Author Topic: Model M layout conversion ISO/ANSI  (Read 3215 times)
Offline njbair
    • nickbair.net
« on: Fri, 17 April 2015, 19:56:10 »
I remember reading somewhere that Model M boards all share the same barrel plates and membranes, so if you relocate the spring hammers you can change the layout. Can anyone confirm this? I am particularly interested if this is still true of the Unicomp PC-122. I bought two used ISO layouts and I would like to convert at least one of them to ANSI.
My boards:
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
Re: Model M layout conversion ISO/ANSI
« Reply #1 on: Fri, 17 April 2015, 20:02:56 »
This is true, but I'm not sure if that goes for the Uni's as well... I would think so but...
I'll post a link if I can find it again!!!
Offline njbair
    • nickbair.net
« Reply #2 on: Fri, 17 April 2015, 20:05:42 »
I should just be able to pop off the enter key and look for an empty barrel, right?
I can actually probably dry-fit all the ANSI keys before I tear it apart. I'll have to try that tomorrow when I get into work.
My boards:
Offline njbair
    • nickbair.net
My boards:
« Reply #5 on: Sat, 18 April 2015, 21:41:44 »
