Author Topic: [IC] LeandreN GB | Planning round 2  (Read 45796 times)
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
Re: [IC] Simple brushed steel mountplates - SAMPLES ARE ORDERED
« Reply #150 on: Tue, 21 April 2015, 11:19:18 »
Photo to confirm PCB mounted stabilizer fit plate:
(Source: https://geekhack.org/index.php?topic=50048.0).
But I still hope you can test if you can.
Thanks! I will still test it if i get the opportunity. The plate uses different mount holes than mine though...
Yes. It isn't have center hole like you but it have capslock hole.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #151 on: Tue, 21 April 2015, 11:28:35 »
OK :)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #152 on: Sat, 25 April 2015, 03:42:38 »
Just wanted yo say that I am talking with China about samples right now
Offline Giorgio
« Reply #153 on: Sat, 25 April 2015, 04:29:03 »
People really need to see the plate and the pcb with all the switches mounted :-) just to be sure that it fits :-)))
Also... That brushed finish, as someone else said, is really too rough and ugly. I could do a better job with a cheap sand paper. Maybe you could ask for other finishing treatments? All, really all, the plates sold here are very smooth, with a very nice texture.
Offline lolpes
« Reply #154 on: Sat, 25 April 2015, 08:47:13 »
If the price stays low i really don't mind if the finishing is rough, some sandpaper and done :)
Offline Giorgio
« Reply #155 on: Sat, 25 April 2015, 09:08:10 »
Try to use the sandpaper and let's see how it goes  :eek: Since they make plates for some keyboard makers, I'm sure that they can give you any finish that you want, at the same price, a less rough one, applied with a circular motion would be better. Apple-aluminium keyboard finish would be optimum.
Offline lolpes
« Reply #156 on: Sat, 25 April 2015, 09:11:38 »
If the price stays the same, then sure a smooth finish is better :) i'm just saying I don't mind doing it myself if it comes to that :)
Offline Pietdagamer
« Reply #157 on: Mon, 27 April 2015, 12:59:10 »
I am defenitly interested in this, since I have been planning to build a 60% keyboard.
This plate will fit in this case right?
Ducky Shine 3 Browns
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #158 on: Mon, 27 April 2015, 13:07:00 »
Thats's the plan, yes :)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #159 on: Tue, 28 April 2015, 00:32:19 »
I will look at some different finishes. Samples are ordered, I just need to pay the shipping and they will send it.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #160 on: Tue, 28 April 2015, 00:34:43 »
Everything is on hold until I pay the shipping. Ordering ANSI advanced sample with brushed finish and ISO advanced with sand blasted finish, just to test things out. Thank you for following a long. The plan after I get the samples is to order a aluminium cast case from Pexon and test it with the plate, ordering cherry stabs and testing everything I can test.
Offline awhitedev
« Reply #161 on: Thu, 30 April 2015, 19:09:17 »
Sorry if this is a dumb question... but will there be an option for an ANSI 150 (7u spacebar) layout?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #162 on: Fri, 01 May 2015, 00:55:59 »
It is just standard Poker layout. Nothing special.
Offline FoC_Tow
  • Brokehlicious
Re: [IC] Simple brushed steel mountplates, GB SOON!
« Reply #163 on: Fri, 01 May 2015, 11:57:35 »
Wait, what are the bend/angled plates in the background? Ö_Ö
The cutouts look non-staggered/linear to me from this angle... Are they lubing stations by any Chance?
I would be super interested in something like a standalone (GON skinny/ infinity60 case style) lubing station!  :)
So if thats what it is I would be really stoked  :thumb:
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #164 on: Fri, 01 May 2015, 14:41:38 »
The angled stuff in the back is /u/Vistination's 6 key switch testers.
This is a plate and no lubeastation :-/
 the mountholes have notches for top removal.
Offline Dihedral
  • Mostly Harmless
« Reply #165 on: Fri, 01 May 2015, 14:55:34 »
You may be interested in my Steel Switch Holder. It works quite well as a mini-lubing station. Click the leftmost image in my thumbnail for more info
Sorry Leandre for derailing your topic :P
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #166 on: Fri, 01 May 2015, 14:56:44 »
No problem Dihedral.
I also own one of his they're are also good :) !
Offline FoC_Tow
  • Brokehlicious
« Reply #167 on: Fri, 01 May 2015, 14:56:52 »
Sorry Lean, I know your mainly doing 60% plates and didn't mean to upset you... =/
It was hard to tell the size (of the switchtester) with the crop of the picture tho. And when I saw right angles I thought you did infinity style cases first, the noticed linear cuts and guessed lubestation.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #168 on: Fri, 01 May 2015, 14:59:08 »
It is okay. Sorry but this is only plates.
Yeah it looks like it in the picture, but as I said it is /u/Vistinations 6 key switch tester you can buy at sentrantpc.com.
I also recommend Dihedral's switch tester you can maybe use as a lubestation. (See the comments over)
Edit: and you didn't upset me at all :) sorry if it sounds like it
« Last Edit: Fri, 01 May 2015, 15:04:52 by LeandreN »
Offline FoC_Tow
  • Brokehlicious
« Reply #169 on: Fri, 01 May 2015, 16:44:03 »
Thx Lean! =) Just checked the Link, hadn't seen this one before!
And also thx Dihedral! I really like yours as a switch tester/display! =)
I would really love to have something slightly bigger (ideally about 60% size and linear) for this tho. Ill keep investigating for a bit!  :)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #170 on: Sat, 02 May 2015, 01:18:30 »
Good luck ! :)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Updated the OP. Let me know if you have any concerns. Hyped to get the samples :3 !
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
The samples are paid and being shipped via DHL soon!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
PLEASE VISIT THE GB THREAD HERE
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: [IC] LeandreN GB | Planning round 2
« Reply #176 on: Mon, 06 July 2015, 10:00:32 »
How do you guys think it look?
Universal 60% plate. ISO, ANSI, JIS and Brazilian layout available. Many different bottom rows is supported. Everything in one layout.
Black anodized aluminium.
Offline VinnyCordeiro
« Reply #177 on: Mon, 06 July 2015, 10:07:38 »
You had me on "Brazilian layout". :D :D :D Count me in for some, and a possible partnership on a future crowdfunding here in Brazil.  :cool:
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #178 on: Mon, 06 July 2015, 10:52:43 »
Nothing is confirmed, but I hope we can collaborate in the future ! :)
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #179 on: Sun, 12 July 2015, 04:20:37 »
Universal 60%
Support for short right shift + Fn
Support for both full-size and stepped capslock
Support for both winkeyless and winkey bottom row
Cutout in plate to allow stabilizer wire removal
Removable switch top notches
Stainless steel
Is this possible?
