Author Topic: Where to get 3D printer templates  (Read 1964 times)
Offline krisman
« on: Tue, 21 April 2015, 13:18:35 »
Hi guys, where can I find key cap templates for 3D printers. A friend has just ordered one and we are thinking of designing some keycaps but first I need the template for the base part of a key.
Thanks in advance! :)
Re: Where to get 3D printer templates
« Reply #1 on: Tue, 21 April 2015, 13:24:04 »
Shapeways has a bunch of designs that you can download.
Offline BlueNalgene
« Reply #2 on: Tue, 21 April 2015, 13:34:30 »
Have you checked this large thread on 3D printing here?
While you can obviously use a template, it may be better in the long run to design your own.  Using your own printer, while still getting it working, you might find that certain polymers and temperatures cause things to change size with settings.  Having designed your own 'hello world' model, you would be more comfortable modifying the model to your machine.
I'm not sure what your skill level is with CAD either.  I've used keycaps as a way to practice with the different programs to find one that meets my needs and to get in valuable practice.
You are more than welcome to try my template, which you can find attached to this post.  It isn't perfect, but it might be a starting point.
What kind of a printer did your friend order?
« Reply #3 on: Tue, 21 April 2015, 14:39:12 »
Make your own in TinkerCAD or other CAD software.  Making it yourself means you can tailor it and makes it so that you really understand the process better.
Offline krisman
« Reply #4 on: Tue, 21 April 2015, 16:01:45 »
Thanks guys! Will start experimenting soon and let you know the results! :)
