Author Topic: Adding weight to a board?  (Read 5142 times)
Offline slaction
« on: Mon, 30 March 2015, 16:32:31 »
Hey everyone, just had a question and wanted to see if I could get some advice.
I'm used to using my V60 60% board with aluminum case which adds a good amount of weight, but I'm much more productive with the 75% Race 2 layout (not the standard TKL). However, the Race 2 is way too light and I can't seem to find a metal or aluminum case for it.
I was wondering if anyone has any info on adding some weights to make a keyboard a little more hefty? I'm not sure what materials can give the most weight with the least amount of space needed.
Thanks in advance.
Re: Adding weight to a board?
« Reply #1 on: Mon, 30 March 2015, 16:35:44 »
wtb lead weights in model m thread
i tried to find it again but i couldn't
you could probably use washers or something to similar effect
Offline plegnic
  • Treble Booty. Bass Guitar.
« Reply #2 on: Mon, 30 March 2015, 16:40:17 »
You could buy wheel weights (like for car wheels). They are already measured, readily available, and you can get them with an adhesive backing.
Planck MIT layout [MX Clears] (in-progress) | QuickFire Storm TK [MX Brown] | Poker II [MX Blue]
« Reply #3 on: Mon, 30 March 2015, 16:41:32 »
I've read that people have used fishing line weights in the past? I didn't know that was a thing though so I'm not 100% sure.
« Reply #4 on: Mon, 30 March 2015, 16:51:47 »
That added auditory feedback
Offline slaction
« Reply #5 on: Mon, 30 March 2015, 17:04:19 »
Great advice everyone!  Thanks!  Going to look into these now.
« Reply #6 on: Mon, 30 March 2015, 19:10:08 »
- D Trump 2026-10-24
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #7 on: Mon, 30 March 2015, 19:34:27 »
If you want to add actual blocks of metal (one of my boards actually came like that out of the factory) I'd advise you so put it as low and as much in the middle as possible, or you'll get a weirdly balanced board. Having it in the top left that Focus (which I could swear is a Dell AT101W Oo ) probably feels kinda strange.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #8 on: Mon, 30 March 2015, 20:42:24 »
You could use lead tape, like the kind you can use for tennis raquets
Offline slaction
« Reply #9 on: Tue, 31 March 2015, 02:13:27 »
Actually never heard of that product before.  Is it something you would get at a sporting goods store locally?
Thanks for all of the replies!  I'd really like to go the lead route, but I'm not the most handy with working with raw materials and don't have the tools to do the melting personally.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #10 on: Tue, 31 March 2015, 07:47:16 »
Yeah, you should be able to find it in some sort of sporting goods store, it's pretty common. The tape is maybe 1/4" wide and a few inches can add some decent weight
Offline heedpantsnow
  • Old enough to know better
« Reply #11 on: Tue, 31 March 2015, 09:14:46 »
There is lead putty, kids use it for pinewood derby cars.
I'm back.
Offline Jixr
« Reply #12 on: Tue, 31 March 2015, 11:45:04 »
eassiest/cheapest/best.
Modeling clay and metal weights, they both add weight, and the clay adds a really nice stability effect. helps distribute the weight, and holds whatever metal bits you're using for weight.
Clay is also really dense by itself, and you can squish it into any case.
My clay filled CM-XT transformed the way that keyboard felt.
Offline FrostyToast
  • Litshoard
« Reply #13 on: Tue, 31 March 2015, 11:48:54 »
Kill your wallet and get a Duck Octagon.  :thumb:
Quote from: elton5354
Offline slaction
« Reply #14 on: Tue, 31 March 2015, 18:04:23 »
I wish I could!
I really like the idea of putty/clay as I would be able to mold it to the conform to the inside of the case.  I wish I could find some metal weights that would fit, but everything thing I've found has been an odd shape that won't fit into the case with some modifications.
As for the putty and clay, would there be any adverse effects of those materials coming in contact with the PCB?  I'd try to keep them separated, but I'm sure they would touch at some point.
Offline Jixr
« Reply #15 on: Thu, 02 April 2015, 09:34:51 »
i've had 2 keyboards weighted like that for over a year with no problems.
Though I also added a layer of wax paper between the pcb and the clay.
Offline hwood34
  • underwater squad
  • #1 CL stan
« Reply #16 on: Thu, 02 April 2015, 13:59:57 »
Just an FYI this is the stuff I'm talking about
« Reply #17 on: Thu, 02 April 2015, 14:43:44 »
Half a gram in 4 inches? That's nothing.
You need to add tens of grams to a keyboard to get any serious help, don't you?
