Author Topic: Orion V2  (Read 102315 times)
Offline monotagary
  • Keycaps > Rent
Re: Orion V2
« Reply #100 on: Sun, 15 March 2015, 14:59:21 »
Looks like they will be offering 3 different materials for their plates.
That looks pretty sick. Do acryllic plates and metal plates feel very different?
Different plates accommodate different switch types better. I'm pretty sure STS is great for linears or something like that.
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
Re: Orion V2
« Reply #101 on: Sun, 15 March 2015, 15:01:03 »
Not sure if this has been posted in here yet, but the plates do support ISO
Offline Ngt
Re: Orion V2
« Reply #102 on: Sun, 15 March 2015, 16:13:08 »
STS?
Offline SavvyBird
  • Savvy Caps
Re: Orion V2
« Reply #103 on: Sun, 15 March 2015, 16:21:13 »
hi
Offline Fnzzy
Re: Orion V2
« Reply #104 on: Sun, 15 March 2015, 16:32:49 »
STS?
Stainless Steel, most likely.
I will probably install some blacks if I end up getting an Orion v2. Should I go with a stainless steel plate then? I never had an acryllic plate and they look cool.
Offline azhdar
  • Praise the AZERTY god
Re: Orion V2
« Reply #105 on: Sun, 15 March 2015, 16:35:28 »
STS?
Stainless steel
Azerty Propagandiste
Offline Ngt
Re: Orion V2
« Reply #106 on: Sun, 15 March 2015, 16:57:06 »
STS?
Stainless steel
Cool thanks buddy. Are you going into the korean custom market now? :D
Offline Sygaldry
  • Edema Ruh
Re: Orion V2
« Reply #107 on: Sun, 15 March 2015, 16:59:21 »
STS?
stainless steel i think?
edit: oops someone beat me to it
null
Offline Ngt
Re: Orion V2
« Reply #108 on: Sun, 15 March 2015, 17:05:19 »
STS?
Thanks anyway. ;)
Offline Fnzzy
Re: Orion V2
« Reply #109 on: Sun, 15 March 2015, 17:21:21 »
I hope we can buy multiple plates in the GB. :D
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
Re: Orion V2
« Reply #110 on: Sun, 15 March 2015, 21:13:39 »
What do you want to do?
Offline monotagary
  • Keycaps > Rent
Re: Orion V2
« Reply #111 on: Sun, 15 March 2015, 23:35:01 »
Ah, I'm so excited for this GB. I already got some ALPS boards to salvage for my ALPS PCB and plate... and I'll probably have some leftover Gaterons for the MX PCB and plate.
Offline azhdar
Re: Orion V2
« Reply #112 on: Mon, 16 March 2015, 02:05:05 »
STS?
Stainless steel
well if they start doing ISO, I will :)
Re: Orion V2
« Reply #113 on: Mon, 16 March 2015, 02:09:23 »
ALPS option!? Oh man, temptingggggg!
Offline Ngt
Re: Orion V2
« Reply #114 on: Mon, 16 March 2015, 03:49:54 »
STS?
Stainless steel
Wallet RIP IN PEPERONI.
Offline Fnzzy
Re: Orion V2
« Reply #115 on: Mon, 16 March 2015, 07:34:42 »
Just to see what different plates feel like. And if we get to order additional PCBs as well, then even better, I can solder 2 PCBs with both plates!
Offline elton5354
Re: Orion V2
« Reply #116 on: Mon, 16 March 2015, 08:21:12 »
The plastic plate isn't acrylic. It's a flexible plastic plate. The aluminum plate won't have an  anodized option. You can order extras as long as you order a main set.
Offline slickmamba
Re: Orion V2
« Reply #117 on: Mon, 16 March 2015, 08:31:20 »
Any more estimation/update on time? ty elton! :)
Hi :)
Offline monotagary
  • Keycaps > Rent
Re: Orion V2
« Reply #118 on: Mon, 16 March 2015, 12:24:46 »
Also interested in knowing this! Gotta start getting my funds in order for this one.
Offline Fnzzy
Re: Orion V2
« Reply #119 on: Mon, 16 March 2015, 14:40:18 »
Great news, thanks.
Offline elton5354
Re: Orion V2
« Reply #120 on: Mon, 16 March 2015, 21:25:45 »
It will start at the end of this week probably.
Offline monotagary
  • Keycaps > Rent
Re: Orion V2
« Reply #121 on: Mon, 16 March 2015, 21:52:14 »
Woo! Time to get some money.
  • Frenzy Classic.
Re: Orion V2
« Reply #122 on: Tue, 17 March 2015, 00:07:27 »
Great.
Offline SavvyBird
  • Savvy Caps
Re: Orion V2
« Reply #123 on: Tue, 17 March 2015, 00:07:58 »
all in my last keyboard ;D
hi
Offline elton5354
Re: Orion V2
« Reply #124 on: Tue, 17 March 2015, 08:27:12 »
Pictures of Orion acrylic bottom piece is up!
http://kbdlab.co.kr/index.php?document_srl=2506641&mid=board_Lsno50
http://duck0113.tistory.com/119
I'm probably getting this acrylic bottom set.  :cool:
« Last Edit: Tue, 17 March 2015, 08:32:29 by elton5354 »
Offline slickmamba
Re: Orion V2
« Reply #125 on: Tue, 17 March 2015, 08:33:04 »
Angle on orion is 11deg?  What is the angle on the viper?
Hi :)
Offline monotagary
  • Keycaps > Rent
Re: Orion V2
« Reply #126 on: Tue, 17 March 2015, 08:33:58 »
11 too
Offline elton5354
Re: Orion V2
« Reply #127 on: Tue, 17 March 2015, 08:34:33 »
I believe it's 11 deg on the viper and on the orion v2, but it looks like it's a bit lower with the acrylic bottom.
It is 7 degrees with the acrylic bottom
« Last Edit: Tue, 17 March 2015, 09:18:25 by elton5354 »
Offline monotagary
  • Keycaps > Rent
Re: Orion V2
« Reply #128 on: Tue, 17 March 2015, 08:46:58 »
Oops Reposted
« Last Edit: Tue, 17 March 2015, 09:00:55 by monotagary »
Offline Fnzzy
Re: Orion V2
« Reply #129 on: Tue, 17 March 2015, 10:06:51 »
I am guessing the 7 degree acrylic bottom will not be available in aluminum? The render duck posted a week or so ago showed it with a solid material. Guess I interpreted it wrong then.
  • Frenzy Classic.
Re: Orion V2
« Reply #130 on: Tue, 17 March 2015, 10:26:01 »
+1. This make me discouraged.
Offline jjang023
Re: Orion V2
« Reply #131 on: Tue, 17 March 2015, 10:55:03 »
Orion V2 slope , in the case of aluminum is 11 degrees, 7 degrees in the case of acrylic lower plate .
Acrylic lower plate material , it was produced by using the light diffusion plate .
And of light spread is highly recommend .
It is even more beautiful and actually see .
Offline Ngt
Re: Orion V2
« Reply #132 on: Tue, 17 March 2015, 11:06:01 »
I'm probably getting this acrylic bottom set.  8)
Damn it is so beautiful! According to the link you posted there are 3 choices of bottom case, aren't there? One STS/alu, one with glass and one acrylic?
Offline monotagary
  • Keycaps > Rent
Re: Orion V2
« Reply #133 on: Tue, 17 March 2015, 11:08:54 »
I think the options are:
1. Full aluminium bottom, 11deg angle
2. Frosted acrylic bottom, 7deg angle
3. Transparent acrylic bottom, 0deg angle
Offline zennasyndroxx
  • It's good to be back!
Re: Orion V2
« Reply #134 on: Tue, 17 March 2015, 11:31:30 »
I believe the transparent acrylic piece will include aluminum feets for you to use. around 7 degs IINM.
Offline elton5354
Re: Orion V2
« Reply #135 on: Tue, 17 March 2015, 12:09:40 »
Yeah.
Offline animated
  • uhhhhhhhhhhhhhhhh
Re: Orion V2
« Reply #136 on: Tue, 17 March 2015, 12:20:29 »
I believe someone posted somewhere that they were going to use bumpers from home depot? with the clear acrylic bottom to keep the angle very minimal.  I'm planning to do that also if I can't get use to the feet :thumb:
Das Browns, Filco Reds, Filco Blues, Leopold FC750R Reds, B.87 and B.Pad Gateron Blacks 65G Korean Springs, Varmillo VA87MR Gateron Blacks w/ Aluminum Case
Offline Ngt
Re: Orion V2
« Reply #137 on: Tue, 17 March 2015, 13:16:11 »
Would the price vary depending on the bottom you take or would they all be the same price?
Offline monotagary
  • Keycaps > Rent
Re: Orion V2
« Reply #138 on: Tue, 17 March 2015, 13:17:39 »
Price will vary. Full alu will be the most expensive. Flat acrylic will be the cheapest.
Offline Ngt
Re: Orion V2
« Reply #139 on: Tue, 17 March 2015, 13:47:00 »
I wonder how it would look wiyh the flat acrylic and the bottom led.
Offline monotagary
  • Keycaps > Rent
Re: Orion V2
« Reply #140 on: Tue, 17 March 2015, 14:01:09 »
http://kbdlab.co.kr/index.php?document_srl=2381083&mid=board_Lsno50
That link should show you exactly what you're looking for.
Offline elton5354
Re: Orion V2
« Reply #141 on: Tue, 17 March 2015, 15:29:14 »
To summarize all 3 bottoms:
Aluminum bottom
http://duck0113.tistory.com/117
Acrylic bottom
Flat acrylic bottom
Note that ALPs PCB will be different than MX's.
« Last Edit: Tue, 17 March 2015, 15:32:36 by elton5354 »
Offline monotagary
  • Keycaps > Rent
Re: Orion V2
« Reply #142 on: Tue, 17 March 2015, 15:47:22 »
They all look so good... But I need that full Alu.
Offline radio_killah
  • Chinchillin'
Re: Orion V2
« Reply #143 on: Tue, 17 March 2015, 15:51:40 »
The keyboard itself looks awesome. I am probably going to pass on this though, TKL just doesn't do it for me. Thanks for running this elton!
Offline SavvyBird
  • Savvy Caps
Re: Orion V2
« Reply #144 on: Tue, 17 March 2015, 16:04:39 »
What alu color would go nice with hyper fuse gmk or dolch gmk
hi
Offline monotagary
  • Keycaps > Rent
Re: Orion V2
« Reply #145 on: Tue, 17 March 2015, 16:31:37 »
Silver will look good with Hyperfuse probably, and black would look good with Dolch.
Offline Sygaldry
  • Edema Ruh
Re: Orion V2
« Reply #146 on: Tue, 17 March 2015, 16:50:49 »
damn... if only that 7degree angled bottom was available in alu...  :mad:
null
Offline Ngt
Re: Orion V2
« Reply #147 on: Tue, 17 March 2015, 16:53:43 »
Thank you. It looks cool.
Aluminum bottom
Acrylic bottom
Flat acrylic bottom
Damn they the full ALU or the acrylic bottom are so nice. It is hard to choose. I'm going to regret this one as I don't have money for it ATM. Is it a one time sale or can you order it afterwards if you go through the website you linked?
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
Re: Orion V2
« Reply #148 on: Tue, 17 March 2015, 17:01:23 »
alright. gg.  :p
Offline Lpwl
  • lpwl.bigcartel.com
    • My O-ring Store
Re: Orion V2
« Reply #149 on: Tue, 17 March 2015, 17:04:32 »
Pretty sure, nop.
It's a one time sale (= groupbuy).
