Author Topic: Where to buy MX Clears  (Read 2373 times)
Offline smoseph
« on: Thu, 05 March 2015, 20:07:36 »
I was looking at getting a QFR and replacing the switches with ergo clears, but I'm having trouble finding where to buy 87 clear switches. Any tips?
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
Re: Where to buy MX Clears
« Reply #1 on: Thu, 05 March 2015, 20:08:34 »
mechanicalkeyboards.com might have some in stock.
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #2 on: Thu, 05 March 2015, 20:08:37 »
Mechanicalkeyboards.com should have heaps in stock.
Offline smoseph
« Reply #3 on: Thu, 05 March 2015, 20:09:58 »
I just checked mechanicalkeyboards.com and it says that they're out of stock unless you buy them in sets of 5, which gets kinda pricy.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #4 on: Thu, 05 March 2015, 20:11:35 »
Both plate and pcb mount?
Offline smoseph
« Reply #5 on: Thu, 05 March 2015, 20:13:47 »
Yeah I just checked again, the sets of five are PCB mount but everything else is out of stock
Also would I need pcb or plate mounted switches for a QFR?
Offline VinnyCordeiro
« Reply #6 on: Thu, 05 March 2015, 20:39:24 »
You can try Mouser or Digikey. It's going to be expensive, be warned.
Offline exitfire401
  • The Force is Re/\l
« Reply #7 on: Thu, 05 March 2015, 20:42:27 »
****...I needed to order clears too...
Offline smoseph
« Reply #8 on: Thu, 05 March 2015, 20:45:01 »
Hm those are a lot pricier. Does anyone have any estimates as to how often mechanicalkeyboards.com restocks typically?
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #9 on: Thu, 05 March 2015, 20:46:28 »
Offline smoseph
« Reply #10 on: Thu, 05 March 2015, 21:49:21 »
WASD has them in stock at a better price than any of the other links. mechanicalkeyboards.com would still be cheaper though, so I contacted them asking when they plan on restocking.
http://www.wasdkeyboards.com/index.php/products/keyboard-parts/cherry-mx-clear-keyswitch-mx1a-c1nn-tactile-bump.html
« Reply #11 on: Thu, 05 March 2015, 22:11:29 »
If you are doing ergo clears just buy tactile grays since your swapping springs anyway.
Offline Oobly
« Reply #12 on: Fri, 06 March 2015, 01:53:10 »
I think 7bit sells them, too.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
