Author Topic: KUL key caps- what profile?  (Read 3270 times)
Offline jamster
« on: Sun, 12 April 2015, 22:10:36 »
From reading reviews, I had thought that KUL ES-87 came with OEM profile caps.
However, I have a single original KUL key (backslash) remaining on the keyboard, with the rest replaced with a Tai Hao set (OEM, unless I am confused), and the KUL backslash is lower profile.
So is KUL Cherry profile, or something else?
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: KUL key caps- what profile?
« Reply #1 on: Sun, 12 April 2015, 22:13:33 »
Should be OEM, though that can obviously vary between manufacturers
Offline Jokrik
« Reply #2 on: Sun, 12 April 2015, 22:59:05 »
This ^
OEM is vary between manufacturer from what I know
You can check my review here
https://geekhack.org/index.php?topic=70856.0
I've compared KUL's with Leopold cherry profile caps
Offline jamster
« Reply #3 on: Mon, 13 April 2015, 00:03:23 »
Oh, that's interesting. I had assumed that OEM profile was some kind of industry standard, rather than "whatever the manufacturer feels like". Which would mean that OEM caps are not necessarily compatible between manufacturers.
Huh.
Offline wigz81
  • Midi-Chlorian Manipulator
« Reply #4 on: Mon, 13 April 2015, 18:20:31 »
I can let you know in a day or two. I ordered a set from WASD in the stock profile.
Your Lack Of Faith In The Force Disturbs Me...
Offline wigz81
« Reply #5 on: Mon, 13 April 2015, 23:10:34 »
Caps just showed up from WASD. Will compare them with the KUL caps when I get home from work.
Offline wigz81
« Reply #6 on: Tue, 14 April 2015, 17:23:00 »
The WASD caps are a couple mil taller than the stock caps. After putting them on I don't notice it. It looks and feels good.
