Author Topic: Plans for a Kishsaver-inspired 60% case  (Read 5446 times)
Offline njbair
    • nickbair.net
« on: Tue, 05 May 2015, 18:23:00 »
I'm sad because I don't own a Kishsaver. So to cheer myself up, I'm working on a solid aluminum 60% case which takes design cues from the IBM Model F/Kishsaver case. My goal is to create a rock-solid compact case which breaks away from the low-profile look of most 60% cases.
EDIT: As of right now, this will be a one-off. If all goes well I may open this up to an interest check, but baby steps for now. Thank you all for your kind words.
Update 2015-05-16: HQ renders
More renders to come soon. The case is currently in the initial design phase.
Case dimensions will be 325mm x 160mm x 35mm (12-3/4" x 6-1/4" x 1-3/8"). The original Kishsaver is about 370mm x 180mm x 35mm (14-1/2" x 7" x 1-3/8"). If this seems tall, keep in mind that the case bottom is only 7mm thick. Add to that 5mm standoffs and about 23mm total for a cherry MX switch with an R1 cherry-profile keycap on it, and you've got 35mm, which is within a few millimeters of a low-profile TEX aluminum case. The difference with this case is the way the keycaps sit below the bezel, as shown in this original Kishsaver photo:
I really tried to carry over the most unique and appealing design elements of the Kishsaver. The rear bezel is much wider than the others and includes the famous Model F "pencil holder" bar. The front bezel is recessed to the same level as the keycap bottoms, 5mm below the top surface. The fillets along the front and rear edges are close to the original.
The main pocket has a few extra millimeters than most 60% cases on the length and width to accommodate keycap pullers.
I'm still finalizing details as far as cutout/hole locations for USB & DIP switches, as well as standoffs etc., but I would love to hear your feedback so far.
« Last Edit: Wed, 06 May 2015, 08:40:53 by njbair »
My boards:
Offline Badwrench
  • ummmm.....I forgot
Re: Plans for a Kishsaver-inspired 60% case
« Reply #1 on: Tue, 05 May 2015, 18:28:05 »
Looks really good.   :thumb:
Offline HPE1000
  • Keycap Paparazzo
« Reply #2 on: Tue, 05 May 2015, 18:49:58 »
I tried a IC like this a while back, there wasn't much interest sadly. A huge 60% case would be cool though. Maybe this time there will be more interest  :)
Offline Wilba
  • Keyboard Stuff Person
    • wilba.tech
« Reply #3 on: Tue, 05 May 2015, 18:53:18 »
VERY interesting! I like the keycaps sitting below the bezel... I'm doing something similar with my TKL case design.
I think you can play with the dimensions a bit and get the Kishsaver feeling without it being higher off the desk than other keyboards. I know it's initial design phase so I won't pick on your dimensions but 7mm+5mm figures seem a bit high. You could make it more like other tray cases and use 3mm base + 3mm standoffs, and still keep the high walls. 35mm seems good, though... that's only a touch higher than bottom row keycaps on a Filco, so maybe I am being fussy.
Let me know if you need a custom 60% PCB to go with it ;D
Offline DrHubblePhD
  • I am star stuff
« Reply #4 on: Tue, 05 May 2015, 18:56:05 »
Tip from the Koreans.... add more weight  :))
For real though, this would be sweet with a weight in the bottom, just make it a 10 lb 60%  ^-^
Offline njbair
    • nickbair.net
« Reply #5 on: Tue, 05 May 2015, 19:28:51 »
Thanks for the kind words, everyone!
No plans for an IC/GB yet...just doing a one-off for now. I should mention I worked for 8 years as a CNC machinist so I have good connections for hobby stuff.
My tradeoff is a few millimeters of height in exchange for a more rigid frame overall. We'll see how it works. But the 35mm height includes the pencil holder bar, which is at the same height as the row-1 keycaps so it might not be as tall as you think.
I'm hoping the extra bezel being made of solid aluminum will add enough extra weight to make sure this thing means business. I'll think it over, though.
My boards:
Offline JPG
  • Model F is my new passion!
« Reply #6 on: Tue, 05 May 2015, 19:59:31 »
Make it Stainless steel or brass then no need to add weight!
Very nice design btw!
Offline Charger
« Reply #7 on: Tue, 05 May 2015, 20:43:52 »
I was thinking about doing the same thing after I saw the thread over on desktority where a guy stripped down and polished his IBM 107 keyboard
Offline The_Beast
  • I like wood ಠ_๏
« Reply #8 on: Tue, 05 May 2015, 20:46:33 »
Make sure it fits the GH60....
Offline njbair
    • nickbair.net
« Reply #9 on: Tue, 05 May 2015, 20:54:48 »
I'm going to borrow the mounting hole pattern from a TEX aluminum case. Can you confirm that the GH60 works with that?
My boards:
Offline njbair
    • nickbair.net
« Reply #10 on: Tue, 05 May 2015, 22:13:05 »
Added some placeholder standoffs and a USB cutout. Here are some quick renders:
I'm going to let these render overnight and I'll update the OP with the high-quality versions in the morning.
« Last Edit: Wed, 06 May 2015, 08:27:42 by njbair »
My boards:
« Reply #11 on: Tue, 05 May 2015, 22:50:13 »
I'm going to powder coat this if I get one, I think it'd be awesome to have this for the 60% blue alps I'm planning.
Offline njbair
    • nickbair.net
« Reply #12 on: Tue, 05 May 2015, 22:56:13 »
I'm probably going to have it anodized.
Again, right now I've got no plans for this to go beyond a one-off. Definitely not before I get one in my hands to test. If not, I will definitely share all relevant plans, drawings, etc. so that anyone interested can make their own.
My boards:
Offline Yoe
  • Alps & ISO <3
« Reply #13 on: Wed, 06 May 2015, 01:33:21 »
Now that's a dream right there! Blue Alps Kish-ish... want!
Offline cooldiscretion
  • Convicted guilty of being totally rad.
« Reply #14 on: Wed, 06 May 2015, 01:50:40 »
Yikes I'm excited. Very cool stuff here. Great idea + design looks solid.
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #15 on: Wed, 06 May 2015, 02:29:39 »
Me likey.
Offline njbair
    • nickbair.net
« Reply #16 on: Wed, 06 May 2015, 08:41:38 »
Do you have any pics/plans? I'd love to see them.
My boards:
« Reply #17 on: Wed, 06 May 2015, 08:42:29 »
I was thinking of this exact thing the other day, but with a curved and bent sheet metal housing. I like your idea better. :thumb:
Offline njbair
    • nickbair.net
« Reply #18 on: Sun, 10 May 2015, 20:17:39 »
It's looking like having this milled is going to be pretty expensive. The material alone will be well over $50. Then, the nature of the design requires at least a 4-axis milling setup, which is more expensive than a traditional 3-axis.
I think I can get costs down if I split the case into parts. I'm not sure exactly how yet--I'll want to play with the model to determine the best way--but I think if I do this smartly I can greatly reduce the overall cost. If it doesn't look to wonky, this may end up being the way to go. I'll keep posting updates here as I try out different designs.
My boards:
