Author Topic: [GB] [Round 1 done] ISO & ANSI 60% mountplates  (Read 207662 times)
Offline nephiel
Re: [GB] [SHIPPING TO YOU] ISO & ANSI 60% mountplates
« Reply #450 on: Thu, 25 June 2015, 15:53:31 »
Bend it back little by little. Lay it on a table or a flooring tile between attempts to check how it goes.
The tape residue should go away with warm water + soap + a good rub with a toothbrush.
Stop wasting space! Chop your spacebar into bits!
NPH60: a custom 60% w/TrackPoint & split spacebar
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #451 on: Thu, 25 June 2015, 18:05:51 »
Thanks everyone for your advice. I 'll try to fix tape and bending issues. But about twisted esc position?
I afraid that I can't install switch on that position.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #452 on: Fri, 26 June 2015, 06:50:40 »
Refunded. Tape residue was my fault, packaging was also my fault to some degree.
Offline TalkingTree
    • My projects
« Reply #453 on: Fri, 26 June 2015, 07:02:46 »
Heat the corner with a heatgun or a lighter then squeeze a switch casing (without stem and spring) in the frame.
  • Frenzy Classic.
« Reply #454 on: Sun, 05 July 2015, 05:39:59 »
Thanks everyone help me to fix plate. Especially thanks to TakingTree & JD.
This is my plate after fixing:
https://flic.kr/s/aHskfypRQN
I only can fix around 90%, can't fix it perfect. But I think it can work well.
« Last Edit: Sun, 05 July 2015, 05:41:49 by quochung1989 »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #455 on: Sun, 05 July 2015, 05:40:37 »
Glad you get to fix it :)
Offline wlhlm
« Reply #456 on: Sun, 05 July 2015, 05:41:32 »
Looks good! :thumb: Which PCB did you use?
  • Frenzy Classic.
« Reply #457 on: Sun, 05 July 2015, 05:45:35 »
Yeah. Thanks :D
Poker X PCB. I 'll try use Cherry plate mounted stabilizers :)
Offline heedpantsnow
  • Old enough to know better
« Reply #458 on: Sun, 05 July 2015, 07:24:41 »
Wow, great job on that!
I'm back.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #459 on: Mon, 06 July 2015, 16:34:24 »
Planning next round :)
Offline nephiel
« Reply #460 on: Tue, 07 July 2015, 00:56:01 »
I just populated mine with vintage MX clears. Potato shot attached.
104652-0
The spacebar slot was cut by hand because I want to split the 6.25 spacebar into 5 stab-less keys (Space, Fn and TrackPoint buttons).
Switch fit in the rest of the plate is secure, but feels a bit wobbly. The only switch that doesn't wobble at all is one who had a 2-pin LED header fitted inside so it's a bit thicker.
I'd try a 0.1mm thicker plate next time if possible.
Offline faxe
« Reply #461 on: Tue, 07 July 2015, 02:46:29 »
Posted this already after GH was back but somehow the post got lost. Finished rows and cols on my handwire project:
ISO Clueboard V2 Zealio 78g -ISO Clueboard V1 MX Clear - ISO 60% MX Clear - ISO Filco MJ 2 MX Brown - ISO is life
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: [GB] [PREPARING ROUND 2] ISO & ANSI 60% mountplates
« Reply #462 on: Fri, 10 July 2015, 15:45:45 »
Okay, i have updated the OP. Please continue your questions and concerns from round 1, i am just preparing round 2. Let me know what you think, i need your feedback.  Prices are not set.
What are you going to buy?
What is necessery/unnecessery?
  • Frenzy Classic.
« Reply #463 on: Fri, 10 July 2015, 22:54:46 »
Personally idea: You should create new thread for Round 2.
Offline emguy
« Reply #464 on: Fri, 10 July 2015, 23:32:33 »
I'll go with the option 2.
Offline TalkingTree
    • My projects
« Reply #465 on: Sat, 11 July 2015, 02:42:43 »
Offline punkpc
« Reply #466 on: Wed, 15 July 2015, 16:54:16 »
The new universal plate look great! I will be in for one of those. Please keep us posted.
Offline tlt
« Reply #467 on: Thu, 16 July 2015, 17:14:41 »
Interested in a aluminum plate. Going to keep an eye on this thread
Offline theanyday
  • love love love
« Reply #468 on: Sat, 01 August 2015, 00:41:14 »
Still waiting on my round 1 plates to arrive.  :'(
MIRA SE | White Fox w/ 67g Zealios | POK3R w/ Blues | K70 w/ Browns | Planck w/ Greens | NovaTouch TKL
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #469 on: Sat, 01 August 2015, 07:31:53 »
That's unfortunate, I have definetily shipped it.
I am afraid I can't do anything about the "lost in shipping" part, but I can maybe give you a compensation. I have no extra plates. If you don't want an ISO.
Please tell me, did you plan on handwriting or PCB. I have a PCB plate coming(could work with hand wiring with glue). A couple of weeks.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #470 on: Sat, 01 August 2015, 07:33:09 »
I'll make a new thread for GB 2, will link here when it is done.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Offline theanyday
  • love love love
« Reply #472 on: Tue, 04 August 2015, 23:34:07 »
Unfortunately no, was needing an ANSI plate. I checked with the post office again and no luck. Didn't really have any plans for the plate yet (just gathering parts) so at the time there was no preference for PCB or handwired plate.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: [GB] [Round 1 done] ISO & ANSI 60% mountplates
« Reply #473 on: Wed, 05 August 2015, 05:22:59 »
If you pay the shipping, I can send you one of the new anodized ones. It's a PCB plate. Sorry, but that package is probably lost.
Offline theanyday
  • love love love
« Reply #474 on: Wed, 05 August 2015, 13:56:44 »
That would be amazing, I know it's no fault of yours and more than likely an issue with the postal system here. I know you're going to be polling for colors but I'd love to see a purple one!
  • Frenzy Classic.
« Reply #475 on: Wed, 05 August 2015, 19:48:37 »
My idea is accepted. Greatting  :))
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #476 on: Fri, 07 August 2015, 03:52:50 »
Purple is available in round 2
Added it for your convenience.
« Last Edit: Fri, 07 August 2015, 03:54:47 by LeandreN »
Offline theanyday
  • love love love
« Reply #477 on: Sat, 08 August 2015, 02:44:08 »
Awesome thank you, how do you want to handle this? Shall I submit an order on the round 2 gb page?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #478 on: Sat, 08 August 2015, 02:54:47 »
Yes please. Also leave a note in the last field :)
