Author Topic: pay someone to replace one switch, or buy soldering gear?  (Read 12560 times)
Offline zombimuncha
« on: Wed, 18 March 2015, 13:58:24 »
I've managed to break one of the switches in my Matias Quiet Pro. Contact leaf is all munged up.
http://imgur.com/sPD7T7R
(btw, how do I get the img tag to work?)(edit: NVM, I got it.)
I tried bending it back into shape but failed.
When I plug the keyboard in, it's like someone is holding that key (numpad 6) down. It repeats forever even if I dont' touch it. Then after I press some other key, the 6 stops repeating and the keyboard mostly behaves as normal, except that the numpad 6 doesn't work. So I assume it's ONLY the switch that is toasted and I just need to replace it
So I got a new switch to replace it with. I got a few spares actually, (including a couple of clicky switches incidentally, which I'm surprised how much I like - I think I need to get a keyboard with these!)
The problem is I don't have any soldering equipment, and haven't done any soldering for about 30 years, so I would need to buy all the kit, and find some junk circuit boards to practice on, the whole 9 yards. This would probably pay off eventually, as I'm moderately interested in building as custom keyboard or two in the (distant) future. But I currently don't even have a space in which to set up a soldering station, other than my desk at work, after hours. No space for it at home :(
I guess it mainly comes down to money.
How much should I expect to pay to get someone to replace 1 switch for me, (located in London, if it makes any difference), and how would I go about finding someone to do it?
And how much would a halfway decent soldering setup cost?
thanks for any advice you can give!
« Last Edit: Wed, 18 March 2015, 14:01:44 by zombimuncha »
Offline ghostjuggernaut
Re: pay someone to replace one switch, or buy soldering gear?
« Reply #1 on: Wed, 18 March 2015, 14:00:46 »
Edit: nvm Tapatalk isnt working for me.
« Last Edit: Wed, 18 March 2015, 14:02:56 by ghostjuggernaut »
« Reply #2 on: Wed, 18 March 2015, 14:04:43 »
It depends on if you plan on soldering in the future.  Think of it this way, cost of shipping will be $30+, plus materials cost, plus labor.  That's $50-60.  I picked up a solid soldering iron for $70, plus solder for $10, plus a solder sucker for $15.  So you can get a decent setup for $100 or so or you can pay $60+ for the work.  I prefer the DIY option, but it's not for everyone.
You might be able to fix it without doing either though.  You should be able to pop the affected leaf off the contact and drop on another from a new switch.  You can also do a whole switch top swap.  If that works, you saved even more money.
Offline zombimuncha
« Reply #3 on: Wed, 18 March 2015, 14:27:34 »
Thanks for the numbers!
I'm actually thinking maybe one of those local phone/laptop repair places (the ones that also sell a lot of cheap iphone cases, and USB cords) might be able to do it for fairly cheap, but no idea really if they would even be able to. But that would at least save on shipping. The MQP is pretty heavy!
AFAICT on Matias switches the contact leaf and the "legs" are the same 2 bits of metal, and are soldered directly to the PCB, so I don't see how I could swap the contact leaf without desoldering. I'll be happy to be proven wrong tho. Got a walkthru / guide / photos?
Offline exitfire401
  • The Force is Re/\l
« Reply #4 on: Wed, 18 March 2015, 14:32:48 »
This is correct. On normal alps switches, the click leaf is another piece altogether. Personally, I would suggest just purchasing soldering equipment. Decent equipment can be had for $70-$90 and it's an immensely helpful skill. Prior to taking an iron to your board though, I'd suggest getting a techkeys card and using that for soldering practice.
Offline Huxley2500
« Reply #5 on: Wed, 18 March 2015, 14:36:46 »
Buy one.  Essential life skill.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #6 on: Wed, 18 March 2015, 14:37:35 »
Option three. Borrow one from a friend. Problem solved ;) .
Offline zeroni13
« Reply #7 on: Wed, 18 March 2015, 14:44:38 »
I would swap it for free if you would ship it over here, but soldering isn't that hard and if it is your first time you solder I would recommend looking up some guides on the internet or something.
Phantom with Silver Vortex Case   Keychron Q6 Pro ISO Knob
Offline Tactile
« Reply #8 on: Wed, 18 March 2015, 15:07:51 »
I'm not a brit, so I'll just use the American terms...
I'd suggest going to a local community college or even a local high school & asking the electronics class to solder it for you. I'm sure they'd have an interest in the keyboard & would probably be delighted to help you out.
REΛLFORCE
Offline FrostyToast
  • Litshoard
« Reply #9 on: Wed, 18 March 2015, 15:10:11 »
Are you not planning on putting together boards in the future?
If you aren't then there isn't much stopping you from going to a friend's house to use their gear.
Quote from: elton5354
Offline Defect
« Reply #10 on: Wed, 18 March 2015, 15:13:07 »
My vote is for soldering yourself (practice first!)
You can always sell used soldering iron, and shipping would be cheaper than mailing a keyboard back and forth
BTW
I would be willing to fix it for you if you cover the cost of switches + shipping (both ways).
Good luck.
Offline zombimuncha
« Reply #11 on: Wed, 18 March 2015, 15:30:38 »
AFAIK I don't know anybody here in the UK who owns a soldering iron. I have a friend in Australia who probably has one but that's not much use to me here.
Is anyone on here in London (or short train ride from) and could let me use theirs?
Offline KHAANNN
« Reply #12 on: Wed, 18 March 2015, 15:48:08 »
Soldering is very very very very very simple, consider learning it yourself, buy the cheapest soldering set you can find, you might even be able to find a $30 set with a variable temperature soldering stand, desoldering pump, solder, soldering tools, I have one, I also bought more decent versions lately, yet It's good to have the old set too as a fallback set
It's like you are looking to dig a small hole in your garden to put a sapling in, and considering whether you should find a local gardener, or import a gardener
Just buy a $5 shovel and do it yourself
You could even use a lighter to melt the solder, remove the switch, put a new one, and re-heat the soldering point, if you have mcgywer genes or sth
It's really a very simple thing to do, hard to mess up
Test it on an unused toy or something, you will see how simple it is
I write this as a motivational post, hope you get motivated
Offline DrHubblePhD
  • I am star stuff
« Reply #13 on: Wed, 18 March 2015, 15:52:34 »
Its never to early do invest in a soldering iron! That said if you are really prohibited by cost there are plenty of people who would be willing to swap out a single switch for you without charge.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #14 on: Wed, 18 March 2015, 16:01:51 »
Talk to margo or pexon?
Offline zombimuncha
« Reply #15 on: Wed, 18 March 2015, 17:33:10 »
Oh, it just occurred to me that I could ask the IT guys at work. I'm sure we don't have soldering kit at work, but they might have their personal one that they could bring in. Call that Plan A.
Plan B will be to inquire at some of the high street laptop repair type places.
Plan C = buy soldering iron etc.
Thanks for all the help, guys!
Offline random_rockets
« Reply #16 on: Wed, 18 March 2015, 19:45:44 »
For PCB desoldering for a novice is wick or pump better?
Offline KHAANNN
« Reply #17 on: Wed, 18 March 2015, 19:57:58 »
pump for everyone
Offline jacobolus
« Reply #18 on: Wed, 18 March 2015, 20:07:34 »
Get a Soldapullt. Many of the other solder suckers are terrible.
Offline fknraiden
« Reply #19 on: Wed, 18 March 2015, 20:08:00 »
it'd probably be best to get your own equipment and DIY, but if you end up sending it to someone i'd do it for free, it just would be a decent amount of shipping to US.
« Reply #20 on: Thu, 19 March 2015, 04:52:42 »
+1
Not worth learning to solder on your one and only valuable keyboard.
margo baggins
Pexon PCs
Offline Bucake
« Reply #21 on: Thu, 19 March 2015, 05:40:23 »
any suggestions for soldering equipment for up to $300?
right now there are no plans to solder anything but keyboards..
i prefer good quality and useful options, over a cheap price :)
Offline Fire Brand
  • Keeper of Rainbows
  • BISCUITS!
« Reply #22 on: Thu, 19 March 2015, 05:56:48 »
Just my thoughts I personally do my own soldering I would say do it your self but like others said margin or pexon might be something good option as for irons honestly I use a Weller BP860 battery powered iron which is pretty awesome and cost around £25 just finished replacing a poker switches with it might be worth looking at :)
My Youtube Channel ~
Keyboards owned
My classified thread :3
Offline jamster
« Reply #23 on: Thu, 19 March 2015, 06:05:54 »
This thread is great:
https://geekhack.org/index.php?topic=42824.0
Offline Bucake
« Reply #24 on: Thu, 19 March 2015, 06:37:14 »
thanks alot jamster, that Edsyn 951SX looks great
Offline antCB
« Reply #25 on: Thu, 19 March 2015, 10:52:52 »
i also busted a switch on my keyboard last year (cherry mx), and went ahead and DYI'd with it, no point in paying someone for something so easy to do (with cherry mx it is fairly easy tbh). and, even if i'm not the greatest one handling the soldering iron, I did a pretty good job with it :D
Steelseries 6GV2 ISO-PT with Gateron Blues.
Offline zombimuncha
« Reply #26 on: Sun, 29 March 2015, 11:55:16 »
Since it's just for the one switch (for now), is there any reason not to get something super cheap n (presumably) nasty, like this:
http://www.amazon.co.uk/CostMad-Soldering-Starter-Station-Desoldering/dp/B004MZYQZ4/ref=sr_1_1?ie=UTF8&qid=1427648079&sr=8-1&keywords=soldering
Offline KHAANNN
« Reply #27 on: Sun, 29 March 2015, 12:15:20 »
You still haven't fixed your board? omg :)
That one looks good actually, 4.2/5 is pretty good, it should serve you well
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #28 on: Sun, 29 March 2015, 13:14:09 »
If you're only ever going to do the one job?  Or a smaller than hobbiest amount of odds/ends?  I dunno if I'd spend the money on tools, you know.
Offline zombimuncha
« Reply #29 on: Sun, 29 March 2015, 13:22:59 »
I waited a while for a response from the contracted contingent of the IT dept, who aren't in the office every week. In the meantime I've been enjoying the MX Clears and compact layout of my FC660m.
Well.... I might be up for building my own board at some point in the distant future. Don't really know yet. For now, this seems like the only sensible option for fixing the QuietPro. Cheaper than shipping it anywhere. Probably easier than shipping too  :thumb:
« Last Edit: Sun, 29 March 2015, 13:27:48 by zombimuncha »
Offline zombimuncha
« Reply #30 on: Sun, 29 March 2015, 13:26:05 »
oops! double post. Sorry. Mods please feel free to delete.
« Last Edit: Sun, 29 March 2015, 13:28:36 by zombimuncha »
Offline livingspeedbump
    • KeyChatter
« Reply #31 on: Mon, 30 March 2015, 17:50:34 »
Honestly, some basic electronics equipment like soldering gear is good to have around. Even without any electronics knowledge you'd be surprised how much you can do and fix on your own with it. On the side, its a very addicting hobby, and with all these keyboard kits around you could easily save some money by building your next keyboard instead of buying a completed one.
<- My Collection (so far)
Offline zombimuncha
« Reply #32 on: Tue, 31 March 2015, 15:31:30 »
the question now is "how basic is too basic?"
If I get that £10 set will I end up cursing the gods or burning my house down if I ever get around to building my own lightsaber keyboard? From what I've read, it seems like the fancy variable temp irons are mainly useful for more complicated tasks than a simple handwired, or thru-pcb keyboard.
Are there quirks or gotchas common to cheap-ass soldering irons that I might find annoying?
Offline heedpantsnow
  • Old enough to know better
« Reply #33 on: Tue, 31 March 2015, 20:10:33 »
I've been using a cheap soldering iron for years. The noname ones with the little dial. I've always felt soldering was really hard and error-prone, and tried to do it as little as possible.
Recently I bought a Hakko. 888d I think. Now soldering is easy and relaxing. Not stressful like before.
I know it sounds like hype but that's my experience. The hakko's tips are better quality and transfer heat better and more precisely. The temp has much better control, so no more lifted pads or waiting for forever for solder to melt. And you can do one joint one right after another. Not so with the cheaper ones.
So I know before when people said stuff like this I thought "what a solder geek" and "mine works just fine" but now I know the difference and I won't go back. $90 is not that much for a quality tool.
I'm back.
Offline bcredbottle
« Reply #34 on: Wed, 22 April 2015, 16:35:39 »
« Last Edit: Wed, 06 October 2021, 13:55:40 by bcredbottle »
Offline Skechup
« Reply #35 on: Wed, 22 April 2015, 17:45:26 »
I recommend that you should just get a soldering iron.
A tip for you would be to keep cleaning the tip of the soldering iron with a rough cloth or something to clean the oxide layer which forms on the soldering iron. If you don't clean the soldering iron tip, the transfer will become less efficient and really messes up the soldering iron. I also recommend that you get a good solder and considering that this is an electrical sort of job, I recommend that you get flux-core solder which reduces metal oxides forming (meaning more electrical conductivity). You can get a good flux-core solder for around £2 (http://www.banggood.com/HX-T100-0_5mm-6337-Tin-Lead-Rosin-Core-Solder-Soldering-Wire-Reel-p-949337.html)
Offline smknjoe
« Reply #36 on: Wed, 22 April 2015, 18:07:12 »
Did you ever get this fixed? If not, any laptop repair shop that can replace a broken "charging plug/jack" on a laptop should be able to take care of it for you. It should be around $65-$85 for a one hour minimum charge if you were in a major US city. Good luck!
Cool avatar. What is it exactly?
SSKs for everyone!
Offline zombimuncha
« Reply #37 on: Thu, 23 April 2015, 06:40:50 »
Not yet. A colleague said he'd let me borrow his soldering gear, but he didn't bring it in to the office yet. I'm in no hurry, but I might pick up this instead of waiting. I asked a couple of laptop repair places but they weren't interested.
Offline Skechup
« Reply #38 on: Thu, 23 April 2015, 14:13:37 »
Mmm, that soldering iron seems solid.
Just remember to be SUPER careful when repairing. Never trust a cheap soldering iron  :p
Offline zombimuncha
« Reply #39 on: Mon, 01 June 2015, 15:16:55 »
HOLY **** I FIXED IT!!!!!!
I almost failed. I realized halfway thru that if I wanted to take the whole switch out I would need to first desolder all of the switches, and I had really only psyched myself up for desoldering one of them. So I left the switch base in there and desoldered the contact leaves, which were the root of the problem anyway, and soldered in the contact leaves from a fresh switch. That took some finagling to get them aligned correctly so I desoldered them again and assembled them into the top half of the switch to guide them into place, clicked the top o the switch back on, then resoldered them in again. And it only bleeding well went and worked, dinnit
Here's a photo of the munted contact leaves
Offline jacobolus
« Reply #40 on: Sat, 08 August 2015, 14:39:31 »
Great to hear!
That’s not true. You can desolder just the one switch and then yank it out. If you do it carelessly, you might end up breaking a couple of the little plastic clips that hold the switch in, but that’s no big deal if it’s a dead switch anyway.
Offline bcredbottle
« Reply #41 on: Sat, 08 August 2015, 15:47:45 »
Memories. I made the same mistake with my first mech (a MEP) and I didn't know how to solder so I paid some guy $80 to solder two switches, and he ****ed up four other switches in the process. It's funny how daunting any electronic work seemed at that time.
Offline njbair
    • nickbair.net
« Reply #42 on: Sat, 08 August 2015, 16:42:32 »
Wow, you're a better man than I. I've tried and failed several times to repair the leaf in Matias switches. Ended up replacing the entire switch.
I'm curious, though, why would you have had to desolder more than just the one switch?
My boards:
Offline bcredbottle
« Reply #43 on: Sat, 08 August 2015, 17:05:01 »
I told him I don't use the cut/copy/paste keys so he took the leafs from there.
This was at an electronics store near my house. I do my own soldering now.
Offline zombimuncha
« Reply #44 on: Sat, 08 August 2015, 18:02:15 »
At first I tried to repair the leaf by bending it with tweezers. Failed miserably.
As far as I can tell, there are little plastic tabs on the base housing of the switch that keep it trapped in between the plate and the PCB. It looked like I would need to desolder all the switches and remove the PCB so that I could pull the broken switch out from the bottom side of the plate.
Great to hear!
Do you mean the little triangular bits, that look like they're designed to let you push the switch down into the plate and then prevent you from pulling it back up out of the plate? Is it really possible to pull a switch up out of the plate without breaking those tabs? If so, that's cool! Is there some kind of trick to it? Got video?
I guess you're right about it not mattering if you break a switch that's already broken - I didn't think of that! :-[
The remaining tiny bits of loose plastic from the tabs should just fall right out if you turn the whole thing upside down and shake it a bit. TIL.
Offline njbair
    • nickbair.net
« Reply #45 on: Sat, 08 August 2015, 20:31:10 »
Great to hear!
Ah, so you thought the switches clipped into the plate from the bottom...I can see how you would think that if you haven't assembled your own board.
Really, though, I'm extremely impressed that you managed to do microsurgery on the switch internals. Matias switches are very nice but not very serviceable.
My boards:
Offline sheinow
« Reply #46 on: Sat, 08 August 2015, 22:00:34 »
If there is a makerspace in your area, take it there most will let you use their tools for free if you have a small project and pay for consumables.
