Author Topic: Mimic-Cables.com February work  (Read 92705 times)
Offline tjcaustin
  • King Klaxon
  • * Moderator
    • Buy stuff
« on: Sun, 01 March 2015, 22:21:21 »
I think we'll dump this here.  Tell me if I should start doing a daily/weekly photo drop instead in the comments:
Looks like there's around 170 cables that I finished this month
https://flic.kr/s/aHsk8iM21D
Re: Mimic-Cables.com February work
« Reply #1 on: Sun, 01 March 2015, 22:23:13 »
Can I dump here too?
Offline tjcaustin
  • King Klaxon
  • * Moderator
    • Buy stuff
« Reply #2 on: Sun, 01 March 2015, 22:24:26 »
Only pictures of my cables you purchased with your shark church tithes.
« Reply #3 on: Sun, 01 March 2015, 22:26:29 »
I bought a cable from TJ once, I still use it.
Offline cwndrws
« Reply #4 on: Sun, 01 March 2015, 22:40:00 »
How do you do your coils? I've tried my wife's hair dryer without much luck. Also do you sleeve them before or after coiling?
Offline tjcaustin
  • King Klaxon
  • * Moderator
    • Buy stuff
« Reply #5 on: Sun, 01 March 2015, 22:49:56 »
Make the cable like normal, so sleeve and terminate, then I wrap it around a wood dowel, cover in two layers of painters tape and then use a heat gun until the outer layer has a brown to black heat scorch on it.
Offline cwndrws
« Reply #6 on: Sun, 01 March 2015, 23:05:37 »
Do you reverse-coil them afterwards? Or are they tight enough after the heat?
Offline tjcaustin
  • King Klaxon
  • * Moderator
    • Buy stuff
« Reply #7 on: Sun, 01 March 2015, 23:24:48 »
They're normally tight enough, but they don't have much memory to them.  I haven't tried reverse coiling, though.
Offline wholphin
« Reply #8 on: Mon, 02 March 2015, 01:50:54 »
Love the SDL to PS/2 cable. How much would one set me back with international shipping?
Ducky Shine 3 TKL (Browns) | Ducky Shine 3 Tuhaojin (Browns) | Poker II (Blues) | Model M, bolt modded x2 (03 Jan '90, 18 Jan '90) | Leopold FC660M (Ergo Clears) w/ aluminium case | HHKB Pro 2 | Model M SSK (04 Dec '91) w/ PhosphorGlow's replacement controller | Leopold FC660C | Realforce 104U | Realforce 23UB
Offline tjcaustin
  • King Klaxon
  • * Moderator
    • Buy stuff
« Reply #9 on: Mon, 02 March 2015, 03:22:36 »
$50
Offline yomammary
« Reply #10 on: Mon, 02 March 2015, 07:25:35 »
Yes you should!
RF 87u 55g | Leeku 1800
« Reply #11 on: Mon, 02 March 2015, 07:27:29 »
A weekly photo dump would be cool :)
