Author Topic: Happy Hacking Pro 2 Disconnecting issue  (Read 3603 times)
Offline slenderman1
« on: Sat, 18 April 2015, 05:14:35 »
Hi, I've had my happy hacking pro 2 for about a year now and now I'm starting to have problem with mine. Whenever I move the keyboard or the USB wire, my keyboard would disconnect and reconnect and this only happens whenever I move the keyboard. Why is this happening? how did the port become loose? How might I fix it?
Offline Ludovician
Re: Happy Hacking Pro 2 Disconnecting issue
« Reply #1 on: Sat, 18 April 2015, 05:31:59 »
Does it have the same issue with other cables?
Have you tried opening it and seeing if the issue is evident?
If you have, have you taken pictures?
Typing speed:
My collection:
HHKB Pro 2 (Blank, white) | HHKB Pro 2 Type-S (Blank, white) | Topre Realforce 87UB silent-modded (not currently functional) | Das Keyboard Model S Professional Silent (MX Brown) | IBM Model M 1391401 - 9th January 1991 (Bolt+Floss-modded) | Apple keyboard m0116 (Orange Alps) | Unidentified DIN Keyboard (White Alps) | ADDS 1010 (Green Alps) | AEK II (Linear-modded, USB-converted) | IBM PC-AT Model F | Noppoo Choc Mini (MX Black) | Amstrad PC2286 | BigKeys LX | IBM Model M 1391401 - 6th September 1990 | IBM Model M2 1395300 - 28th February 1991 | Leopold FC660C | Cherry G80-11802 (MX Brown) | Matias Tactile Pro (Simplfied grey Alps) | Razer Blackwidow (MX Blue) | Novatouch 55g | Focus FK-2001 (White alps) | DSE Multitech (Blue alps) | Dell AT101W (Matias quiet) | Pok3r (White w/Clears) | KBP V80 (Blue Alps)
Pending:
Infinity kit
Offline slenderman1
« Reply #2 on: Sat, 18 April 2015, 05:34:12 »
Yeah I have tried it with another cable and no I haven't opened it. I'm not sure if it's safe to do so or how to do it.
Offline Ludovician
« Reply #3 on: Sat, 18 April 2015, 05:42:29 »
It should be a simple matter of unscrewing the case and taking that off. Not sure how that could be considered unsafe.
Typing speed:
My collection:
Pending:
Infinity kit
Offline slenderman1
« Reply #4 on: Sat, 18 April 2015, 06:03:33 »
I opened it. The issue isn't evident as the problem is inside the tiny port. It's the tiny black chip inside the port that that moves whenever I hit the wire. Not sure if this is normal or a design flaw.
« Last Edit: Sat, 18 April 2015, 06:05:31 by slenderman1 »
Offline Thechemist
« Reply #5 on: Sun, 19 April 2015, 00:15:42 »
Are you referring to the mini usb b connector? sounds like you need a new one.
Offline slenderman1
« Reply #6 on: Sun, 19 April 2015, 04:11:39 »
Perhaps. I opened it up and saw that it's attached to the keyboard. Not sure how to remove it or how to get a replacement for it.
Offline MJ45
  • HHKB Pro
« Reply #7 on: Sun, 19 April 2015, 05:18:41 »
I have a spare HHKB Pro 2 controller board available, if you want to replace it, PM me or get one of Hasu's programmable controllers.
Offline slenderman1
« Reply #8 on: Sun, 19 April 2015, 05:44:34 »
I did not know about Hasu's controller. Are there any real benefit for choosing Hasu's alternative over the standard controller board?
Offline Ludovician
« Reply #9 on: Sun, 19 April 2015, 07:50:41 »
    Customizable keymap and multiple layers
    Mouse keys
    USB NKRO
    Media & system control
Typing speed:
My collection:
Pending:
Infinity kit
