Author Topic: [GB] [Round 1 done] ISO & ANSI 60% mountplates  (Read 207810 times)
Offline honoka
Re: [GB] [SHIPPING TO YOU] ISO & ANSI 60% mountplates
« Reply #400 on: Wed, 17 June 2015, 13:16:46 »
Unfortunately my two plates had a lot of residue on them. I will probably never clean anyway so its fine. I do have some issues with my cherry stabilizers not sittning thightly. I can easily dislodge them. Anyone else?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #401 on: Wed, 17 June 2015, 13:23:53 »
I can send you an extra ISO if you want. Sorry for the residue that was entirely my fault.
The Cherry stabs fit somewhat tightly for me, but if they're loose, I would suggest gluing them in. If you think there could be improvements, contact SwillKB. He is the man behind the design tool used for this plates.
I will probably glue my own, as I will never remove them. If you use a heat glue, you can remove it later if needed.
Offline honoka
« Reply #402 on: Wed, 17 June 2015, 13:58:52 »
NO! Do not send me a new plate. Its only glue, it comes off. Actually, i dont think you should offer people replacements since they are not broken. No one expects that of you. Just keep on with the awesomely smooth gb :)
.....And... Make an QFR/Filco compatible tkl plate <3
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #403 on: Wed, 17 June 2015, 14:17:44 »
You can fill out this, if you want to help me decide what i should run the next time!
Offline Acerk
  • I pay attention to details!
« Reply #404 on: Wed, 17 June 2015, 14:26:54 »
Are you thinking Phantom/Teensy or just a replacement plate so you have notches on QFR/Filco? I'm in the same boat myself. Been thinking of putting Phantom in my QFR-I, off-center caps lock and split right shift (if possible).
Here's some info from another thread:
I had to cut a mini usb cable and solder the ends to the QFR USB board. So the mini usb cable connects to the teensy and the exposed wires are just soldered onto the QFR board. Wasn't too hard to do really and there's plenty of room in the case for everything.
I did notice one small problem with using a Phantom in a QFR case after after about 2 weeks of use. The plate and PCB do move slightly in the case if you travel with the keyboard or hit it hard on your desk. It's a pretty stiff move so it doesn't really bother me too much. I haven't found a good way to screw it to the case in a way where it won't do that. I think the problem is due to the fact that my stainless steel mounting plate is flat and the QFR requires curved edges. If you had the right plate or managed to find a way to use the QFR stock plate you probably wouldn't have a problem. Again, not really an issue that I care about... but it might bug some.
« Last Edit: Wed, 17 June 2015, 14:34:49 by Acerk »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #405 on: Wed, 17 June 2015, 14:28:06 »
Plate arrived safe-and-sound. Just a little tape residue to clean in up on one end, but otherwise in perfect condition. Thank youLeandreN!
Thanks for joining and posting here :) !
Offline cwils0n
  • twiggletwaggle
« Reply #406 on: Wed, 17 June 2015, 16:28:42 »
Mine just arrived, dead straight with no bends  :cool:
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #407 on: Wed, 17 June 2015, 16:31:26 »
Arriving in outside Europe in less than a week? That's amazing.
Enjoy!
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #408 on: Wed, 17 June 2015, 18:46:58 »
Little tape issue on left hem :(
Offline cwils0n
  • twiggletwaggle
« Reply #409 on: Wed, 17 June 2015, 20:46:58 »
Yes it did have a little tap residue, but I was able to get it off easily with some soap and a sponge.
  • Frenzy Classic.
« Reply #410 on: Wed, 17 June 2015, 20:49:35 »
Oh really? This is very great. Thanks for your info  :thumb:
Can you post picture after you  solve issue?
« Last Edit: Wed, 17 June 2015, 21:24:52 by quochung1989 »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #411 on: Thu, 18 June 2015, 00:44:02 »
Great!
Offline TalkingTree
    • My projects
« Reply #412 on: Thu, 18 June 2015, 05:37:07 »
I'm not a stamps collector but these ones look nice.
Picture with autograph!
Sticky plates.
After some cleaning I took the glue off, it might not be pretty but it's not sticky either.
This was my first GB and I'm very satisfied.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #413 on: Thu, 18 June 2015, 07:24:50 »
Sticky plates.
Thanks for the detailed post :)
Offline cwils0n
  • twiggletwaggle
« Reply #414 on: Thu, 18 June 2015, 08:10:25 »
The dark spots are from where I used the scruffy pad of the sponge.  You could probably avoid the same results if you just use the soft side.  It doesn't really matter for me though, I'll be painting my plate as well.
« Reply #415 on: Thu, 18 June 2015, 08:22:27 »
These are plate mounted stabilizers you are using, correct? Do they dislodge from the "top" part of the stabilizer hole? If so, that has to do with the design of the hole. That notch on the hole is for Costar stabilizer compatibility, but it's not present in the Cherry-only stabilizer hole design. It prevents the Cherry plate mount stabilizers from clipping onto the plate as they should, and therefore the stabilizers come out easily. It's a design compromise, for inclusion of Costar compatibility.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #416 on: Thu, 18 June 2015, 08:23:38 »
Thanks for explaining JD!
  • Frenzy Classic.
« Reply #417 on: Thu, 18 June 2015, 08:41:19 »
Yes. Thanks for sharing :thumb:
If we want to have perfect plate, we must be re-painting it.
Offline Defying
  • (suffer on)
« Reply #418 on: Thu, 18 June 2015, 14:53:06 »
Interesting...
Bent it back easily but its a little uneven now.. Bit of tape residue but there's no issue with that. Just wondering how I can make it completely flat.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #419 on: Thu, 18 June 2015, 14:55:27 »
Interesting...
Looks like its more bent than "a little uneven" I am sure you can get it 85% flat with your hands and just lay it under a heavy book or something over the night to get it straight. Sorry about the issue.
Offline Defying
  • (suffer on)
« Reply #420 on: Thu, 18 June 2015, 15:06:06 »
Interesting...
It's fine, it's not your issue. Probably the silly US Mail system :)
It's pretty flat right now, just gonna put it under some books like you said and wait.
Offline a-c
« Reply #421 on: Thu, 18 June 2015, 15:25:25 »
They've crossed the Atlantic! Hopefully mine will arrive for the weekend.  :)
Offline TalkingTree
    • My projects
« Reply #422 on: Thu, 18 June 2015, 16:54:00 »
You will forgive the obscene photo quality, it's just to show how perfectly the plate fits into a Pexon's 60% case on a Satan GH60 PCB.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #423 on: Thu, 18 June 2015, 17:41:37 »
That is great to hear. Awesome switch layout.
Also, let me know how that Satan PCB works. I've been thinking about ordering one for a long time!
Offline a-c
« Reply #424 on: Thu, 18 June 2015, 22:30:14 »
Already here, half way around the world!
So excited I already assembled one with a b.face board. Everything aligns perfectly.
http://imgur.com/a/L5rNh
All soldered up. Very solid. Switches very snug.
Thank you LeandreN!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #425 on: Fri, 19 June 2015, 00:18:37 »
Thank you LeandreN!
Cool. Glad you enjoyed! :)
Offline faxe
« Reply #426 on: Fri, 19 June 2015, 01:21:28 »
Thank you LeandreN!
Hi,
mind telling me what a b.face board is? Searching leads to confusing results :)
ISO Clueboard V2 Zealio 78g -ISO Clueboard V1 MX Clear - ISO 60% MX Clear - ISO Filco MJ 2 MX Brown - ISO is life
Offline flabbergast
« Reply #427 on: Fri, 19 June 2015, 01:25:16 »
http://winkeyless.kr/shop/
Offline faxe
« Reply #428 on: Fri, 19 June 2015, 01:57:04 »
Offline TalkingTree
    • My projects
« Reply #429 on: Fri, 19 June 2015, 03:05:59 »
Works well, it comes with a basic firmware already so it's ready to go. The only thing I've noticed is that the Cherry spacebar stabilizer gets easily stuck between PCB and place, I'm taking it out and getting a Costar stab for that. The 2u Cherry stabilizers work flawlessly.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #430 on: Fri, 19 June 2015, 03:33:39 »
Ohh okey. Hav eyou clipped your Cherry stabs btw?
Offline TalkingTree
    • My projects
« Reply #431 on: Fri, 19 June 2015, 04:00:50 »
Not yet but I'm trying since getting Costar stabs in Europe is rather hard and expensive. Maybe someone should consider running a groupbuy for them along with plates.
Offline a-c
« Reply #432 on: Fri, 19 June 2015, 07:39:21 »
Yes, that's the place. I got the older model with only the controller parts pre-soldered. They are on sale, since they came out with a new version with more RGB LED's on the bottom of the board.
Shipping is high though.
Offline a-c
« Reply #433 on: Fri, 19 June 2015, 17:08:53 »
Sprit may also still have some of his PCB's available. They are very similar to the B.face. No RGB LED's, but all the diodes and resistors are pre-soldered.
https://geekhack.org/index.php?topic=60887.msg1760685#msg1760685
Offline Ripudio
« Reply #434 on: Fri, 19 June 2015, 18:32:43 »
My plates arrived safe and sound, only a tiny bit of bending vertically (I expected to find them snapped in half by the postal service). I got too excited and didn't take any pictures before fitting everything together, but I'll post pictures of the one in progress when I get home! It took a tiny bit of fiddling to get them on around the stabilizers, but that was the only thing I noticed, other than that these are absolutely beautiful (and heavy). Thanks so much LeandreN!
Edit: I was surprised to find that my two plates weren't taped together, bonus win.
« Last Edit: Fri, 19 June 2015, 18:34:39 by Ripudio »
Offline Tiramisuu
« Reply #435 on: Fri, 19 June 2015, 18:35:17 »
Looking forward to hearing about the Satan  board as well.   A programmable  pcb that can be ordered at a reasonable fit price without drama is appealing.
Keyboard error F1 to continue.
Poker 2, Gherkin, Lets Split, Planck, Filco
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #436 on: Sat, 20 June 2015, 15:28:09 »
Haha! Great. Thanks for posting
Offline honoka
« Reply #437 on: Sun, 21 June 2015, 05:43:57 »
Thank for the explenation. It is plate mount cherry stabilizers I am using.
Hugs
« Reply #438 on: Sun, 21 June 2015, 20:58:45 »
Shouldve said something last week but I received my plates and there aren't any tape marks. Plate looks great. Thanks for running the buy!
Offline Tiramisuu
« Reply #439 on: Mon, 22 June 2015, 12:33:18 »
The US Post seems to be beating Canada Post this time round.  They must have decided to send mine via dogsled.
Offline nephiel
« Reply #440 on: Tue, 23 June 2015, 17:16:14 »
Mine is here. Potato shot, ahoy!
Very slight bend, fixed by hand right away. Tiny scuff and tape residue on Esc corner, nothing I care about.
Thank you Leandren!
Stop wasting space! Chop your spacebar into bits!
NPH60: a custom 60% w/TrackPoint & split spacebar
Offline Melanic
« Reply #441 on: Tue, 23 June 2015, 18:34:18 »
Just received mine. A bit of a bend, a bit of tape residue, but otherwise in good condition. First GB I've been in that didn't have shipping issues! Thanks.
Now I just need to find some use for it...
Offline QuiGonJinn
« Reply #442 on: Wed, 24 June 2015, 12:02:01 »
Mine arrived last Friday, though I was busy to write back. Just a little bit bent, I made it flat now. Excellent quality(no residue) and switches fit like a charm. It actually makes me regret having started to build a custom keyboard with an acrylic plate. This will be next in the list. Thanks a lot Leandren.
Offline Tiramisuu
« Reply #443 on: Wed, 24 June 2015, 18:45:11 »
Mine arrived today.  A little tape residue needs to be removed with some isopropyl alcohol but otherwise perfect.
Now all I need are all the other parts.
Offline TalkingTree
    • My projects
« Reply #444 on: Thu, 25 June 2015, 03:32:35 »
I strongly recommend a Satan GH60 and a plastic 60% case (unless you prefer aluminum), you can find both on Aliexpress.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #445 on: Thu, 25 June 2015, 07:39:19 »
Thanks for all the answers !
Offline kosomoN
« Reply #446 on: Thu, 25 June 2015, 07:44:02 »
Mine had arrived in perfect shape, I was overseas and just came back home.
Thanks for an awesome GB!
  • Frenzy Classic.
« Reply #447 on: Thu, 25 June 2015, 08:42:41 »
I received plates. I don't like it. It had problems like tape on left & right fringe, bend plate....even ESC position is twisted...
I don't think I can use it...
I don't know I give it become original status (straight plate). Who can show me?
I'm thinking this is first bad GB which I participated ....
Some photos:
I am so sad now  :-[
PS: You packaged plate uncarefully, I think.
« Last Edit: Fri, 26 June 2015, 05:14:30 by quochung1989 »
Offline Ruisu
« Reply #448 on: Thu, 25 June 2015, 13:59:05 »
My plate arrived with only a very slight bend, came out nicer than expected.
Quochung, the tape residue should just wipe off and even that bend shouldn't be too hard to make flat again.
Offline Tiramisuu
« Reply #449 on: Thu, 25 June 2015, 14:16:09 »
The trick to unbending Metal is to take the time to understand how it is bent and then apply a balanced opposite force.
If you bend it randomly it gets worse
