Author Topic: [IC] LeandreN GB | Planning round 2  (Read 45797 times)
Offline Acanthophis
Re: [IC] Simple brushed steel mountplates
« Reply #50 on: Mon, 13 April 2015, 08:01:15 »
Only those 4 designs will be made?
Offline Dihedral
  • Mostly Harmless
« Reply #51 on: Mon, 13 April 2015, 08:01:56 »
To keep prices down, MOQ will need to be high for each type of design. Simple is better.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #52 on: Mon, 13 April 2015, 08:02:19 »
I dont know yet. Something specific you are thinking about?
Offline Acanthophis
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #54 on: Mon, 13 April 2015, 09:04:26 »
Yup. http://www.keyboard-layout-editor.com/#/layouts/e4e4a9db64cf54b5fba25bf27e2a8ec5
Rather special, ik.
Oh short right shift. I forgot it. Almost korea custom boards fan like it.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #55 on: Mon, 13 April 2015, 09:56:51 »
Updates from China. Read OP
  • Frenzy Classic.
« Reply #56 on: Mon, 13 April 2015, 10:16:23 »
How much is prototype? Over 25$?
It is cut in China?
Can you explain about advantage ISO & ANSI? I don't understand about this.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #57 on: Mon, 13 April 2015, 10:23:09 »
It is cut in China?
The prototype is about 50$, i think. (20 for prototype, 30 for EMS shipping).
Talking with other suppliers also.
Advanced ISO and ANSI, are plates with more features than the plain ones. (You can have both stabilizers, mountholes and not he's for switch removal) for a higher cost. A lot of people in the IC didn't need these features, so I made both.
Hope I answered your question.
  • Frenzy Classic.
« Reply #58 on: Mon, 13 April 2015, 11:24:13 »
It is cut in China?
Good anwser :thumb:
We only need plate with mountholes. If you have notched plates, it is very great.
But it is important thing is price. Hope you 'll give reasonable price.
Thanks for your effect.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #59 on: Mon, 13 April 2015, 11:25:01 »
It is cut in China?
Good anwser :thumb:
I will try my best :) thanks !
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #60 on: Mon, 13 April 2015, 12:40:23 »
It is cut in China?
Good anwser :thumb:
I asked them how the cuts would be without the notches. That was actually a really great idea. While notches is great, as long as you know what kind of switches you want on, there shouldn`t be a problem.
  • Frenzy Classic.
« Reply #61 on: Mon, 13 April 2015, 12:48:42 »
It is cut in China?
Good anwser :thumb:
Sound great !
I dont' understand your question. I thought plates 'll fit all Cherry MX switch? Not true?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #62 on: Mon, 13 April 2015, 12:51:34 »
It is cut in China?
Good anwser :thumb:
Sound great !
The plates will fit all Cherry MX switches :) I think ALPs will fit to. With or without notches, all the Cherry MX switches will fit :)
  • Frenzy Classic.
« Reply #63 on: Mon, 13 April 2015, 13:10:31 »
It is cut in China?
Good anwser :thumb:
Sound great !
Great. I like Cherry MX & only use it. In additional I would like use notched plate rather than.
Offline Dihedral
  • Mostly Harmless
« Reply #64 on: Mon, 13 April 2015, 13:27:55 »
If you want to keep costs down, why the brushed finish? It's the little things that add up to expensive end results.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #65 on: Mon, 13 April 2015, 13:29:06 »
Currently, the company i am talking with does not add extra cost for brushed finish :) It is the same price with or without.
Offline Dihedral
  • Mostly Harmless
« Reply #66 on: Mon, 13 April 2015, 13:30:48 »
Ah right, in that case then :)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #67 on: Mon, 13 April 2015, 13:32:03 »
It is cut in China?
Good anwser :thumb:
Sound great !
Now you are a little unclear for me. Do you want notched or not? I think it is easier to make with no notched.
« Reply #68 on: Mon, 13 April 2015, 13:43:55 »
Depending on the notch style you use the impact on the cost should be minimal.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #69 on: Mon, 13 April 2015, 13:44:38 »
Yep, but the difficulty of cutting.
« Reply #70 on: Mon, 13 April 2015, 13:48:17 »
What notches are you using? They don't really complicate plates that much, especially with CNC lasers.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #71 on: Mon, 13 April 2015, 13:57:03 »
The standard notches shown in the pictures on the "Advanced plates". I got that the advanced plates was much more likely to be errors on and suggestet i prototype it.
« Reply #72 on: Mon, 13 April 2015, 14:00:28 »
Is the cutting place you're using really sketch? There should only be issues if the plate is drawn wrong. Also you should add holes to the simple boards because they are completely useless without them.
If you want a cheap plate ditch the notches, keep support for both stab types (unless everyone can agree on one), decide on a layout, and add the mounting holes. This is as cheap as you can make a plate and still have it be useful.
« Last Edit: Mon, 13 April 2015, 14:02:32 by Joey Quinn »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #73 on: Mon, 13 April 2015, 14:26:21 »
Thanks for the feedback. I will know more tomorrow. Contacted more suppliers :)
  • Frenzy Classic.
« Reply #74 on: Mon, 13 April 2015, 19:16:31 »
I want notched plates.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #75 on: Mon, 13 April 2015, 22:45:51 »
Offline Dihedral
  • Mostly Harmless
« Reply #76 on: Tue, 14 April 2015, 02:13:30 »
Go type two. It allows for matias builds, which are always cool :)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #77 on: Tue, 14 April 2015, 07:30:15 »
You mean the notches? :)
Offline Dihedral
  • Mostly Harmless
« Reply #78 on: Tue, 14 April 2015, 07:49:55 »
If by notches you mean this one then yeah.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #79 on: Tue, 14 April 2015, 09:08:32 »
Yes, that is what i mean by that :) Talked with the orginal suppliers today. Got a quote. Will start to make some prices soon.
Hopefully, we will also be making the ones with the "notches".
LeandreN
Offline Acanthophis
« Reply #80 on: Tue, 14 April 2015, 11:01:58 »
How expensive would be one single design?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #81 on: Tue, 14 April 2015, 11:04:16 »
What do you mean? I got quotes for all the plates and will start making the "end price" for all of you.(have to add shipping to me, taxes, package, and all of that). The prices are not ready yet.
Offline Dihedral
  • Mostly Harmless
« Reply #82 on: Tue, 14 April 2015, 11:36:04 »
probably around 50 pounds if you got it done yourself. That's in the region of 60 euros or 80 muricas.
« Reply #83 on: Tue, 14 April 2015, 11:45:03 »
I think LeandreN's goal was much cheaper.
Offline Dihedral
  • Mostly Harmless
« Reply #84 on: Tue, 14 April 2015, 11:47:41 »
Yes, because he's buying in bulk. Acanthopis just wants one plate from what i can discern from his post, so it will inevitably be more expensive.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #85 on: Tue, 14 April 2015, 11:48:13 »
Yes, that's right.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #86 on: Tue, 14 April 2015, 11:48:36 »
Yes, my goal is definitely cheaper than 50£
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #87 on: Tue, 14 April 2015, 12:38:26 »
Updated the OP:
04.14.2015 - After looking at the quotes, i found that the price differentiation was to small to effectively make both with a reasonable price. I decided to discontinue the plain ones for now. This will result in a hopefully cheaper price for the ISO and ANSI advanced ones.
Offline Dihedral
  • Mostly Harmless
« Reply #88 on: Tue, 14 April 2015, 12:55:20 »
Updated the OP:
was plain just without the brushed finish? if so, this seems like a prudent choice.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #89 on: Tue, 14 April 2015, 13:01:16 »
Updated the OP:
Nah lots of other stuff to...
You can read about it here
« Last Edit: Tue, 14 April 2015, 14:16:49 by LeandreN »
Offline Dihedral
  • Mostly Harmless
« Reply #90 on: Wed, 15 April 2015, 01:56:16 »
Updated the OP:
Ah. That one sounds quite good in terms of simplicity, but I guess if you don't have enough interest...
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #91 on: Wed, 15 April 2015, 06:41:58 »
Updated the OP:
The biggest problem is price difference. They cost almost the same to make and I don't want to set the advanced ones to a ridicously high price to give you an illusion that the plain ones are cheap. :)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #92 on: Wed, 15 April 2015, 10:18:54 »
PRICES ARE READY !
Prices: http://leandre.webs.com/groupbuys
« Last Edit: Wed, 15 April 2015, 16:03:32 by LeandreN »
Offline Dihedral
  • Mostly Harmless
« Reply #93 on: Thu, 16 April 2015, 04:33:31 »
Probably best to start a GB thread now - in my GB I made the mistake of starting it too late which means that less people saw it.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #94 on: Thu, 16 April 2015, 04:34:57 »
Thanks for the tips. Will just wait for confirmation from China about samples ;-)
Or not. I'll make on today :)
« Last Edit: Thu, 16 April 2015, 05:20:10 by LeandreN »
Offline Dihedral
  • Mostly Harmless
« Reply #95 on: Thu, 16 April 2015, 06:14:49 »
Just go for it. If you hit any problems, be honest and let people know, they will be understanding.
  • Frenzy Classic.
« Reply #96 on: Thu, 16 April 2015, 10:43:03 »
How to order? Via your shop?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #97 on: Thu, 16 April 2015, 10:56:33 »
Yes, but it is not ready yet. There is still a some of work to do. Need to get samples to assure the quality and that everything fits. And then I will begin orders. I have also made a GB page which is currently under approval.
  • Frenzy Classic.
« Reply #98 on: Thu, 16 April 2015, 12:54:13 »
Sound great. I 'll waiting ...
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #99 on: Thu, 16 April 2015, 13:09:09 »
Do you know of a place i can get some Cherry stabilizers? I don`t have them. I just need one for the space bar and on of the shorter ones, just to test. I only use Costar myself.
AND, do you have any feedback on the prices?
« Last Edit: Thu, 16 April 2015, 13:29:06 by LeandreN »
