Author Topic: Orion V2  (Read 102316 times)
Offline Flyersfan1
  • Hi!
Re: Orion V2
« Reply #150 on: Tue, 17 March 2015, 17:16:38 »
For those with Duck boards now, is the 11 degree angle comfortable to use? I know it's a preference like all things, I just worry it might be a bit of a shock to me since I'm used to using a much lower angle.
Quote from: Photekq
Offline monotagary
  • Keycaps > Rent
Re: Orion V2
« Reply #151 on: Tue, 17 March 2015, 17:17:08 »
Would the price vary depending on the bottom you take or would they all be the same price?
Price will vary. Full alu will be the most expensive. Flat acrylic will be the cheapest.
I wonder how it would look wiyh the flat acrylic and the bottom led.
http://kbdlab.co.kr/index.php?document_srl=2381083&mid=board_Lsno50
That link should show you exactly what you're looking for.
Thank you. It looks cool.
To summarize all 3 bottoms:
Aluminum bottom
http://duck0113.tistory.com/117
Acrylic bottom
http://duck0113.tistory.com/119
Flat acrylic bottom
Note that ALPs PCB will be different than MX's.
Damn they the full ALU or the acrylic bottom are so nice. It is hard to choose. I'm going to regret this one as I don't have money for it ATM. Is it a one time sale or can you order it afterwards if you go through the website you linked?
I'm pretty sure it's going to be a one time deal, or you'll have to get one aftermarket... and it will hurt your wallet even more.
Offline Ngt
Re: Orion V2
« Reply #152 on: Tue, 17 March 2015, 17:22:07 »
Pretty sure, nop.
It's a one time sale (= groupbuy).
I was not talking about this sale thread but more like in general as I assume we would not be the only one buying it. Especially since it is done towards the Korean community as it seems.
Offline whentheclouds
Re: Orion V2
« Reply #153 on: Tue, 17 March 2015, 17:55:27 »
it's the same process anywere: the creator takes orders for a limited amount of time, then produces as many kits as required. if he makes some extra kits/has leftovers and sell them on his website, you can bet they'll be snapped up within a short period of time.
that's how custom boards retain their exclusivity. not having money is one thing, but delaying a purchase in hopes of it being available after the GB period is generally a bad idea if you really want the product
Offline Fnzzy
Re: Orion V2
« Reply #154 on: Tue, 17 March 2015, 18:16:14 »
My Viper is comfortable to use and I haven't had a problem adjusting to it.
Offline jonathanyu
Re: Orion V2
« Reply #155 on: Tue, 17 March 2015, 18:16:16 »
I have used butterfly keypad from Duck, and it's 11 degree.  I personally prefer 12 degree, but 11 degree is actually pretty good to type on as well.  But it would also depend on what keycaps profile you used on it.
Offline Flyersfan1
  • Hi!
Re: Orion V2
« Reply #156 on: Tue, 17 March 2015, 18:19:19 »
Thanks Jonathan! I was most worried about unneeded wrist extension, but I'm sure I could adjust pretty quickly! :)
Quote from: Photekq
Offline SavvyBird
  • Savvy Caps
Re: Orion V2
« Reply #157 on: Tue, 17 March 2015, 21:50:36 »
What alu color would go nice with hyper fuse gmk or dolch gmk
Silver will look good with Hyperfuse probably, and black would look good with Dolch.
What about the blue grey ?
hi
Offline monotagary
  • Keycaps > Rent
Re: Orion V2
« Reply #158 on: Tue, 17 March 2015, 22:37:48 »
That would actually look pretty good too.
Offline zennasyndroxx
  • It's good to be back!
Re: Orion V2
« Reply #159 on: Tue, 17 March 2015, 22:46:43 »
blue grey with classic beige is alright for me.
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
Re: Orion V2
« Reply #160 on: Tue, 17 March 2015, 23:36:36 »
What color is it availble in group buy? Or like previous GB: Silver, Black, Blue-Grey?
Offline monotagary
  • Keycaps > Rent
Re: Orion V2
« Reply #161 on: Wed, 18 March 2015, 00:12:31 »
Based on the images we've seen so far, silver and blue-grey are confirmed. I personally want blue-grey so that's awesome, but hopefully there will be one or two more color options.
Offline Cottonsox
Re: Orion V2
« Reply #162 on: Wed, 18 March 2015, 00:13:21 »
This is getting harder and harder to resist.
Offline PunksDead
  • hspernks
  • keyboard poser
Re: Orion V2
« Reply #163 on: Wed, 18 March 2015, 00:15:27 »
Ill be your bad influence
Offline Cottonsox
Re: Orion V2
« Reply #164 on: Wed, 18 March 2015, 00:16:53 »
pretty sure i am in, waiting on numbers to determine which base i can afford!
Offline SavvyBird
  • Savvy Caps
Re: Orion V2
« Reply #165 on: Wed, 18 March 2015, 00:26:49 »
Where can I buy the smd leds that are on the pcb.
Also where can I get clear switches?
I'm already planning this out.
hi
Offline Ngt
Re: Orion V2
« Reply #166 on: Wed, 18 March 2015, 03:31:15 »
Thanks for the advice. I was asking because I may not have the cash to buy it atm. I'll just think through and see if I can afford it. :)
  • Frenzy Classic.
Re: Orion V2
« Reply #167 on: Wed, 18 March 2015, 04:31:48 »
Maybe SMD led 'll pre-soldered like previous GB I think.
Offline Ngt
Re: Orion V2
« Reply #168 on: Wed, 18 March 2015, 04:54:43 »
That'd be cool because I heard you have a hard time soldering those.
Edit: forgot to ask. How long will the GB be running?
  • Frenzy Classic.
Re: Orion V2
« Reply #169 on: Wed, 18 March 2015, 04:57:17 »
Only Ellton can anwser this question  :p
  • Frenzy Classic.
Re: Orion V2
« Reply #170 on: Wed, 18 March 2015, 07:44:32 »
Offline ramnes
  • T fou, mec?
Re: Orion V2
« Reply #171 on: Wed, 18 March 2015, 09:18:48 »
Looks neat indeed. ISO support is awesome. Might be my first Korean too! That incline is a bit violent, tho.
Offline SavvyBird
  • Savvy Caps
Re: Orion V2
« Reply #172 on: Wed, 18 March 2015, 15:24:29 »
hi
Offline Ngt
Re: Orion V2
« Reply #173 on: Wed, 18 March 2015, 15:25:59 »
Yeah I was hoping he could answer it. :D
https://youtu.be/XZ5WUSzXYi8
Nice video. You can get a real sense of what it is going to look like.
I'm a bit worried it might be a hard change to get used to. I wonder if the Novatouch has some angle too.
Offline monotagary
  • Keycaps > Rent
Re: Orion V2
« Reply #174 on: Thu, 19 March 2015, 12:41:22 »
I just got my SGI keyboard in the mail to harvest the keycaps and stabs... and I got my Chicony w/ Blue Alps yesterday to harvest switches from.
I wish I didn't have to get a MX kit too. I really just want Alps!  :))
Offline HTN47
  • Mr. SoCal
Re: Orion V2
« Reply #175 on: Thu, 19 March 2015, 16:32:28 »
Hmmm... If  this group buy doesn't offer an option for full assembly I think this will be the first board I will ever try to make   :D
Hopefully I wont mess up  :-X
Anyone have any recommendation for a budget soldering kit?
What is love.... Baby don't hurt me... No more!!
Offline PunksDead
  • hspernks
  • keyboard poser
Re: Orion V2
« Reply #176 on: Thu, 19 March 2015, 16:41:43 »
do these boards normally come with the SMDs + Controllers presoldered?
Offline Eugene
Re: Orion V2
« Reply #177 on: Thu, 19 March 2015, 16:44:22 »
The temp-controlled Hakko or Weller kits are preferred here. Aoyue is a decent budget alternative.
Offline Ngt
Re: Orion V2
« Reply #178 on: Thu, 19 March 2015, 16:45:19 »
Welcome to GH!
Here you would find what you want: https://geekhack.org/index.php?topic=42824.0;topicseen
  • Frenzy Classic.
Re: Orion V2
« Reply #179 on: Thu, 19 March 2015, 20:01:32 »
Maybe. I think so.
Offline Lastpilot
  • Power stance
Re: Orion V2
« Reply #180 on: Thu, 19 March 2015, 20:35:39 »
Yes :]
Offline monotagary
  • Keycaps > Rent
Re: Orion V2
« Reply #181 on: Thu, 19 March 2015, 20:51:35 »
Yes :]
That's good to know. Soldering SMDs is a pain in the ass.  :p
Offline Ngt
Re: Orion V2
« Reply #182 on: Fri, 20 March 2015, 10:07:47 »
Yes :]
I've never done it but that's what I heard so far.
Offline cooldiscretion
  • Convicted guilty of being totally rad.
Re: Orion V2
« Reply #183 on: Fri, 20 March 2015, 10:51:47 »
Yes :]
I agree, but there are definitely so many pro tricks that make it much easier even if you only have a soldering iron.
I had no idea how I was going to solder the tiny diodes on my GON board with only an iron and no flux but it wasn't that hard after I watched a few videos and learned some tricks from youtube.
Without youtube though, it would be super frustrating and might feel like you need a third arm to do the task - one to hold component in place, one to hold iron, and another to feed in solder.
Offline elton5354
Re: Orion V2
« Reply #184 on: Sat, 21 March 2015, 09:24:05 »
How much did you buy your blue alps board for? I can't really find one under $80.
Offline Lastpilot
  • Power stance
Re: Orion V2
« Reply #185 on: Sat, 21 March 2015, 10:05:09 »
- Saw Elton post; thought the GB was coming up.
- Must wait more...
Offline monotagary
  • Keycaps > Rent
Re: Orion V2
« Reply #186 on: Sat, 21 March 2015, 11:50:08 »
I snagged it for $60  :p
Re: Orion V2
« Reply #187 on: Sat, 21 March 2015, 11:51:46 »
How are you guys finding this stuff?  I can't get any luck locating an SGI.
Offline monotagary
  • Keycaps > Rent
Re: Orion V2
« Reply #188 on: Sat, 21 March 2015, 11:54:02 »
I had been hunting for one of eBay for two weeks. It just takes patience... And maybe some luck. Or rather mostly some luck.
Offline SL89
Re: Orion V2
« Reply #189 on: Sat, 21 March 2015, 12:06:26 »
I'm sorry to crash this thread, but you Orion folks are my best hope at getting some information. Namely Full-Size Korean Custom Keyboards I see a lot of action for Orion, Viper, tx1800, lightsaver and etc but besides Gon's work, I've yet to see a really high quality full size. If any of you could point me in the right direction I'd appreciate it.
Offline monotagary
  • Keycaps > Rent
Re: Orion V2
« Reply #190 on: Sat, 21 March 2015, 12:10:58 »
GONs NERD108 is the only full size Korean custom I know about. There are others that have all the functionality of a full size like the Lightsaver and TX1800, but they aren't standard full size boards.
Offline SL89
Re: Orion V2
« Reply #191 on: Sat, 21 March 2015, 12:13:51 »
That was what I thought, but I'm not super well versed in the Korean scene. HQ Fullsize boards are hard to come by and Bespoke ones even more so. Looks like my next buy is a Gon. Thanks!
Re: Orion V2
« Reply #192 on: Sat, 21 March 2015, 12:24:42 »
is bespoke a fancy way of saying custom? anyway, a Korean member here by the name of Kaliet will take orders if you contact him. here's what i could find: http://22kbd.com/163 http://22kbd.com/151
Offline SL89
Re: Orion V2
« Reply #193 on: Sat, 21 March 2015, 12:31:44 »
lol yes it is. I just saw him join DT I'll definitely ask him, thanks!
Re: Orion V2
« Reply #194 on: Sat, 21 March 2015, 12:33:00 »
he's on GH too, same name. but you can just use the email address he listed on the webpage
Offline SL89
Re: Orion V2
« Reply #195 on: Sat, 21 March 2015, 12:33:56 »
Oh i know, I meant I knew the name but never thought to ask.
Offline KnivesM
Re: Orion V2
« Reply #196 on: Sat, 21 March 2015, 17:30:35 »
LifeZone made a full size but I've never seen it besides his site so I doubt you'd be able to find one.
http://lzlife.tistory.com/entry/LZT-1
Others
Offline Dark_wizzie
Re: Orion V2
« Reply #197 on: Sun, 22 March 2015, 02:13:48 »
The keyboard isn't flat though. That's the dealbreaker for me, non-flat Korean keyboards.
Beep Boop
Offline rabidwombat
Re: Orion V2
« Reply #198 on: Sun, 22 March 2015, 02:18:05 »
If you looked through the prototypes and the thread, you will see there are at least 3 different versions..including a flat one with a clear acrylic base.
Offline HTN47
  • Mr. SoCal
Re: Orion V2
« Reply #199 on: Sun, 22 March 2015, 20:43:09 »
I'm dying of anticipation LoL
Ohhh please Korean Gods, let this group buy happen NOW!!  :-X
