Author Topic: Lubing cherry mx without disassembling  (Read 2034 times)
Offline manna
« on: Thu, 16 April 2015, 19:02:45 »
Is it possible to lube mx switches, without having to desolder or disassemble them?
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: Lubing cherry mx without disassembling
« Reply #1 on: Thu, 16 April 2015, 20:05:15 »
Well all the parts you'd be lubing are inside the housing, so no, not without dissasembly. But if the swiches are PCB mounted to can take off the housing top without desoldering
« Last Edit: Thu, 16 April 2015, 20:19:16 by hwood34 »
Offline alexofthewest
« Reply #2 on: Thu, 16 April 2015, 20:16:10 »
I think its possible to lub without desoldering however, if you have a PCB mounted board. I think you can just take the top half of the switch off
