Author Topic: 2nd keyboard: new switch or same?  (Read 4147 times)
Offline ianbullock
« on: Fri, 20 February 2015, 14:58:43 »
General question: I will have two keyboards, one at work and one at home. I could get one with the same switches (have QF TK w/ MX brown), or try something new (MX clear?). Obviously, trying something new is tempting. (I have tried a Model M for a bit as well but I think key force that high is not really suitable for me.) But, the drawback could be that it might be annoying to switch back and forth between the two switch profiles.
So, I am wondering from those of you who have 2 (or many more) keyboards: Do you feel your typing performance is best when you are using keyboards with the same switch profile throughout your day? Is it easy or difficult to adjust back and forth between multiple switch profiles?
Sorry if this has been asked before (new here), but didn't see it in the FAQ at least. Thank you!
Offline FrostyToast
  • Litshoard
Re: 2nd keyboard: new switch or same?
« Reply #1 on: Fri, 20 February 2015, 15:01:29 »
I can honestly say that having multiple switches makes you appreciate them much more.
After a while you will get bored of the switches that you are using and it will feel like a breath of fresh air switching to something new.
I just notice the pop of my topre board infinitely more after using MX blacks and then I realise the orgasmic smoothness of the blacks so clearly after switching from topre.
Quote from: elton5354
Offline FreeCopy
« Reply #2 on: Fri, 20 February 2015, 15:11:48 »
I rotate between BS, MX Blue, and MX Red. I find that going between the blues and bs isn't much of an adjustment at all. Going from either of those to the reds there is a bit longer of an adjustment period but is still pretty negligible.
Ultimately for me it doesn't matter what I'm typing on my speeds are pretty close to the same, well, except for the horrible bluetooth board I use in the living room that has scissor switches. I think my wpm drops to like 12 on that pos.
Overall I enjoy the different switches. Like music, I feel each switch type goes with a mood. Sometimes I want to rock out, BS. Sometimes I just want to jam, blues, and others I just want to cruise easy, reds. I have plans for many more switch types to expand on this.
Keyboards
Poker II | Leopold fc500r | Bolt Modded M 1391401 x2 08NOV90 - 19NOV90 | FK-2001 White Alps Clones | Filco MJ2 104 |  Bolt Modded SSK 1391472 27JUL87 | Winkeyless B.87 TKL | MiniVan GateReds 62g
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #3 on: Fri, 20 February 2015, 15:25:46 »
Definitely different. I currently have 9 boards, using 4 different key profiles, 5 form factors, 7 different switch types and I think it's great. You get to a point where you are using the same board every day and you think; "Huh, I think I might swap back to my KC84/Model M/Ducky Mini today", and you have a whole new typing experience.
If you like the tactility of browns, then definitely try out clears. There are a lot of good boards out there now who are stretching beyond just blues, reds, browns and blacks, and moving to clears and greens, so it won't be hard to find one you like the look of. Then you can think about if you want to change the size to 40/60/75% or TKL or whatever :)
Offline BrewCaps
« Reply #4 on: Fri, 20 February 2015, 17:24:44 »
You owe it to yourself to try Cherry Blues.
Offline smknjoe
« Reply #5 on: Fri, 20 February 2015, 17:28:21 »
SSKs for everyone!
Offline slickmamba
« Reply #6 on: Fri, 20 February 2015, 17:34:25 »
I pretty happily switch between linears, topre, and clears.  I've gotten used to the different boards(dox, hhkb, viper, 87ub) and they are all awesome. I see having multiple types as a positive
Hi :)
« Reply #7 on: Fri, 20 February 2015, 17:35:58 »
Nope.
Save yourself a **** ton of money and get a HHKB.  Blues are disappointing, Reds are ****, Mathias Alps are nothing special (though OG Alps are awesome outside of Black and White), Model Ms are inferior to Fs, and Korean customs are fun but will ultimately take a back burner to your cheaper HHKB when you pick it up.
Offline slickmamba
« Reply #8 on: Fri, 20 February 2015, 17:39:30 »
Nope.
I'm so happy and proud to have been a part of this hhkb love
Hi :)
« Reply #9 on: Fri, 20 February 2015, 17:41:16 »
Nope.
I was the biggest skeptic in the world and really did attribute it to some sort of Stockholm Syndrome/post-purchase rationalization, but after using yours for free, it really is fantastic.  I still hate plate mounted Topre, but the HHKB is special and great.
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #10 on: Fri, 20 February 2015, 17:49:58 »
HHKB TYPE S.
SORRY
I
couldn't
help
myself
« Reply #11 on: Fri, 20 February 2015, 18:17:42 »
Nope.
wrong. blues are awesome. op try cherry bruise (blue stem/black spring) or greens. just no linear, because they are boring.
« Reply #12 on: Fri, 20 February 2015, 18:31:27 »
Nope.
You only like Blues because they remind you of holding jumping beans.  Blues just make a **** ton of annoying noise and have a disappointing bump.  It's like the white girl's ass of bumps.
« Reply #13 on: Fri, 20 February 2015, 18:32:39 »
Nope.
well if it's two things i like it's
a) noise
b) white girl's butts
wtf how did we get here? you defending hhkb and me defending cherry.
BIZARRO GH
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #14 on: Sat, 21 February 2015, 09:48:32 »
I have a Dell AT101W at work and vary the board I use at home according to which one I'll be reviewing next. So the one at work never changes but the one at home changes every other week.
I had a little trouble using my AT101W while I was testing out my Chicony KB-5981 because the Monterey switches made me type so light that I had trouble using the (much heavier) Alps switches in the Dell xD . Right now I'm typing on a board with even lighter switches and I'm not having trouble using the Dell at work, though. Must've been a special thing.
I really don't mind having two kinds of keyboards, especially if they fulfill different roles like gaming and typing. Even when it's the same I think it only adds more variation and gives you more things to play with, really.
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #15 on: Sat, 21 February 2015, 10:09:20 »
Nope.
Model Ms are inferior to Fs, .....
I humbly disagree with you nubbinator.  The XTANT is a great project, and I think that is a great change to the model F keyboard, but overall, I'll stay with my model M keyboard.  I don't have to make any changes at all with the layout.  I won't mention the heartache and pain of getting a model F to work again if it has problems.
« Reply #16 on: Sat, 21 February 2015, 20:19:41 »
i rotated regularly until i found out which switches i like the most
now i pretty much only use 2-3 keyboards
Offline Veridis
« Reply #17 on: Sun, 22 February 2015, 03:07:16 »
I use Browns both at work and at home. My experience is 6 years with blues, 6 months with browns and 2 months with topre.
Using the same switch type really eliminates any adjustment period.
No one's stopping you to have other switch types to play with once in a while though :)
Ducky Shine 3 TKL (MX Brown) | CM Rapid-i (MX Brown) | Realforce 87u 45g Uniform | CM Novatouch | Ducky Zero TKL (MX Brown) | Das Keyboard III (MX Blue)
Offline Oobly
« Reply #18 on: Mon, 23 February 2015, 06:01:15 »
Variety is nice, especially when the variety includes Clears ;)
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline SpikeBolt
  • √(4) != -2
« Reply #19 on: Mon, 23 February 2015, 10:11:27 »
This is the kind of stuff that is extremely personal.
I would recommend getting a different switch, because browns are pretty boring and expanding your knowledge is always a good thing :P The "problem" with getting a board with different switches is that you'll most likely end up preferring one over the other and may even start to dislike previously experienced switches. This happened to me quite a bit and I entered a buy/sell spiral. I wouldn't say it is really a problem, as long are you're willing to make the time, money and feelings investment.
Offline Doyniish
  • Good you
    • Power Hour Playlists
« Reply #20 on: Mon, 23 February 2015, 14:19:58 »
Switch it up. No pun.
Offline tbc
« Reply #21 on: Mon, 23 February 2015, 14:59:06 »
Nope.
it's like the white girl's ass of bumps.
that's like the best thing ever
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #22 on: Mon, 23 February 2015, 17:30:44 »
If you only have the one board, I'd definitely try out a new switch
Offline ianbullock
« Reply #23 on: Mon, 23 February 2015, 23:31:28 »
Thanks for the input everyone! I decided to go for a different switch as most of you suggested. Will try out MX Blue on a Filco Minila.
I tried out my friend's ErgoDox in MX Clear, but that switch just feels a little too heavy to me - I personally actually prefer brown to it. Did make me interested in slightly unconventional layouts like the Minila where I might be able to use my thumbs to do more than just hit the spacebar.
I'm also acquiring some keycap sets of various types so I can see how that affects things :).
Offline slickmamba
« Reply #24 on: Mon, 23 February 2015, 23:38:33 »
If you get a chance, try out some ergo clears.  They are clears with lighter springs (either stock mx red/brown/blue springs, or 60-65g korean springs)
Hi :)
Offline Oobly
« Reply #25 on: Tue, 24 February 2015, 03:22:03 »
^^This. Way better tactility than Browns.
Keycaps can make quite a big difference. If you get a chance, try SA profile caps. They're the heaviest I've found so far (almost exactly 2g per cap!) and feel very different to stock OEM or DCS caps.
Offline klikkyklik
    • Klikky Klik
« Reply #26 on: Tue, 24 February 2015, 08:36:21 »
Good decision on getting a different switch, and good decision trying out blues.
The next question is of course, what switch are you going to try after THOSE?  I liked reds better than browns, so you'll probably have to give them a shot.  But then Alps... and Topre... and Gaterons...
I hope you know what you're in for.  :)
