Author Topic: What cameras do you guys use/have?  (Read 73563 times)
Offline InSanCen
« Reply #150 on: Sun, 28 March 2010, 16:45:44 »
Well, I grabbed a few shots. I need sunlight. I managed an acceptable (Read as blurry, but not catrastrophic) shot, but I am not happy with it. I will see what I can do in the next few days. I ended up using a 28-80, as the 75-300 was just too much, but it is nowhere as sharp.
In the meantime...
Currently Using :- IBM M13 1996, Black :
Currently Own :- 1391406 1989 & 1990 : AT Model F 1985 : Boscom 122 (Black) : G80-3000 : G80-1800 (x2) : Wang 724 : G81-8000LPBGB (Card Reader, MY) : Unitek : AT102W : TVS Gold :
Project's :- 122 key 1389620 Wireless ESP32 :
'Pooter :- Xeon E5-2680v4 : Machinist MR9A : 2x16GB DDR4 : Radeon RX6600 : NVME & Spinning rust :
Offline Rajagra
« Reply #151 on: Sun, 28 March 2010, 17:03:57 »
In the absence of sunlight, a solid tripod, cable release or self-timer, and mirror lockup can do wonders. Macro shots are ones where mirror lock up can make a big difference.
Offline InSanCen
« Reply #152 on: Sun, 28 March 2010, 17:35:58 »
Quote from: Rajagra;167684
I have a tripod, soft tent and lights... but they are all in the attic, and it's 11:30PM... not going to happen if I want to live!
It's not the Tripod, as the body is sitting on the floor, and the lens is propped up with an X shaped piece of plastic. It's totally still when using Self Timer. The problem is the depth of field. 1mm of movement, and it's out of focus. I have a feeling that I will need to mount the subject on a Slide rail somehow, and crank it in, .5mm at a time.
Offline Rajagra
« Reply #153 on: Sun, 28 March 2010, 22:07:56 »
I have some similar gear (at least as far as the Gitzo carbon fibre tripod, quality ballhead and macro focusing rail.) But what's the deal with the flash setup? Does the pop-up flash trigger the slave flashes? Do you have to use manual settings?
That hand strap looks like a luxury item.
Offline InSanCen
« Reply #154 on: Mon, 29 March 2010, 15:30:55 »
I am building my own Ring light for Macro. I am waiting on parts. I would like Canon's wireless ring flash, but that is yet another expensive item that is not essential. It does indeed need another flash (I use the 550EX but others will do as well) on the camera as master (Or using an off camera cord) to trigger the Slave unit, but this part is wireless.
My tripod will do as well...  (Not my pic). Having had a play, I think I can get some pictures without using a slide rail. I'll grab some shots in the week on my day off.
The lighting on picture that was a high power LED torch (Very white light) with a Flash Diffuser bag over it. I like the effect, and will rig a mounting device of some sort to hold 3 of them.
Offline InSanCen
« Reply #155 on: Mon, 29 March 2010, 15:39:28 »
That is gorgeous! Mine will be a more Ghetto affair, with "Angel Eyes" (1x58mm ID, 1x 120mm OD) and a scuffed up CD cake lid. Planning on using 2 Li-Ion batteries in Series for power/weight/capacity ratio.
I do have access to a fully equipped (if manual) machine shop, and am, by trade a Welding Engineer.... hmmmmmm. If i get some time I may have to play with some Alu...
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #156 on: Mon, 29 March 2010, 16:12:03 »
Heh! As I have no more access to the lathe etc. right now,
and the old ring-light doesn't fit on my new camera,
I probably have to do some Ghetto DIY myself...
Perhaps a advanced version of this?
A Ghost From The Past
Offline MsKeyboard
« Reply #157 on: Mon, 29 March 2010, 16:26:39 »
Just donated an old Canon S80 to the inlaws, and replaced it with a Panasonic ZS3..........Really like it!  Much easier to carry around than the Canon T1i.
Offline InSanCen
« Reply #158 on: Mon, 29 March 2010, 17:00:12 »
Yup Ripster, that's how i am doing it, but with 2 rings. Will cost pretty much nothing even if it turns out to be full of fail. Mounting it to a 58mm UV filter so I can use it natively on my 750-300 and 28-80, and via a 55-58mm step-up on my 55-200.
As for carrying an SLR round, I know almost nothing else. I had no interest in pictures before I got a Job in a Camera shop repairing and Building PC's. A condition of working there was you had to *know* how to use a Camera. I got given a Zenit XP, some film, and a bit of tuition. It snowballed from there. When I went to modern SLR's, I had the chioce, but having a "sticky" thumb, then Canon's dial being right under the forefinger was easier for me than the Nikon.
I still own some esoteric gear, including an insane 300mm lens for M42 that proudly announces it was made in the DDR. It weighs more than my 70-200 f2.8 L IS did, and nearly as much as the 170-500. I also have bellows for it. Focusing on that is a pretty scary affair. I also dabble with Medium format (Bronica SQAM 6x6), and intend to run off some shots of my Daughter on 120 FP5 which will gove my rusty lightmeter skills a run. Throw in some Fuji Velvia action on the Original EOS1 35mm, and it rounds out my collection, excluding the really old, but interesting camera's I have lying round.
« Last Edit: Mon, 29 March 2010, 17:10:22 by InSanCen »
Offline InSanCen
« Reply #159 on: Mon, 29 March 2010, 17:12:03 »
I saw that linked at another forum webwit... awesome pictures, very much along the lines of what I aspire to do with Macro. I plan on trying a reversing ring setup next, as I have some M42 Jena's kicking round looking for a purpose in life.
Offline InSanCen
« Reply #160 on: Mon, 29 March 2010, 17:24:37 »
If you want Trashy, then it's The Sun, or, for full on Trash, with added tit's, The Daily Star.
Offline Rajagra
« Reply #161 on: Mon, 29 March 2010, 18:00:50 »
Quote from: webwit;167901
I you want trashy, watch the weather forecast. Not sure what this lady is trying to say.
"High chance of precipitation."
Offline InSanCen
« Reply #162 on: Tue, 30 March 2010, 02:37:54 »
Quote from: ripster;167931
Ouch!  Gentlemen, there's a lady in this thread.
Edit:  Whoah Daddy, take that back.  Now I have to figure out how to add the Daily Star to my Google home page next to the Wall Street Journal and NY Times.
Like I said, Trash, with Added tit's.
Open all 3 pages, Tools, Options, General, Use Current Pages.
Offline itlnstln
« Reply #163 on: Tue, 30 March 2010, 07:56:53 »
Like anybody with the name "Peaches" is going to be a good role model for kids.
What?  I read the articles, too.
Offline clickclack
  • Board Chow EXTRAORDINAIRE
« Reply #164 on: Wed, 31 March 2010, 06:48:18 »
I really dig that guys work too, its comforting for some reason =)
Although a bit different his stuff reminds me of this guy's-
862+ keyboards and counting!   R.I.P.ster          Vendor link ->Clack Factory
Offline clickclack
whoops!
« Reply #165 on: Wed, 31 March 2010, 23:48:00 »
I forgot this pic, haahaa (it was my whole point)-
Offline clickclack
« Reply #166 on: Thu, 01 April 2010, 01:32:45 »
Quote from: ripster;168208
Just saw him on the ABC news and found out he uses a $75 6MP Sony Point and shoot.  Reminds me that  photography is all about taking lots of pictures of interesting stuff.
Thanks for bringing his work back up, I wanted to show an employer his stuff but I couldn't for the life of me remember where I saw it or anything about it (yes my memory sucks).
As far as his gear goes, model photography many times is much easier with smaller format equipment. Aside from the obvious reason of restricted space the scale veiw is much easier to achieve with an extended depth of field, which small format equipment easily provides.
Quote from: ripster;168556
Nice!  I was wondering how he got the dirt to fly.  Motorized model.
The first frame reminds me - Lightroom 3 beta 2 just added tethered laptop support - Woohoo!
Believe it or not the model didn't move more than an inch or two in each photo. The wheels were spinning but the dirt, snow, and rain were pumped and or sprayed as well as what little the cars tires would "rooster tail" on their own.
-80+% of the model was made or modded from scratch, as well as all of the immediate scenery.
-working lights, as well as a inertia reel brake lights that would also make the brake disks glow as if they were under hard braking.
-Photos were taken in 2005 with a canon point and shoot.
-All taken on the same day in different parts of the city on that same wooden board and saw horses.
-The shots were taken hand held while also holding and operating the transmitter (for the R/C car) as well as working the leg operated pumps. Yes all at the same time for each shot, talk about stress =P
The most fun I have ever had making a model and shooting it =D
I would love to do that again =)
« Last Edit: Thu, 01 April 2010, 01:36:46 by clickclack »
Offline Specter_57
« Reply #167 on: Fri, 02 April 2010, 10:13:07 »
Now...*this* would be fun to play with...
http://dvice.com/archives/2009/12/man-builds-his.php
Spec_57
Offline itlnstln
« Reply #168 on: Fri, 02 April 2010, 10:32:04 »
When I saw the first set of pics, I didn't realize the car was a model.  Good work.  You might want to re-evaluate the snow shot if you do another one, though.  A few things in the pic don't quite add up.
Offline clickclack
« Reply #169 on: Fri, 02 April 2010, 18:35:34 »
Quote from: Specter_57;168874
Spec_57
You know whats funny about that?
We used to make pinhole cameras out of brass, in either a panno format or 35 and not only did they look more steamhack, but they are what people used to do. Actually the really funny thing is old semi belows med format or TLR cameras as well as TS large format cameras all look a million times more steampunk. I am sure in part this "romantic" old world technology played a role in the ideas behind steamhack/steampunk.
As far as that particular camera goes, the soldering job and off kilter geometry hurts it a bit (considering some of it is spot on exacting) but really it's the big honkey plastic knob that hurts/ruins the appeal for me. Having said that I always enjoy seeing people handcraft/modify stuff.
Offline InSanCen
« Reply #170 on: Sat, 03 April 2010, 01:32:43 »
steampunk camera
I'll post something up after work you may like. I can still get film as it uses standard 120 roll, and I can use colour if I am willing to forgo frame numbers and block the light holes at the back. It is original, and works perfectly.
(and yes, I use it as a camera, although remembering movement is mirror image is fun).
As a caveat to my last post... the Huge lens was actually made in the GDR, and is a Pentacon 300/4. I have an M42 adaptor for the EOS on the way. Should be... interesting... with a 2x teleconverter on it, and a 1.6x crop for APS-C sensor size... 960mm effective. There is plenty of weight in the lens (2.5KG) to damp most shake, although I suspect that a lot of shots will be Tripod Only.
Offline clickclack
« Reply #171 on: Sat, 03 April 2010, 02:55:04 »
Quote from: ripster;168879
ClickClack, nice.  Didn't know that you took those pics.
Hahaa, thanks. Yeah I posted it initially in a missleading way, it made me feel nostalgic =P Those were good times for me.
I won a contest with those and got a job as a lead theme park model maker by having it in my portfolio and on top of that it gave me legitimate (and relatable) exposure to the SFX shop photographers who pushed me to go 100% digital for my photography. It was only then that I understood how inefficient I was in doing film and digital for clients. Outside of clients though I am never giving up film entirely.
Quote from: itlnstln;168881
Perhaps, but I was just too thrilled with being able to do all of it convincingly on the same day near my home. And as a side note all of it was edited initially on a lunch break on my bosses computer (so I could make the deadline) with whatever windows xp came with, I think it was called "paint". I just remember it was a PITA to edit. If I ever had any quibbles about photoshop they ended that day. I have always wanted to go back an edit it, but sometimes when a project is done, it's done.
In 2007 it was used as a model at Mitsubishi's California headquarters when they were unveiling there new rally car and new Lancer Evo. I spilled baking soda, baby powder, alum, and talc on the way to display it. My cars cloth black interior looked a bit more abstract for months but it never smelled better =P
Quote from: ripster;168884
California salt flats near LA.
Gotta use your imagination when you look at ART!!!
I would kill for this product!!!!!!!!!!!!!!!!!!!
I must have it! I am working at a gallery right now and I think this would be the ultimate gift for my cowerkers and boss! I would also love to have it on the reception desk as a display for the guests =)
Salt flats near LA? That sounds neato, I should go look that up!
Offline InSanCen
« Reply #172 on: Sat, 03 April 2010, 17:24:20 »
Here you go... You like old camera's?
This was made between 1946-1949, and as I said, I still use it.
I present to you... The Ensign Ful-Vue. It was a cheap camera, lot's of Kids had these back then. But I love it. Linkage to a bit more information.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #173 on: Sat, 03 April 2010, 17:35:57 »
@ClickClack: It's all in the URL's ;)
|||My other keyboards :
x
Offline Rajagra
« Reply #174 on: Sat, 03 April 2010, 17:43:14 »
Quote from: JaccoW;169326
What a great site, they even have something for Webwit!
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #175 on: Sat, 03 April 2010, 20:31:38 »
Heyyyy...I recognize that guy. And the logo in the corner!
George does a good show. Any US/International networks carry The Hour?
kishy.ca
Offline clickclack
« Reply #176 on: Sun, 04 April 2010, 02:23:38 »
Quote from: InSanCen;169324
This was made between 1946-1949, and as I said, I still use it...
What a wonderful example of a pre TLR camera! I love how its so simple yet robust, almost tank like (like its gunna headbutt its subject). Thanks for the informative link too! =)
There is something so calming and romantic when shooting and planning with vintage equipment.
Even when they are just sitting on your shelf they are inspiring, so much more magical.
Offline clickclack
« Reply #177 on: Sun, 04 April 2010, 02:26:26 »
Haahaa, thank you!
I much appreciate it and I can't wait to get em!
hmmm... another thought, maybe I should use it on some of the students that cant critique to save their lives.
=D
« Last Edit: Sun, 04 April 2010, 02:27:20 by clickclack »
Offline InSanCen
« Reply #178 on: Sat, 10 April 2010, 01:28:43 »
Quote from: clickclack;169416
Planning in integral to the use of this. The edges are very soft, and give a nice effect when used in portraiture. No movement whatsoever though, I think the shutter speed is fixed at about 1/30. The beauty is 60" enlargements that done correctly, look like they are straight out of the Old West (I did a themed "Cowboy" shoot at one point, and is one of my more popular requests for a portrait, though unless they can sit perfectly still, I use the Bronica). I mainly use Ilford XP2 in it, and make educated guesses as to the Frame Number, as the aperture you normall read that through is now covered over, as the cover only blocks out reds and is suitable for B&W oly.
Offline InSanCen
« Reply #179 on: Sat, 17 April 2010, 03:19:14 »
Quote from: ripster;172901
Photoshop CS5 upgrade is $199.   Upgrade time since I'm on CS2, the oldest version eligible for the upgrade.
Yep, I pay for software.  After having a recording engineer as a roommate once I even pay for my music.  Archaic, I know.
I have been stashing cash away for this too. As I make money off it, I don't have a problem paying for it, and CS5 looks to be a very nice upgrade from 4.
Offline Shintsu
« Reply #180 on: Sat, 01 May 2010, 22:18:03 »
My main camera is a Canon EOS 300D. Love Canon, I'd sooner use a disposable than a Nikon...I also have a secondary camera I use for Craiglist pictures and videos - a Konica Minolta Dimage Z2 (I'm actually amazed at how good the video quality is, better than most camcorders I've seen until you get into some real big bucks). I used to have a Rebel G as my first SLR and then I bought a Rebel Ti body and finally got into the DSLRs with my 300D. I don't take as many pictures as I'd like though, mostly of my car when it's clean. Personally I don't rely on what any clown says on some website to tell me what camera I should use, and Nikon also irks me because they won't stop showing that idiot Ashton Kutcher in their commercials (I really hate him...) too busy advertising gimmicks like touch the screen to take a picture instead of actual quality features...I'll take picture and build quality over gimmicks every time.
Mouse:
Logitech G500
Keyboard:
Saitek Eclipse Red edition
Offline Shintsu
« Reply #181 on: Sun, 02 May 2010, 04:34:31 »
Quote from: ripster;178007
Canon for compacts and camcorders.  Nikon is the SLR choice of the pros though.
Professional what? Professional Poseurs? Huh, I guess the three photography studios I've been to in my area that have multiple photographers and large studios that do photo shoots for universities and all the schools in a six county area aren't professionals since they're using Canon cameras. I can sure tell you all those people who look at their pictures go "OH MY GOD, someone took these with a Canon - I can somehow (Magically?) tell the difference!" :rolleyes:
Image quality between Canon and Nikon with DSLRs are COMPLETELY indiscernible - if you say otherwise you're just lying to argue. I'll agree to that. Take two IDENTICAL photos with similar featured cameras (Two base models or two top end - not top end of one vs bottom end of another or anything) and scale them to the same size - in a blind test you won't definitively get a consistent answer. A photo journal did one in the late 80's between Canon, Nikon, Minolta, and I think one other - none of their readers could tell. The only difference between brands is price, build quality, and how easy it is to use and outfit. It's the same today, it hasn't changed - it's just digital instead of film now. I have a cousin who has had three Nikon cameras and all of those POSes broke and she couldn't use them anymore. I think she has a Samsung camera now or something. My father still uses a Canon Powershot he bought in I think 2001 or 2000 and pictures still look great and it works good as ever, just not 12 megapixels or anything (2 to be exact). Cousin bought her first Nikon in 2003 and went through them and had to buy a new one in '04, then in '05 and for awhile she just used her cell phone for pics (I never said they were picky on quality...)
This is the problem I have with you Nikon people - if anyone ever asks about cameras in even a general sense the first bash some idiot always has to quip is "HUR HUR NIKON FUR DE PROFSIONALL CUZ I TAK PRO PICZ OF MAH KAT !!!!11ne1337!" whereas I don't see Canon people starting it (at least on average). I wouldn't have said anything about Nikon if some idiots on the front page didn't feel the necessity to do just what I said they always do. It's the same problem you get with Mac users. They pop up out of no where like little trolls "HUR HUR MAC R TEH BEST HAH I IZ L33tZ WINNR!!1!1on1" even though no one asked for their snarky little comments. Stupidness like this means no respect for you, and since silly trolls never learn it will continue to happen.
Besides, Nikon cameras are cheaper than Canon on average because they're cheaper built. Entry Nikon DSLR is 6.3 megapixels, entry Canon is 8 megapixels - when we're comparing new DSLRs this does begin to matter as downscaling will have higher quality the larger the RAW image. I prefer Canon's method of grading quality of lenses better too, Nikon's don't make sense to me - not that I care all that much since I won't own one. It's easy to tell the highest quality Canon lenses are the L-series typically with the white and red on the lens.
But I've come to realization that much of society is so foolish they need to assert their superiority to you in anyway they think possible, even if no one cares or if what they assert as a sign of superiority is simply a difference of opinion. Someone will say "Hey I just bought this new car and I love it" and the "better" person will come by and quip "HAHA, my car cost what three of your cars would - WHAT ARE YOU POOR? HAW HAW HAW". It's this self-believed superiority complex that so many people have that they can't STFU about what stupid BS they think is better. How about a thread asking a question about a PC issue? "HA you should've bought a Mac - I obviously have more money than common sense and it's what I did and TV and Movies say I'm cool if I do it so take that you conformist - I'm so different because I assert my difference by doing the same thing all the other people who are different do". It happens with cameras, computer stuff, cars, everything. This idea of difference is simply conformity of non-conformity - even though it never amounts to anything, the bloody fools.
I'll sum it up with a picture that captures this concept nicely (I've rambled [ranted?] along far too long anyway, but I'm famous for long posts - anyone want to tell me I'm inferior for using a membrane keyboard? Here's your chance...because I love typing on mine)
« Last Edit: Sun, 02 May 2010, 04:38:21 by Shintsu »
Mouse:
Logitech G500
Keyboard:
Offline Rajagra
« Reply #182 on: Sun, 02 May 2010, 05:10:29 »
20% of them, anyway:
80% of professional photographers use Canon.
Oh, wait, this isn't the trolling thread.
Offline clickclack
« Reply #183 on: Sun, 02 May 2010, 05:36:30 »
My chest hurts and I can't fall asleep so why not post something, ya? =)
Quote from: Shintsu;177988
Ouch, then you would be missing out, heehee =P
There was a famous fashion photographer who would use a disposable, ballz baby gots ballz... ok and maybe skills =D
I Personally I don't rely on what any clown says on some website to tell me what camera I should use, and Nikon also irks me because they won't stop showing that idiot Ashton Kutcher in their commercials (I really hate him...)
Haahaa! Yeah I am not the biggest fan of his, although I won Nikons/ Ashtons national photography contest. So I can't be hating too much ;)
I know, those successful stupid ipod/iphone/ipad people... oh...we were talking about nikon... no wait!
I think most would too, well... more or less. I think I would rank versatility and ergonomics and intuitive features first though, but then I shoot for income.
Edit: Ooooo, I just saw your other post....
« Last Edit: Sun, 02 May 2010, 05:38:28 by clickclack »
Offline clickclack
« Reply #184 on: Sun, 02 May 2010, 07:00:22 »
Oooo this ones a dooozey! Lets see if I can impart some of my 4:40 am loopiness into this post....
Quote from: Shintsu;178052
Haahaa, ouch! Actually if you say "Poseurs" just right (and improperly) it sounds elite!
How seriously did you take his comment again? Wait were is that darn pic of Akbar when you need it??? And some of the studios I have worked for and do switched to Nikon recently. And that's only because one had something the other one didn't at that time. Many are just sticking with some MF or a Hassy setup for "studio" shots.
Says you but that doesn't neccessarily mean it's always significant or even matters. But then again I do this for a chunk of my income.
OMG!!!! Haahaahaaa... "Blind test", I think I am getting your sense of humor now! That's damn hysterical!!!! lolz =D
That is one funny factoid to mention doncha think? In the 80's when we shot "film" the "film" was the same in any camera you put it in. The main differences was the lenses that you used and the difference then was far less descernable than it is today.
I dissagree, are you surprised though? I think you buy more into a system now than ever, because everything in that "system" is more or less optimized for it. I don't price is a significant factor between Canon and nikon now, but it certainly is between their competitors. I also think build quality is moot at this point also. A pro level body is certainly more than capable in any brand for the most part (little features aside). Ease of use can vary even within ones own brand. The digital difference between brands (photodiode, interpolation, and management wise) can be very significant.
Bummer, but atleast I know who I won't be lending gear too =P
Any chance they throw emm up on ebay for cheap, gotta feed the addiction ya know, thats a pretty impressive rate to run through them for a non Pro! =)
I kindly go "ahem" not "HUR, HUR" but I just might switch now! And btw you would go crazy for the puss..."ahem" cat shots that I take. Oh no you dih-ent!
Then you need to get around more my pixelated friend =)
Good thing there are no cliffs around =P
Ooooo I musta missed something in those first posts... *scurries off to go reread*
Hey, kinda like Japanese tourists at Disneyland! HI Snap-Snap, checks pictures, Snap-Snap!
(insert Soup Nazi picture...)
hmmm... I must have miss that memo...My wallet never seemed to agree with that, nor has my experience.
Some years off there son =) Perhaps its best that you don't look up the new cameras or age old trends.
What about other types of interpolation... like idunno... the more popular one "upscaling"? But I thought image quality didn't matter? You can only swap that one so many times in one thread. But I feel ya man, emotions run strong *hits chest and throws up a peace sign.
Aside from a circumnavigating overly glorified red/gold pinstripe hint that Canon/Nikon use the extra "L" designation perhaps does help the people who don't know or understand what makes the characteristics a good or versatile lens. We tend to look at specs, and then test them. There are plenty of "lower end" lenses in their respective lineups that spank their higher end lenses. not that I care all that much since I won't own one. It's easy to tell the highest quality Canon lenses are the L-series typically with the white and red on the lens.
You do strike me as the pesrson who would need an extra hint to know the difference though. j/k Sorry, but I had to though, that one was way too easy to pass up
You certainly have proved you point in that respect =)
You indeed have proved that well
No worries, there is always someone who cant sleep too (like me today)
Is that membrane in the form of a Model M keyboard? If not, don't worry nobody is perfect =P
Offline Rajagra
« Reply #185 on: Sun, 02 May 2010, 14:12:54 »
Quote from: ripster;178125
I was just talking about the lenscap.  Pinch cap FTW!
Trudat.
« Last Edit: Sun, 02 May 2010, 14:28:44 by Rajagra »
Offline ricercar
  • mostly abides
« Reply #186 on: Sun, 02 May 2010, 16:06:54 »
Quote from: Rajagra;178059
All treads are for trolling. This is Geekhack.
Offline InSanCen
« Reply #187 on: Sun, 02 May 2010, 16:40:32 »
It will never cease to amaze me that people will argue to the death about gear.
Yes, I use Canon. The sole reason for that is that my thumb is "sticky", and using the wheel at the back of the Nikon's is far harder than the wheel on the front of the Canon's.
When I started out buying my first non-manual SLR, I was working in a Camera shop, and had a choice of whatever the hell I wanted at a heavily discounted price. I chose the Canon for the above reason. I have worked with both canon and Nikon sporting pro's, and my feeling is "just shoot some damn pictures, n00b".
Offline Rajagra
« Reply #188 on: Sun, 02 May 2010, 17:08:23 »
If I could afford to buy a complete set of Nikon gear and a complete set of Canon gear, I would. And I'd still take more bad pictures than good ones. :rofl:
Offline EverythingIBM
« Reply #189 on: Sun, 02 May 2010, 17:13:07 »
Quote from: Rajagra;178268
Canon is better; nikon uses funny layouts that are nonsensical.
Offline InSanCen
« Reply #190 on: Sun, 02 May 2010, 17:59:19 »
Quote from: ripster;178261
Sorry about your thumb.  Are you a tree  frog?
Not unless someone spikes the drink I'm not... ;-)
Offline izzypizzy
« Reply #191 on: Fri, 21 May 2010, 23:57:58 »
I have a Canon 20d and a Canon 5d, as for lenses I have a 24-70 2.8L, a 135mm 2.0L, and a 200m 2.8L with the built in lens hood.
I have no say on the topic of Canon vs Nikon, I've never used a Nikon, but I'm sure they're both fairly equally good. I'm very unlikely to ever give Nikon a shot though, because once you invest thousands into lenses, it's unlikely that you'll ever switch brands.
Offline Rajagra
« Reply #192 on: Sat, 22 May 2010, 00:37:25 »
If anyone thinks Nikon or Canon are the limiting factor of how good their photos are, I have only one thing to say.
(Be sure to zoom in.)
(Source.)
« Last Edit: Sat, 22 May 2010, 00:39:32 by Rajagra »
« Reply #193 on: Sat, 22 May 2010, 02:47:47 »
Quote from: ripster;185650
Happy Nikon User.  Be sure to zoom in!
The nikon person on the right (right as in facing the photo) has strabismus.
Offline Rajagra
« Reply #194 on: Sat, 22 May 2010, 13:33:18 »
Quote from: EverythingIBM;185661
Oddly, I never noticed.
Offline Pylon
« Reply #195 on: Mon, 28 June 2010, 12:10:26 »
I have a Nikon D40 with the kit lens and a 55-200VR.
I also have a film N90 I got for $35 that I've run some film through(Ilford HP5 mainly, along with some other films). I don't use it anymore, but just to say, Fujifilm Velvia looks awesome.
Offline D-EJ915
« Reply #196 on: Mon, 28 June 2010, 23:05:37 »
I have a EOS 1D now and I still hate that damn wheel, pisses me off lol.  Luckily with a manual aperture lens I never have to deal with the damn thing haha
Offline chimera15
« Reply #197 on: Tue, 29 June 2010, 02:25:27 »
A couple weeks ago now I got a Nikon D3000 for around $300.  It's got some bad reviews, and doesn't have live view or a movie mode, which is stupid for a digital camera, but it's not bad for a 10mp dslr.  It's almost point and shoot prices.  Was my first dslr, so.  I'm pretty happy with it, it does raw which I've never had  a camera do before.  I'm still learning all the settings for it.
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline nraymond
« Reply #198 on: Wed, 30 June 2010, 22:41:44 »
I own a Pentax K200D (couple of years old), and also have a number of Pentax film bodies (they can all use the same lenses, and all the lenses I have both MF and AF are backward and forward compatible).  Great cameras.  K-7 and K-x are the current DSLRs, excellent bodies, but my K200D currently does everything I need.
Offline Cabbs
« Reply #199 on: Thu, 01 July 2010, 12:47:01 »
I've had my 500D for about 18 months. The only two lenses I have are the 18-55 IS kit lens and 50MM f/1.8. For the money there's no reason not to have the 50MM, but it's a big long for indoors on a crop sensor.
