Author Topic: How is the "Keyboard Power" scancode used on Mac?  (Read 4375 times)
« on: Mon, 23 February 2015, 12:19:45 »
Hey guys, being a windows user I'm confused by this key and how I should support it.
The USB HID usage page 7 for keyboards defines scancode 0x66 as "Keyboard Power" and only lists it as supported on the Mac platform.  It also implies through a footnote that it never mapped to a key.
If I remember correctly, the KMAC keymapper included this scancode but it didn't do anything on Windows.  (I haven't used it in a long time)
So is this scancode useful when mapped to a key on the Mac?  What does it do?  Should I add it as an option?
To all you poor Apple users, thanks for any insights!
Re: How is the "Keyboard Power" scancode used on Mac?
« Reply #1 on: Mon, 23 February 2015, 12:52:08 »
So there's a wiki page on the topic: https://en.wikipedia.org/wiki/Apple_Keyboard
However I'm still not sure if the modern USB boards actually send that scancode.  It appears the older boards had dedicated lines for the power switch.
Offline MJ45
  • HHKB Pro
« Reply #2 on: Mon, 23 February 2015, 13:27:59 »
I think that was from the ABD days before Apple went to USB.
Offline tufty
« Reply #3 on: Mon, 23 February 2015, 15:03:43 »
The older boards for ADB based macs do both.  They send a scancode, which the OS interprets as a command to power down, *and* do soft power on through the extra wire in the ADB connector.
The USB keyboards, with the exception of the original USB keyboard, don't have a power button.  You'd want to look at what's sent when you do cmd-option-eject, which is the "power off" keystroke these days
Offline hasu
  • @tmk
« Reply #4 on: Tue, 24 February 2015, 08:36:24 »
I've not owned Mac for long time since my first-gen Macbook pro was broken miserably but I can remember 0x66 works on OSX.
Mac mode of HHKB sends the code as Power key(Fn + Esc).
Linux also recognize that code without problem but poor Windows doesn't so we have to use Usage page 0x01 instead.
EDIT: IIRC, volume control keys(0x7F, 0x80, 0x83) also can be used on Linux and Mac but not Windows :(
« Last Edit: Tue, 24 February 2015, 08:43:50 by hasu »
« Reply #5 on: Tue, 24 February 2015, 12:03:15 »
Thanks Hasu :)
I added the scancodes to the selector.  What the heck, doesn't hurt anything.
Aqua's key test on Windows saw a scancode but obviously didn't match it to anything.
Also apparently Mac-only is the KEYPAD_EQUALS, which I think is 0x67.
