Author Topic: Which Number Pad for MX/Kailh do You Use?  (Read 2525 times)
Offline morpheus
« on: Tue, 03 March 2015, 01:43:26 »
For all you out there who use a separate number pad, which one did you choose, and why is it the best in your opinion?
Also, can you get one for under $40?
Thanks.
Offline Chromako
  • Worshipper of the Topre and IBM Gods
Re: Which Number Pad for MX/Kailh do You Use?
« Reply #1 on: Tue, 03 March 2015, 02:03:08 »
If you want something for cheap, you can get the Adesso AKP-220B, which is what I use. It's reasonably well constructed and has real Cherry (not Kailh!) Blue switches (PCB mount, I think- you're unlikely to find a plate-mount keypad for less than $40 new). My only complaint is that it's a bit light so it likes to slide around your desk unless you put sticky rubber feet on it. It does have plebeian ABS keycaps (the horror!), but what did you expect for $30?
Another nice thing is that the Adesso DOES send actual numeric keypad scancodes, unlike the more expensive Leopold FC210TP which does NOT. *facepalm* (But the FC210TTP does have fancy bourgeois PBT keycaps.)
If you want the best of the best, take a look at the Topre Realforce 23U, or maybe a Gonpad. Then take a look at the eyewatering price. You know you want one.
« Last Edit: Tue, 03 March 2015, 02:17:10 by Chromako »
Thou Shalt Not Violate Causality, Nor Shalt Thou Invert Thy Spacebar.
Offline Novus
  • Formerly the1onewolf
  • Mondai nothing~
« Reply #2 on: Tue, 03 March 2015, 03:21:30 »
Keycool 22
Offline Defect
« Reply #3 on: Tue, 03 March 2015, 09:44:04 »
There were some on eBay with MX blacks that were like 12 bucks each. Bought three and never used them.
Offline Dee1
« Reply #4 on: Tue, 03 March 2015, 12:03:50 »
I mainly use a realforce 23U. The reason I use it because it works and it feels nice.
I also have a keycool one. I keep it plugged in and actually use it more for its USB ports than to type on. :P I do actually like it more than I thought I would. I use the fn combos on it a lot.
« Last Edit: Tue, 03 March 2015, 12:05:55 by Dee1 »
« Reply #5 on: Tue, 03 March 2015, 12:37:19 »
<--  Qazpad :)
Offline Jotokun
« Reply #6 on: Tue, 03 March 2015, 12:50:36 »
I use a Kinesis number pad with Browns I found on ebay for $30 new in box. I don't know that I would call it the best, but it uses plate mounted switches, has a USB hub and sends number pad scancodes. Stock caps are pad printed ABS, but that's easily fixed. Of the commercially available options, it seems really good for the price.
The only real flaw I could say about it, it maintains its own numlock state so numlock itself doesn't send a scancode. I don't find it a problem, but I could see that being a deal breaker for some.
« Last Edit: Tue, 03 March 2015, 12:52:18 by Jotokun »
85 IBM Model F "120" ANSI-Modded | 86 IBM Model M | Cherry G84-4100 | TG3 Data911 (MX Blacks) | 90 Apple Extended II (Linear modded Cream ALPS) | 95 Apple Extended II (Dampened White ALPS)
Offline Data
« Reply #7 on: Tue, 03 March 2015, 13:07:10 »
Leopold 210TP with those absurd clicky Blue MX.  I put the Midnight set on it.
Offline saturnotaku
« Reply #8 on: Tue, 03 March 2015, 13:17:27 »
I have a Genovation 630 with MX blacks at work and a DSI with browns and blank PBT caps at home.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #9 on: Tue, 03 March 2015, 17:21:56 »
I use an old Cherry numpad w/ mx blacks that I found on ebay for $35
Offline spoonypirate
« Reply #10 on: Fri, 06 March 2015, 23:01:04 »
I use a Genovation 622 that I saved from my workplace.
« Reply #11 on: Sat, 07 March 2015, 00:18:12 »
Leopold fc210 clears lubed!
« Reply #12 on: Sat, 07 March 2015, 00:23:20 »
The one attached to my full size keyboards? Ba dum tiss.
But actually, a Goldtouch GTC-0077.
Offline slickmamba
« Reply #13 on: Sat, 07 March 2015, 00:51:56 »
a GHpad ;)
Hi :)
