Author Topic: Switch ID help  (Read 2671 times)
Offline heedpantsnow
  • Old enough to know better
Switch ID help
« on: Fri, 06 March 2015, 21:19:54 »
Anyone know what type of switch this is? It's from an Acer Future keyboard but doesn't feel like typical rubber domes. Any ideas?
I'm back.
Re: Switch ID help
« Reply #1 on: Fri, 06 March 2015, 21:22:01 »
Alps mount slider over rubber dome.
Re: Switch ID help
« Reply #2 on: Fri, 06 March 2015, 21:31:09 »
Thanks, nubs. Are they crappy?  I'm embarrassed to say they seem kindof okay.
I'm back.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: Switch ID help
« Reply #3 on: Fri, 06 March 2015, 21:36:42 »
I mean, I guess ever just so slightly because the keypresses have a little less wobble. Still not good though.
Re: Switch ID help
« Reply #4 on: Fri, 06 March 2015, 21:50:39 »
Ok thanks guys.
I'm back.
Re: Switch ID help
« Reply #5 on: Fri, 06 March 2015, 22:00:54 »
Better than membrane, worse than Topre.  So they're not utter ****e, but they're not great either.
Offline Touch_It
Re: Switch ID help
« Reply #6 on: Fri, 06 March 2015, 22:03:41 »
Already explained by above posters but hey if it feels good to you then that's great. Some rubber domes don't feel that bad.
Re: Switch ID help
« Reply #7 on: Fri, 06 March 2015, 22:11:08 »
With a little lube, time, and getting used to, many things you wouldn't expect to feel good start to feel good.
I should stop posting.
Offline Touch_It
Re: Switch ID help
« Reply #8 on: Fri, 06 March 2015, 22:16:29 »
I'm going to play dumb.  Please explain further.
On a naughty note my guilty pleasure is I find the silver and black hp business keyboards pretty good to type on.
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
Re: Switch ID help
« Reply #9 on: Sat, 07 March 2015, 06:37:26 »
What makes you think that they don't use a membrane? Dome over PCB is comparatively rare.
Bore Awards
Re: Switch ID help
« Reply #10 on: Sat, 07 March 2015, 15:09:16 »
I was meaning better feeling than the straight ultra crappy membrane boards you get that feel like mush.  I phrased it poorly.
