Author Topic: Very large keycaps? 1.2 to 1.5 cm  (Read 4211 times)
Offline Naweo
« on: Wed, 06 May 2015, 10:18:04 »
I am looking for a very large keycap fitting the escape key, very large (30-40-50% larger than the normal one.)
Does this exist?
Thank you
Offline Data
Re: Very large keycaps? 1.2 to 1.5 cm
« Reply #1 on: Wed, 06 May 2015, 11:24:06 »
Large in which dimension(s)?
Offline Snarfangel
« Reply #2 on: Wed, 06 May 2015, 12:08:43 »
The fourth dimension. He wants them to last a long time.  :))
Offline Data
« Reply #3 on: Wed, 06 May 2015, 16:25:09 »
In that case I would recommend Titanium.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #4 on: Wed, 06 May 2015, 20:54:38 »
Depending on what you mean by large, if by widest then maybe this:  http://keyshop.pimpmykeyboard.com/products/specialty-custom-keys/flat-keys
If by tallest then maybe this:  http://www.pimpmykeyboard.com/deals/big-red-eject-key/
If you just want something gigantic then you can always take a blank keycap and glue something over top to make it huge lol.
Offline Naweo
« Reply #5 on: Thu, 07 May 2015, 04:18:13 »
Yes sorry, I mean large as in tall - height. This eject key would do, but I am not sure if the surface area is smaller than normal keys? Little detail, but if is not smaller in surface area then it is very good. Thanks. This is for cherry MX switches.
« Last Edit: Thu, 07 May 2015, 04:25:14 by Naweo »
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #6 on: Thu, 07 May 2015, 04:33:12 »
Hmmm... get some of the green stuff or whatever these keycap crafters use and build one up yourself a bit?
« Reply #7 on: Thu, 07 May 2015, 04:40:22 »
If you look here you'll see that the tallest caps are SA row 1.  The Big Red Eject looks to be row 3 SA (it has a flat top) so it's slightly shorter than the tallest at around 1.2cm but still a significant step up from OEM caps.
Where are you in the world are you?
Offline jacobolus
« Reply #8 on: Thu, 07 May 2015, 04:43:47 »
For anyone who wants real big keycaps, there’s always the Alps-compatible BigKeys keyboard:
