Author Topic: What's Your Preferred Keyboard Cable Length?  (Read 16982 times)
Offline Karura
  • Professional Canadian
  • SKidata life.
« on: Tue, 03 March 2015, 23:17:46 »
Was just curious as to how long people prefer their cable lengths to me.
Please reply in the following format for clarity:
1) Length: 6ft
2) Reason: It's the stock cable length of keyboards
or
1) Length: 10ft
2) Reason: Mah computer is too far away.
Let's hear it  :thumb:
Re: What's Your Preferred Keyboard Cable Length?
« Reply #1 on: Tue, 03 March 2015, 23:32:03 »
3.50
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #2 on: Wed, 04 March 2015, 00:13:45 »
Nothing less than 6 feet.  Anything less and I have to start unplugging it just to take the side panel off due to how it is positioned and how I route my cables.
« Reply #3 on: Wed, 04 March 2015, 00:18:43 »
I have a hub and travel with my keyboards to events n **** a lot. I really need to invest in shorter cables, later. For keyboard I just have 6ft cuz that's the maximum length before tj charges me more money and I'm a cheap Chinaman. Kindly refer to demik and his signature if you're American.
« Reply #4 on: Wed, 04 March 2015, 07:44:04 »
Pretty much this.
I have a large desk with the keyboard in the middle, at the front, and the computer sits on the floor off to the side, toward the back.
Since I use ancient IBM iron with a Soarer's/Teensy, that run can be broken in half with one piece going from the Teensy to the USB port, and with the Teensy sitting on the desk the keyboard cable itself can be short.
That said, whenever I build a Soarer's/Teensy I use pull-up resistors as a matter of course, and 10 foot USB cable "just in case"
- D Trump 2026-10-24
Offline epzy
  • HHKB Fiend
  • ded
« Reply #5 on: Wed, 04 March 2015, 07:45:00 »
4 ft is perfect for me
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #6 on: Wed, 04 March 2015, 08:12:02 »
I love coiled cable, so I don't care length  :))
Offline Huxley2500
« Reply #7 on: Wed, 04 March 2015, 11:31:22 »
6 ft.
« Reply #8 on: Wed, 04 March 2015, 11:33:03 »
Preferably wireless but that doesn't happen much.
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #9 on: Wed, 04 March 2015, 12:00:23 »
Depends.
My one I have at work is only 2ft long because my desk and thin client (shudder) are close together.
But my preferred cable length at home is somewhere around 6ft
Offline sirisaac1982
  • The Answer is 42...
« Reply #10 on: Wed, 04 March 2015, 12:10:42 »
I like my peripheral cables as long as possible. It gives me more options for desk layout. You can always wire tie the excess.
Offline Melvang
« Reply #11 on: Wed, 04 March 2015, 12:24:16 »
Pretty much this.
I use a 10 foot cable in my XT with soarer, no problems and I don't have a pull up resistor
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #12 on: Wed, 04 March 2015, 16:23:59 »
6ft, but with a little bit of coil on the end. Partially an aesthetic thing, it's also nice to have a little extra stretch to it
Offline exitfire401
  • The Force is Re/\l
« Reply #13 on: Wed, 04 March 2015, 16:25:57 »
6 feet on my desktop
mainly because it's the default length.
3 feet or less on my laptop.
If I'm using my laptop, my board is usually never more than a foot and a half away from the computer.
Offline 0100010
  • Not Sure
« Reply #14 on: Wed, 04 March 2015, 18:08:47 »
10'
6' is to short usually and it is no issue coiling up a little extra under the desk.
Offline tbc
« Reply #15 on: Wed, 04 March 2015, 18:20:16 »
Length:  8" [to my usb hub]
Reason: I don't game so I just connect all my peripherals to a USB hub so I only have a single cable running to the computer.  my sum total length of cables is reduced this way.
Offline reaxas
« Reply #16 on: Wed, 04 March 2015, 21:38:12 »
6ft because then I incorporate it into my cable management system, and also because it's the default length! :P
« Reply #17 on: Wed, 04 March 2015, 21:38:47 »
WHATEVER MIMIC-CABLES.COM SELLS. CABLES FRESH AS ****
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #18 on: Thu, 05 March 2015, 05:12:05 »
Coiled, so any length. My work computer is only half a metre (2 feet in weird units) away, but my home one is more like three (9 feet).
Offline KHAANNN
« Reply #19 on: Thu, 05 March 2015, 09:58:39 »
Width is also very important
I just made a custom paracord sleeved usb cable, it was such a bust
« Reply #20 on: Thu, 05 March 2015, 10:00:08 »
6ft because my computer is pretty far from my desk's keyboard tray.
Offline Karura
  • SKidata life.
« Reply #21 on: Fri, 06 March 2015, 01:52:46 »
I like this idea. Perhaps it would be best to have two cables, one 10ft for longer reaching (such as using it in the living room + TV rig), and a short one 3ft for laptop/tablet usage!
