Author Topic: TMK USB to USB keyboard converter  (Read 1359535 times)
Offline pupmonster
Re: TMK USB to USB keyboard converter
« Reply #900 on: Fri, 01 March 2024, 00:37:34 »
I continued with my testing of miniM_ab4b44.hex and populated it with my layout.
It solved a problem with the previous last-working version where keystrokes would strangely appear that I had not typed.  Perhaps this information is useful to you.
Offline pupmonster
« Reply #901 on: Sat, 02 March 2024, 03:20:08 »
Continuing testing ...
Perhaps it was not the intention of the interim file you provided, but using it, I have not been able to remap the bottom-row control keys, e.g. left-option, japanese_pc_nfer, japanese_pc_xfer, japanese_pc_katakana.
Offline hasu
  • @tmk
« Reply #902 on: Sat, 02 March 2024, 03:57:33 »
This is not what I expected, I missed something probably.
I'll have to start over debug process.
Hasu, here are the results:
miniM_ab4b44.hex:  All keys register
miniM_woHubFix.hex: No keys register
The firmwares I attached before were built only for debug and cannot be remapped with keymap editor.
Use one attached in this post if you need to remap. This firmware is not full-function but should work.
* miniM_ab4b44_unimap.hex (71.92 kB - downloaded 524 times.)
Offline pupmonster
« Reply #903 on: Sat, 02 March 2024, 07:21:01 »
Merci! That helps a lot!
Offline hasu
  • @tmk
« Reply #904 on: Sat, 02 March 2024, 08:46:51 »
Can you try these fimwares to when you have time?
And let me know your result.
Thank you
* miniM_35606b.hex (56.54 kB - downloaded 481 times.)
* miniM_a98e6f.hex (59.45 kB - downloaded 513 times.)
Offline pupmonster
« Reply #905 on: Sat, 02 March 2024, 22:24:23 »
Here are my results as tested on Mac and Linux
miniM_35606b.hex:
    all keys register
    behaviour while typing is as desired (no strange extra character inserts)
    capslock light comes on
    numlock light does not come on
    scrolllock light does not come on
miniM_a98e6f.hex:
    all keys register
Offline hasu
  • @tmk
« Reply #906 on: Tue, 05 March 2024, 02:01:07 »
pupmonster,
I don't find a fault point yet. Can you try these also?
Post debug prints if it fails.
Thank you for your help.
* miniM_85af76.hex (60.41 kB - downloaded 499 times.)
* miniM_df8e64.hex (61.97 kB - downloaded 515 times.)
Offline pupmonster
« Reply #907 on: Tue, 05 March 2024, 10:25:21 »
Hasu, glad to assist.
Here you go:
miniM_85af76.hex:  no keys register
miniM_df8e64.hex:  no keys register
Tested on MacOS and Linux.
« Last Edit: Tue, 05 March 2024, 10:29:33 by pupmonster »
Offline hasu
  • @tmk
« Reply #908 on: Wed, 06 March 2024, 00:21:15 »
Can you post debug prints from miniM_85af76.hex?
This fix affects the issue, perhaps.
https://github.com/tmk/USB_Host_Shield_2.0/commit/9072c34c6fc669d696a8f0a99807e076531a2163
Offline pupmonster
« Reply #909 on: Wed, 06 March 2024, 09:33:45 »
I am not sure I did what you need, but this is what I have:
I flashed the keyboard with miniM_85af76.hex, and started hid_listen as root on Linux.   I pressed every key from left to right, top to bottom.
The results are in the next message as an attachment. It is named "out.hex" because when I tried to upload a file with a .txt extension the server gave me an uncaught exception. The same happened when I tried to insert the output into this message.
« Last Edit: Wed, 06 March 2024, 10:02:11 by pupmonster »
Offline hasu
  • @tmk
« Reply #910 on: Wed, 06 March 2024, 23:48:31 »
That log is what I needed. Thank you.
I think I found one of the causes at least and fixed it.
* miniM_fix_5ed16b.hex (61.9 kB - downloaded 607 times.)
Can you try this and share debug prints?
Use this procedure to get debug prints.
1. run hid_listen
2. plug in the converter first and wait for 5 sec
3. plug in the keyboard then
4. press a few keys
Offline pupmonster
« Reply #911 on: Thu, 07 March 2024, 03:20:34 »
Results here inline, as attachment somehow was disallowed by forum:
Code: [Select]
sudo ./hid_listen
Waiting for device:....
Listening:
TMK:5ed16b/LUFA:d6a7df/UHS2:df8e64
u:20
[S][W][W]u:40
u:50
u:51
[W]BM Init
Addr:01
NC:01
HID_PROTOCOL_KEYBOARD
bNumEP:02
Cnf:01
bIfaceNum:00
bNumIface:00
Interface:00
SET_PROTOCOL: 00
SET_IDLE: 00
RPIPE: 00
RWU: 00
BM configured
u:90
s:f
USB configured.
[i]
Loop start.
usb_state: 90
speed: full
input 1: 00 00 0A 00 00 00 00 00 00 00 00 00
ginput 1: 00 00 00 00 00 00 00 00 00 00 00 00
input 1: 00 00 0B 00 00 00 00 00 00 00 00 00
hinput 1: 00 00 00 00 00 00 00 00 00 00 00 00
input 1: 00 00 12 00 00 00 00 00 00 00 00 00
oinput 1: 00 00 00 00 00 00 00 00 00 00 00 00
input 1: 00 00 26 00 00 00 00 00 00 00 00 00
9input 1: 00 00 00 00 00 00 00 00 00 00 00 00
input 1: 00 00 49 00 00 00 00 00 00 00 00 00
^[[2~input 1: 00 00 00 00 00 00 00 00 00 00 00 00
input 1: 00 00 46 00 00 00 00 00 00 00 00 00
·input 1: 00 00 45 00 00 00 00 00 00 00 00 00
^C
steveg@fedora-t14:/data/apps$ sudo ./hid_listen
Waiting for device:........
Listening:
u:20
[S][W][W]u:40
u:50
u:51
[W]BM Init
Addr:01
NC:01
bNumEP:02
Cnf:01
bIfaceNum:00
bNumIface:00
Interface:00
SET_PROTOCOL: 00
SET_IDLE: 00
RPIPE: 00
RWU: 00
BM configured
u:90
s:f
USB configured.
[i]
Loop start.
usb_state: 90
speed: full
input 1: 00 00 04 00 00 00 00 00 00 00 00 00
ainput 1: 00 00 00 00 00 00 00 00 00 00 00 00
input 1: 00 00 16 00 00 00 00 00 00 00 00 00
sinput 1: 00 00 00 00 00 00 00 00 00 00 00 00
input 1: 00 00 52 00 00 00 00 00 00 00 00 00
00 00 52 00 00 00 00 00 0^[[A0 00 00 00
input 1: 00 00 43 00 00 00 00 00 00 00 00 00
^[[21~input 1: 00 00 00 00 00 00 00 00 00 00 00 00
input 1: 00 00 33 00 00 00 00 00 00 00 00 00
òinput 1: 00 00 00 00 00 00 00 00 00 00 00 00
input 1: 00 00 8A 00 00 00 00 00 00 00 00 00
input 1: 01 00 00 00 00 00 00 00 00 00 00 00
« Last Edit: Thu, 07 March 2024, 10:08:44 by pupmonster »
Offline hasu
  • @tmk
« Reply #912 on: Thu, 07 March 2024, 06:25:37 »
It looks good now according to the log.
Let me know if you still have a problem. I'll update firmware on Keymap Editor soon later if not.
Next time, you can use CODE tag to include debug output in your message on this forum.
https://en.wikipedia.org/wiki/BBCode
https://www.bbcode.org/showing-code-with-bbcode.php
Offline pupmonster
« Reply #913 on: Thu, 07 March 2024, 10:07:07 »
Sounds good. Thanks so much. Your service is outstanding.
However, I do not quite understand how you intend to proceed or what I should ideally be doing on my end.
Should I use  miniM_fix_5ed16b.hex  as the basis of any adaptations to my keyboard layout in TMK Keymap Editor?
And ... I also just received the newest USB-USB adapter today in the mail. Thanks. Should I also use miniM_fix_5ed16b.hex there as well?
Or ... should I just start TMK Keyboard editor without first uploading a base hex file, in the understanding that the latest and greatest is being used automatically there?
Thanks much for the clarification!
Offline hasu
  • @tmk
« Reply #914 on: Thu, 07 March 2024, 18:03:02 »
miniM_fix_5ed16b.hex was built just for debug/test and it can be used with Keymap Editor.
With the fix the converter doesn't seem to have obvious problem with Mini M now.
I just updated firmware on github and Keymap Editor for Mini M support. Now you can edit keymap and download the fixed firmware on Keymap Editor.
https://www.tmk-kbd.com/tmk_keyboard/editor/unimap/?usb_usb
Offline pupmonster
« Reply #915 on: Fri, 08 March 2024, 10:20:30 »
Thanks, Hasu!
I thought you would like to know that I used the TMK Layout Editor to modify my layout of the Japanese Mini M using both my older USB-USB adapter and the brand-new adapter just received, and everything looks good.
Offline paiste
« Reply #916 on: Thu, 11 April 2024, 14:39:14 »
Hi,
so does this work if there is a hub between the real keyboard and the converter? Is it possible to have the firmware supporting for mouse only? (We have a devices that accepts only keyboard or mouse directly attached, but we need to use a USB over LAN that shows up as hub between keyboard / mouse and the device? Need tens of units.
Offline hasu
  • @tmk
« Reply #917 on: Thu, 11 April 2024, 18:47:39 »
- My firmware with current configuration can support two hubs. Yes, you can use hub between the converter and keyboard.
- My firmware does not support mouse.
It is possible for the converter to support  hub, keyboard and mouse technically if you can write custom code for that.
Offline timd
« Reply #918 on: Sat, 19 October 2024, 16:49:28 »
Hi Hasu,
I received my usb-usb converter the other day (thanks!), and I've been partly successful using it with my Chilkey ND75. Everything is good if I use the USB cable connection, however I'm not able to get it working with the 2.4G wireless dongle.
I was hoping that if I post the debug & dump hid_listen logs that you might be able to help?
usb_usb_debug.hex:
Code: [Select]
Waiting for device:
Listening:
usb_state: 20
usb_state: 40
usb_state: 50
usb_state: 51
BM Init
Addr:01
NC:01
bNumEP:01
D1
>>>>BUSRST
BM Init
Addr:01
NC:01
bNumEP:01
D1
>>>>BUSRST
BM Init
Addr:01
NC:01
bNumEP:01
D1
>>>>BUSRST
BM Init
Addr:01
NC:01
bNumEP:01
D1
>>>>BUSRST
>>>>BUSRST
>>>>BUSRST
host.Task: 2457
usb_state: 90
speed: full
usb_desc_dump.hex:
Code: [Select]
Waiting for device:
Listening:
TMK:7b2827/LUFA:d6a7df/UHS2:96112d
Start
USB configured.
Loop start.
usb_state: 12
usb_state: 20
usb_state: 40
usb_state: 50
usb_state: 51
usb_state: 90
// USB_desc_dump
// Address: 01
// Lowspeed: 00
// Devicer dump:
12 01 10 01 00 00 00 08 45 0C FE FE 23 01 01 02
00 01
// Device:
bLength: 12
bDescriptorType: 01
bcdUSB: 0110
bDeviceClass: 00
bDeviceSubClass: 00
bDeviceProtocol: 00
bMaxPacketSize0: 08
idVendor: 0C45
idProduct: FEFE
bcdDevice: 0123
iManufacturer: 01
iProduct: 02
iSerialNumber: 00
bNumConfigurations: 01
// String Zero: len: 04
// 04 03 09 04
// LangId: 0409
// iManufacturer: ERROR: 05
// iProduct: String2(0409): len: 18
// 18 03 32 00 2E 00 34 00 47 00 20 00 44 00 6F 00
// 6E 00 67 00 6C 00 65 00
// 2.4G Dongle
// Config0 dump: len: 0094
09 02 94 00 05 01 00 A0 23 09 04 00 00 01 03 00
00 00 09 21 00 01 00 01 22 48 00 07 05 81 03 08
00 01 09 04 01 00 01 03 00 00 00 09 21 00 01 00
01 22 3D 00 07 05 82 03 08 00 01 09 04 02 00 01
03 00 00 00 09 21 00 01 00 01 22 CD 00 07 05 83
03 10 00 01 09 04 03 00 02 03 00 00 00 09 21 00
01 00 01 22 22 00 07 05 85 03 30 00 01 07 05 05
03 30 00 01 09 04 04 00 02 03 00 00 00 09 21 00
01 00 01 22 22 00 07 05 86 03 40 00 01 07 05 06
03 40 00 01
// Config:
bLength: 09
bDescriptorType: 02
wTotalLength: 0094
bNumInterfaces: 05
bConfigurationValue: 01
iConfiguration: 00
bmAttributes: A0
bMaxPower: 23
// Interface0.0:
bLength: 09
bDescriptorType: 04
bInterfaceNumber: 00
bAlternateSetting: 00
bNumEndpoints: 01
bInterfaceClass: 03
bInterfaceSubClass: 00
bInterfaceProtocol: 00
iInterface: 00
// HID:
bLength: 09
bDescriptorType: 21
bcdHID: 0100
bCountryCode: 00
bNumDescriptors: 01
bDescrType: 22
wDescriptorLength: 0048
// Report0 dump: len: 0048
05 01 09 06 A1 01 05 07 19 E0 29 E7 15 00 25 01
75 01 95 08 81 02 95 01 75 08 81 01 95 03 75 01
05 08 19 01 29 03 91 02 95 05 75 01 91 01 95 05
75 08 26 FF 00 05 07 19 00 29 FF 81 00 05 FF 09
03 75 08 95 01 81 02 C0
// Endpoint:
bLength: 07
bDescriptorType: 05
bEndpointAddress: 81
bmAttributes: 03
wMaxPacketSize: 0008
bInterval: 01
// Interface1.0:
bLength: 09
bDescriptorType: 04
bInterfaceNumber: 01
bNumEndpoints: 01
bInterfaceClass: 03
iInterface: 00
// HID:
bLength: 09
bDescriptorType: 21
bcdHID: 0100
bCountryCode: 00
bNumDescriptors: 01
bDescrType: 22
wDescriptorLength: 003D
// Report0 dump: len: 003D
05 01 09 02 A1 01 09 01 A1 00 05 09 19 01 29 03
15 00 25 01 95 05 75 01 81 02 95 01 75 03 81 01
05 01 09 30 09 31 09 38 15 81 25 7F 75 08 95 03
81 06 95 01 05 0C 0A 38 02 81 06 C0 C0
// Endpoint:
bLength: 07
bDescriptorType: 05
bEndpointAddress: 82
bmAttributes: 03
bInterval: 01
// Interface2.0:
bLength: 09
bDescriptorType: 04
bInterfaceNumber: 02
bNumEndpoints: 01
bInterfaceClass: 03
iInterface: 00
// HID:
bLength: 09
bDescriptorType: 21
bcdHID: 0100
bCountryCode: 00
bNumDescriptors: 01
bDescrType: 22
wDescriptorLength: 00CD
// Report0 dump: len: 00CD
05 0C 09 01 A1 01 85 01 19 00 2A 3C 03 15 00 26
3C 03 95 01 75 10 81 00 C0 05 01 09 80 A1 01 85
02 05 01 19 81 29 83 15 00 25 01 95 03 75 01 81
02 95 01 75 05 81 01 C0 05 01 09 06 A1 01 85 03
05 07 15 00 25 01 19 00 29 77 95 78 75 01 81 02
C0 05 01 09 0E A1 01 85 06 05 0D 09 21 A1 00 05
09 09 01 95 01 75 01 15 00 25 01 81 02 05 01 09
37 95 01 75 0F 55 0F 65 14 36 F0 F1 46 10 0E 16
F0 F1 26 10 0E 81 06 09 30 75 10 55 0D 65 13 35
00 46 C0 5D 15 00 26 FF 7F 81 02 09 31 46 B0 36
81 02 05 0D 09 48 36 B8 0B 46 B8 0B 16 B8 0B 26
B8 0B 81 03 C0 C0 06 FF FF 09 01 A1 01 85 05 09
01 15 00 26 FF 00 75 08 95 03 81 02 C0
// Endpoint:
bLength: 07
bDescriptorType: 05
bEndpointAddress: 83
bmAttributes: 03
wMaxPacketSize: 0010
bInterval: 01
// Interface3.0:
bLength: 09
bDescriptorType: 04
bInterfaceNumber: 03
bNumEndpoints: 02
bInterfaceClass: 03
iInterface: 00
// HID:
bLength: 09
bDescriptorType: 21
bcdHID: 0100
bCountryCode: 00
bNumDescriptors: 01
bDescrType: 22
wDescriptorLength: 0022
// Report0 dump: len: 0022
06 60 FF 09 61 A1 01 09 62 15 00 26 FF 00 95 20
75 08 81 02 09 63 15 00 26 FF 00 95 20 75 08 91
02 C0
// Endpoint:
bLength: 07
bDescriptorType: 05
bEndpointAddress: 85
bmAttributes: 03
wMaxPacketSize: 0030
bInterval: 01
// Endpoint:
bLength: 07
bDescriptorType: 05
bEndpointAddress: 05
bmAttributes: 03
bInterval: 01
// Interface4.0:
bLength: 09
bDescriptorType: 04
bInterfaceNumber: 04
bNumEndpoints: 02
bInterfaceClass: 03
iInterface: 00
// HID:
bLength: 09
bDescriptorType: 21
bcdHID: 0100
bCountryCode: 00
bNumDescriptors: 01
bDescrType: 22
06 60 FF 09 61 A1 01 09 62 15 00 26 FF 00 95 40
75 08 81 02 09 63 15 00 26 FF 00 95 40 75 08 91
02 C0
// Endpoint:
bLength: 07
bDescriptorType: 05
bEndpointAddress: 86
bmAttributes: 03
wMaxPacketSize: 0040
bInterval: 01
// Endpoint:
bLength: 07
bDescriptorType: 05
bEndpointAddress: 06
bmAttributes: 03
bInterval: 01
// Parse data here: http://eleccelerator.com/usbdescreqparser/
Many thanks,
Tim
Offline hasu
  • @tmk
« Reply #919 on: Mon, 21 October 2024, 04:49:47 »
Hi Tim,
Thanks for the info.
It seems interface0 is boot keyboard compatible but it does not assert itself as a 'Boot keyboard' in USB descriptor for some reason. So Chilkey ND75 dongle is not a boot keyboard and the converter cannot detect it.
I'll look into to find a workaround for the dongle.
Offline timd
« Reply #920 on: Mon, 21 October 2024, 13:50:36 »
Thank you  :thumb:
Offline hasu
  • @tmk
« Reply #921 on: Tue, 22 October 2024, 09:35:14 »
timd,
Can you try attached firmware and post its log?
Thanks
* usb_usb_debug.hex (64.3 kB - downloaded 427 times.)
Offline timd
« Reply #922 on: Tue, 22 October 2024, 09:52:18 »
Thanks hasu - here's the log:
Code: [Select]
Waiting for device:
Listening:
usb_state: 20
usb_state: 40
usb_state: 50
usb_state: 51
BM Init
Addr:01
NC:01
vid:0C45
pid:FEFE
bNumEP:02
Cnf:01sssddddd
bIfaceNum:01
bNumIface:00
Interface:00
skip SET_PROTOCOL
SET_IDLE: 00
RPIPE: 00
RWU: 00
BM configured
host.Task: 2327
usb_state: 90
speed: full
It isn't picking up any keystrokes.
Offline hasu
  • @tmk
« Reply #923 on: Tue, 22 October 2024, 11:04:41 »
hmm, It seems to work still in nkro mode.
we have to make keyboard turn into 6kro boot mode, perhaps. This firmware may work.
* usb_usb_debug.hex (64.35 kB - downloaded 412 times.)
Offline timd
« Reply #924 on: Tue, 22 October 2024, 14:55:04 »
Hi Hasu, here's the log:
Code: [Select]
Waiting for device:
Listening:
usb_state: 20
usb_state: 40
usb_state: 50
usb_state: 51
BM Init
Addr:01
NC:01
vid:0C45
pid:FEFE
bNumEP:02
Cnf:01
bIfaceNum:01
bNumIface:00
Interface:00
SET_PROTOCOL: 00
SET_IDLE: 00
RPIPE: 00
RWU: 00
BM configured
host.Task: 2327
usb_state: 90
speed: full
Still no key presses recognised.
Thanks,
Tim
« Last Edit: Tue, 22 October 2024, 16:07:14 by timd »
Offline timd
« Reply #925 on: Tue, 22 October 2024, 16:05:08 »
Sorry, not sure what I did before... I was rushing as it was half-time in the football.
It's registering input now - thank you for looking into this:
Code: [Select]
Waiting for device:
Listening:
usb_state: 20
usb_state: 40
usb_state: 50
usb_state: 51
BM Init
Addr:01
NC:01
vid:0C45
pid:FEFE
bNumEP:02
Cnf:01
bIfaceNum:01
bNumIface:00
Interface:00
SET_PROTOCOL: 00
SET_IDLE: 00
RPIPE: 00
RWU: 00
BM configured
host.Task: 2328
usb_state: 90
speed: full
input 1: 00 00 0E 00 00 00 00 00
kinput 1: 00 00 00 00 00 00 00 00
input 1: 00 00 14 00 00 00 00 00
qinput 1: 00 00 00 00 00 00 00 00
input 1: 00 00 1A 00 00 00 00 00
winput 1: 00 00 00 00 00 00 00 00
input 1: 00 00 08 00 00 00 00 00
einput 1: 00 00 00 00 00 00 00 00
input 1: 00 00 15 00 00 00 00 00
rinput 1: 00 00 00 00 00 00 00 00
input 1: 00 00 17 00 00 00 00 00
tinput 1: 00 00 00 00 00 00 00 00
input 1: 00 00 1C 00 00 00 00 00
Regards,
Tim
Offline hasu
  • @tmk
« Reply #926 on: Wed, 23 October 2024, 01:55:27 »
OK. I updated firmware on Keymap Editor and github.
You can download the fixed firmware on Keymap Editor now.
Let me know if you have any problem.
Thanks
Offline timd
« Reply #927 on: Wed, 23 October 2024, 15:42:06 »
Thanks for your time debugging the issue, Hasu.
I've added a bit more information to the github issue https://github.com/tmk/tmk_keyboard/issues/778, but I just realised you may not have been notified as the issue is closed now. Basically, the keyboard isn't always recognised correctly, and the connection doesn't get re-established if the keyboard goes to sleep and is woken up.
Regards,
Tim
Offline qk6339zmdm
« Reply #928 on: Thu, 20 March 2025, 08:54:53 »
The Logitech Wave Keys works, using its "Logi Bolt" receiver
https://www.logitech.com/en-us/shop/p/wave-keys-ergonomic-wireless.920-012276
Offline hasu
  • @tmk
« Reply #929 on: Thu, 20 March 2025, 20:32:38 »
Thanks for the info! Updated in the first post.
Offline hasu
  • @tmk
« Reply #930 on: Sat, 19 July 2025, 05:20:15 »
I'm working on Sun Type-6/7 USB keyboard and just added initial support to the latest firmware.
It does not support 'blank' key between Help and F1 yet.
Code: [Select]
|  Help |  |   |  | F1| F2|
|Stp|Agn|  |Esc|  1|  2|  3
|Prp|Und|  |Tab  |  Q|  W|
|Frt|Cpy|  |Ctrl  |  A|  S|
|Opn|Pst|  |Shft| +\|  Z|
|Fnd|Cut|  |Caps  |Alt|Met|
I don't have any sun usb keyboard in hand acutually.
Is anyone happen to have with Sun USB keyboard with Unix layout here?
I like to know scan code(HID usage) of the 'blank' key. Let me know if you can help me.
https://github.com/tmk/tmk_keyboard/commit/eff87d8e12cee4b38dd1475c3df49cbc5e990ad6
Keymap Editor for Sun Type-6/7
Thank you
« Last Edit: Sat, 19 July 2025, 05:23:23 by hasu »
Offline Genricxs
« Reply #931 on: Fri, 15 August 2025, 09:27:18 »
I saw it also in Amazon and it's good. http://www.boiseconcretecontractor.com
Offline JimDetroit
« Reply #932 on: Wed, 10 December 2025, 16:31:25 »
Hasu,
I was trying to use the converter with a WASD v3 (non-CODE) 104-key keyboard I bought recently (used). I just updated to the latest code at Github, owing to the fact that the controller did not work with my WASD keyboard. The keyboard was just non-responsive when plugging it into the adapter.
After building with the latest codebase, I can report:
>> The latest code works with the WASD v3 (non-CODE) keyboard. <<
In fact, I'm typing on it right now, through the adapter.
Offline hasu
  • @tmk
« Reply #933 on: Mon, 29 December 2025, 19:54:57 »
JimDetroit,
Thank you for your report!
Just updated the list in the first post.
Offline qk6339zmdm
Offline hasu
  • @tmk
« Reply #935 on: Tue, 04 August 2026, 23:22:09 »
Confirmed with USB Sun Type-7 UNIX layout keyboard finally.
The Blank key outputs 0x76 as scan code(HID usage) which is identical to Props key for some reason.
https://github.com/tmk/tmk_keyboard/wiki/Sun-Keyboard-Protocol#usb-hid-usages-for-sun-type-67
Sun Type-6/7 USB keyboards are supported now, including Sun specific functions, volume and sleep keys.
You can use UNIX or  PC layout in TMK Keyboard Editor.
Code: [Select]
