Author Topic: Nonstandard mappings  (Read 1505 times)
Offline blastoid
« on: Mon, 09 March 2015, 12:26:00 »
Sorry in advance if I'm making the noob mistake of posting in the wrong place.
I'm curious about what nonstandard mappings people use for various keys.
About a year ago, I experimented with mapping Caps to Backspace, but I guess I'm a mistake-prone typist, because after a few days of that, my left pinkie was seriously achy. So I switched to the more standard mapping Caps to Ctrl, and I really love that one and have changed all my keyboards.
This past week, I added two more, swapping Esc and `/~, and Backspace and \/|. Which means that for now, I keep hitting backslash instead of backspace, but I'll get used to it. I'm also a heavy Vim user, so having Esc more reachable should be nice.
Also, IIRC, Ecs and Backspace are in those positions on everyone's favorite HHKB.
I don't think I ever hit my right mods, does anyone map out any of those keys? I currently have RAlt mapped to Win on my M, but that's just so that I can actually have a Win key.
Any other good mappings?
Offline a_ak57
Re: Nonstandard mappings
« Reply #1 on: Mon, 09 March 2015, 12:30:29 »
Since I went back to my HHKB at home, I mapped the realforce I use at work to switch backspace/backslash and control/caps.
Offline Ludovician
« Reply #2 on: Mon, 09 March 2015, 12:49:37 »
I have also done this with my realforce.
Typing speed:
My collection:
HHKB Pro 2 (Blank, white) | HHKB Pro 2 Type-S (Blank, white) | Topre Realforce 87UB silent-modded (not currently functional) | Das Keyboard Model S Professional Silent (MX Brown) | IBM Model M 1391401 - 9th January 1991 (Bolt+Floss-modded) | Apple keyboard m0116 (Orange Alps) | Unidentified DIN Keyboard (White Alps) | ADDS 1010 (Green Alps) | AEK II (Linear-modded, USB-converted) | IBM PC-AT Model F | Noppoo Choc Mini (MX Black) | Amstrad PC2286 | BigKeys LX | IBM Model M 1391401 - 6th September 1990 | IBM Model M2 1395300 - 28th February 1991 | Leopold FC660C | Cherry G80-11802 (MX Brown) | Matias Tactile Pro (Simplfied grey Alps) | Razer Blackwidow (MX Blue) | Novatouch 55g | Focus FK-2001 (White alps) | DSE Multitech (Blue alps) | Dell AT101W (Matias quiet) | Pok3r (White w/Clears) | KBP V80 (Blue Alps)
Pending:
Infinity kit
Offline jacobolus
« Reply #3 on: Tue, 10 March 2015, 00:07:13 »
This is on a Model M, you said?
I personally am a big fan of a split spacebar with space on the left thumb and backwards delete on the right thumb. But that obviously doesn’t help you if you have a keyboard without a split spacebar. :-)
Another thing I’m a big fan of is putting the numbers on a layer, something along the lines of
After that it’s possible to use the original number keys for something else.
« Last Edit: Tue, 10 March 2015, 00:15:49 by jacobolus »
Offline derezzed
« Reply #4 on: Tue, 10 March 2015, 00:25:29 »
Full sized space bar is the biggest waste of space on a keyboard.  Caps lock is the second biggest waste of space.
I swapped left control and caps lock.  I have a split space bar, which is absolutely awesome.  I use Autohotkeys to make shift + backspace function as delete.  And recently, I supplemented that with TouchCursor to make space + number keys into function keys, and use the standard TouchCursor navigation cluster around the ijkl keys.  It's what convinced me to convert to a 60% keyboard.  I also dabbled with using the the menu key + e and menu key + b as shift + end and shift + home, respectively.
Offline blastoid
« Reply #5 on: Wed, 11 March 2015, 11:56:28 »
One thing I'm noticing is that since switching backslash and backspace (ANSI), I often accidentally send messages I'm trying to correct (hitting enter instead of the key labeled backslash). Also noticed some mild pain in my right arm.
Hopefully this is just growing pains.
