Author Topic: Nice coiled USB cords  (Read 6626 times)
Offline TopreFan333
« on: Tue, 24 February 2015, 16:54:15 »
My old Apple Extended Keyboard II has a really great long coiled cord. Would love an equivalent for a USB mini connection. Anybody have any faves?
Offline byker
  • Literally Canada
Re: Nice coiled USB cords
« Reply #1 on: Tue, 24 February 2015, 16:57:10 »
Check out zealpc.net for some very nice coiled usb cables.  :)  I highly recommend his work, love the cables I have from him, and he gets them to you ASAP.
Offline TopreFan333
« Reply #2 on: Tue, 24 February 2015, 17:09:44 »
awesome, thanks!
« Reply #3 on: Tue, 24 February 2015, 20:13:53 »
if you're in the US, support mimic-cables.com
GHer tjcaustin's company. isn't only limited to usb cables either. good dude
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #4 on: Tue, 24 February 2015, 22:43:45 »
+1
Offline DrHubblePhD
  • I am star stuff
« Reply #5 on: Tue, 24 February 2015, 22:47:36 »
+1
-1  :))
just kidding Zealpc is great  :thumb:
Offline tbc
« Reply #6 on: Tue, 24 February 2015, 23:06:17 »
yap
i got like 5-6 cables in colors and designs no one else was stocking...maybe more.
great stuff every time.
Offline munch
« Reply #7 on: Tue, 24 February 2015, 23:06:30 »
+1 on this, his coils look great.
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #8 on: Wed, 25 February 2015, 01:55:40 »
Zeal for Canada, TJ for the USA and Pexon for the UK  :thumb:
« Reply #9 on: Wed, 25 February 2015, 02:18:01 »
got some headphone cables from mimic.  He's always done stellar work.  :thumb:
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #10 on: Wed, 25 February 2015, 02:29:39 »
Zeal all the way, dude does incredible work.
Offline GenKaan
  • Mer caps, mindre käbbel
« Reply #11 on: Thu, 26 February 2015, 07:10:57 »
Got a few Pexon PCs cables, they are great
|| @Home:: Shine 3 TKL (Mx Red / Deep Space)  || @Work:: G2Pro (Mx Clear / Dye Sub PBT) ||
@Reserve:: HHKB (Topre 45g / Mixed PBT) // Das v3 (Mx Brown / Blank PBT)
Offline ideus
  • Björkö.
« Reply #12 on: Thu, 26 February 2015, 07:22:52 »
+1 pexon's are cool.
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #13 on: Fri, 06 March 2015, 18:13:13 »
What does the "Coils are for cosmetic purpose ONLY" (zealpc.net) mean?
Are they not "springy" like coiled cables found ie. on headphones? >.>
A Ghost From The Past
Offline whizzard
  • whizzard got ur gizzard
    • LOOTKEYS BLOG
« Reply #14 on: Fri, 06 March 2015, 19:21:27 »
I have never seen Pexon's cables,  I am sure they are great.  I have been a customer of ZealPC, and he makes really nice cords with many colors and options.. along with being a super nice guy.  So I would check him out for sure.
Offline taylordcraig
« Reply #15 on: Fri, 06 March 2015, 19:50:12 »
Correct, they are still springy, however, just not quite so spring as a factory coil.
Zeal's cables are hand coiled. When a factory coils cables on a product the wire is actually formed in a coiled shape.
Whereas zeal takes straight cable, tightens it around a core, and uses heat to form the wire. [my rough knowledge of the process]
I have two coils that have been in and out of use for about a year, and are currently hanging from a hook on the wall behind my computer,
neither coil I purchased from zeal has lost its shape. The last few coils on one end are a bit looser than the rest;
however, even my strict tastes aren't offended. If you want a coil to sometimes stretch out while you pull your peripheral, zeals coils are fine.
If you want a coil to stretch out for extended periods of use, they'll likely lose their shape quicker than you expected. However, a factory coil, if expanded for hours at a time, will also lose shape.
THESE ARE MY OFFICIAL NOTES ON COILED CABLES.
  • ~ BOOO ~
« Reply #16 on: Fri, 06 March 2015, 20:07:40 »
Thanks for the info!
Now I wonder if the reason for handcoiling is the lack of a good source for coiled wire...
« Reply #17 on: Fri, 06 March 2015, 20:15:52 »
You probably couldn't sleeve coiled wire, even if you could buy it. And you couldn't have any straight ends.
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #18 on: Fri, 06 March 2015, 20:53:53 »
I have a coiled Pexon cable, and the coils are nice, and I have a mimic cable on the way with a coil in it, so I will be able to compare the two. I will have to a Zeal cable next. An excuse to get another board is to test out the zeal cables.
Offline TopreFan333
« Reply #19 on: Sun, 08 March 2015, 12:13:03 »
I care more about the coil really. Don't even really want fancy sleeves. My ideal would be the quality and consistency of a thick glossy old phone handset cable.
  • ~ BOOO ~
« Reply #20 on: Sun, 08 March 2015, 12:28:32 »
+1
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #21 on: Sun, 08 March 2015, 13:05:22 »
I can source something like that if you were ok with black in 5 ft increments.
  • ~ BOOO ~
« Reply #22 on: Sun, 08 March 2015, 13:31:12 »
Yes, please! :)
Offline TopreFan333
« Reply #23 on: Sun, 08 March 2015, 21:50:02 »
sounds interesting! when you say 5 feet, would that be the coiled length?
« Reply #24 on: Sun, 08 March 2015, 22:17:59 »
+1
Sounds like you both want a lindy cable.
http://www.amazon.com/Lindy-Coiled-Cable-Transparent-31925/dp/B003BMS5LK
Offline TopreFan333
« Reply #25 on: Sun, 08 March 2015, 23:36:34 »
looks a little short -- I guess the "2m" is if you stretched it all out?
« Reply #26 on: Sun, 08 March 2015, 23:39:30 »
yup, i own that lindy 2m.. its about a foot coiled, if that.
Offline bueller
  • MX baller
« Reply #27 on: Sun, 08 March 2015, 23:42:53 »
Yep, got one too. Pretty decent little cable for the price.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #28 on: Mon, 09 March 2015, 15:03:44 »
I forgot about lindy, that's a good option, too.
Something like this, I'd be buying pre-coiled raw cable in a specified length and then putting requested ends on it.  From what I can tell from the site I'm getting them from, the length is the extended length, but I can get a 5ft coil, too.  It's just going to be tremendously expensive.
