues), Monoprice 9433
Eternally searching for Celestial Blue BS V2 and blue/purple Bros.
« Reply #17 on: Thu, 19 February 2015, 20:13:19 »
i haven't bought a keyboard in like 2 years now
wolf why do you always make threads that exclude me :(
Offline ShardZer0
« Reply #18 on: Thu, 19 February 2015, 20:16:36 »
Don't buy a Ducky Mini, you'll break your floor if you drop it.
Offline Sygaldry
  • Edema Ruh
« Reply #19 on: Thu, 19 February 2015, 20:16:39 »
Don't buy a CM QFR because no keyboard under 300 dollars is worth buying. Anything below that price point is ****e.
null
Offline chicken
  • Gallus gallus domesticus
« Reply #20 on: Thu, 19 February 2015, 20:52:46 »
My first board was a Rapoo KX. It has a metal plate, which you have to keep off to use aftermarket caps. Backlighting is uneven, and has a really weird layout. But it was 50 bucks so.......... :-\
Offline mouse.the.lucky.dog
« Reply #21 on: Thu, 19 February 2015, 21:18:10 »
Don't buy that keyboard because they might run out of stock if you do. Then I won't be able to by another.
« Reply #22 on: Thu, 19 February 2015, 21:26:21 »
don't buy a pure pro
it's **** all around
Offline exitfire401
  • The Force is Re/\l
« Reply #23 on: Thu, 19 February 2015, 21:29:27 »
Any Race for that matter...That's the only downfall of that board. Love mine to death though. Wouldn't be trying to sell it if it wasn't for the TX1800
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #24 on: Thu, 19 February 2015, 23:37:12 »
Any board that can't be fitted with a winkey + tsangan set really.
« Reply #25 on: Thu, 19 February 2015, 23:38:51 »
so basically, just dont buy anything.
Offline radio_killah
  • Chinchillin'
« Reply #26 on: Fri, 20 February 2015, 00:29:50 »
Only way to stop the wallethack.
« Reply #27 on: Fri, 20 February 2015, 00:54:25 »
Don't buy a KMAC 1.2 just to have a KMAC 1.2.. there are better quality Korean customs out there now. And don't buy a ****ing Race because it's not fully programmable or compatible with custom keycaps.
Offline bueller
  • MX baller
« Reply #28 on: Fri, 20 February 2015, 00:59:46 »
I just don't get the whole KR boards thing, seems like it's more about exclusivity than keyboards at this point.
« Reply #29 on: Fri, 20 February 2015, 01:04:10 »
I just collect ones that are blue. Maybe pink. Thats why I don't really want this KMAC I just happen to have it.
« Reply #30 on: Fri, 20 February 2015, 01:06:41 »
They're like.. metal and stuff.
Until there is a good GH custom, I'll continue salivating over them.
« Reply #31 on: Fri, 20 February 2015, 01:07:25 »
Didn't you make your own for this purpose...
Offline GSimon
« Reply #32 on: Fri, 20 February 2015, 01:09:51 »
Don't buy Das Keyboard Model S! The space-bar might be crappy which ruins the entire keyboard.
Sifo can testify
Offline Oobly
« Reply #33 on: Fri, 20 February 2015, 01:16:15 »
Don't buy a modern Cherry G80 (unless it's for switch harvesting). They're flimsy, bendy, feel bad to type on, have a 2KRO matrix and the keycaps are thin and often lasered off-centre. Also, they're physically massive, yet light.
Can't think of any reason not to buy the two boards I use daily (KBT Pure and GON NerD60 in a Vortex case)... Except, the KBT Pure has the switches mounted the "right" way round, so the LED's are on the "wrong" side for most backlit caps?
Ah yes, don't buy a 60% because Fn keys cannot be positioned in truly useful places on standard layout and it takes about the same effort to move your hand to press the Fn key with your thumb (or hold it down with a pinkie) as it would to move your hand to the arrow and edit clusters... So actually a TKL could still be less effort to use or save the already overworked pinkies from more strain.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #34 on: Fri, 20 February 2015, 11:31:17 »
That was my first design. Lots of improvements needed to be made to put it on par with the Korean boards. Maybe I'll do another in the future with those improvements made.
Offline azhdar
  • Praise the AZERTY god
« Reply #35 on: Fri, 20 February 2015, 11:33:49 »
can I get a link to this? Seems interesting.
Azerty Propagandiste
« Reply #36 on: Fri, 20 February 2015, 11:36:21 »
Don't buy a topre board unless you are prepared to buy more topre boards.
Offline plegnic
  • Treble Booty. Bass Guitar.
« Reply #37 on: Fri, 20 February 2015, 11:39:07 »
Don't buy a Poker II...
- Nobody will be impressed or want to even hear about it on the internet
- The poker 3 is coming out soon
- The DIP switch options will only get you frustratingly close to the layout you want
- Stupid phrases all over this thing: "Enjoy your feeling" "The keyboard to cheer you up"
Planck MIT layout [MX Clears] (in-progress) | QuickFire Storm TK [MX Brown] | Poker II [MX Blue]
Offline snipars
« Reply #38 on: Fri, 20 February 2015, 12:05:01 »
don't buy a poker 2
it's really buggy
the layout is annoying
it has cherry stabs
it's still one of my favourite keyboards, but this is why you shouldn't buy it
Duck Octagon + Gateron Black |HHKB Pro 2 | Poker 2 + Vintage Black + Tex case | Unicomp Ultra Classic | WASD V2 |
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #39 on: Fri, 20 February 2015, 12:12:33 »
don't buy a poker 2
it's really buggy
it has cherry stabs
Cherry stabs >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>miles ahead of costar
Offline snipars
« Reply #40 on: Fri, 20 February 2015, 12:26:02 »
don't buy a poker 2
it's really buggy
it has cherry stabs
they feel so mushy and gross, i hate them
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #41 on: Fri, 20 February 2015, 12:27:24 »
don't buy a poker 2
it's really buggy
it has cherry stabs
I only like them more because they are a lot easier to use.
« Reply #42 on: Fri, 20 February 2015, 15:00:42 »
Don't buy a Topre board unless it's a HHKB.  The FC660C and CM Novatouch suck and Realforces aren't the best feeling unless you can float, which is tough to do on Topre.
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #43 on: Fri, 20 February 2015, 15:27:49 »
I lol'd. They are so heavy and so well made. I honestly don't know who would win between a Ducky Mini and a Model M.
Offline Novus
  • Mondai nothing~
« Reply #44 on: Fri, 20 February 2015, 17:34:42 »
don't buy a poker 2
it's really buggy
it has cherry stabs
I think only the modern ones seem to feel good well at least for me
Offline Geroximo
« Reply #45 on: Fri, 20 February 2015, 19:39:41 »
I got a modern Cherry G80 (MX Black) for almost nothing. Cleaned it, lubed it and replaced the thin PBT caps with thick PBTs. It now feels, at least to me, even better than the QFR (MX Black). Too bad I cannot use boards bigger than TKL anymore.
Offline DrHubblePhD
  • I am star stuff
« Reply #46 on: Fri, 20 February 2015, 19:47:42 »
Last keyboard purchase was the 360c. Dont buy it if you cant assemble it yourself :)) Also I am certain that aluminum plates suck, mine bent all over the place just trying to install switches.
Offline davkol
  •  Post Editing Timeout
« Reply #47 on: Sat, 21 February 2015, 06:08:44 »
Don't buy a HHKB. There's a non-trivial risk that 55g keys will hurt your fingers (be it Topre in Pro, or Chicony rubber dome in Lite), the USB hub in HHKB 2 is a gimmick, the embedded navigation layer is stupid (goes more or less in the opposite direction than staggering) and it's barely any smaller than a 75% keyboard... overall, an overpriced luxury item that only gives you street cred.
Offline brimborion
« Reply #48 on: Sat, 21 February 2015, 13:05:38 »
Don't buy a Type Heaven because the "thock" is slightly higher pitched, accounting for $150 of lost value vs. the Realforce, and if you mention it you will get a strained, polite smile.
Don't buy a Matias Tactile Pro because it feels like rummaging through a bucket of legos.
« Reply #49 on: Sat, 21 February 2015, 14:33:27 »
The HHKB has 45g domes.  I've never heard of someone complaining about the HHKB hurting their fingers since it doesn't have a metal plate.
