Author Topic: USB to PS2 Adapter?  (Read 6960 times)
Offline JunkFace
USB to PS2 Adapter?
« on: Tue, 12 May 2015, 14:52:28 »
Hey I have a KVM at work that I would like to plug either my HHKB or a Filco Minila into.  The only problem is the KVM is PS2 and my keyboards are USB.  I'd like to always be able to type on my main PC and also control other machines I'm working on with the Filco.  It would be ideal to use a couple of 60% boards so I don't have to move the big, clunky, horrible, rubber dome HP monstrosity that is PS2.  I brought in a model M but that thing is even bigger and desk space is a real constraint.
Anyway I'm having some trouble finding out how to do this online.   There are some converters around (in the UK for 50 pounds) but I have a teensie laying around not being used so I'd rather just do it myself.
I see tons of PS2 to USB teensie projects but haven't found a USB to PS2.
Does anyone know if this is possible?
If you could point me in the right direction that would be great.  There are converters out there so it must be possible.  Can anyone help out?
Offline JunkFace
Re: USB to PS2 Adapter?
« Reply #1 on: Wed, 13 May 2015, 08:25:30 »
Anyone know if this can be done?
Offline azhdar
  • Praise the AZERTY god
« Reply #2 on: Wed, 13 May 2015, 08:33:35 »
why don't you use this things. I remember getting one with my QFR.
Azerty Propagandiste
Offline JunkFace
« Reply #3 on: Wed, 13 May 2015, 10:21:42 »
I've tried using these and they don't seem to work.
Offline wlhlm
« Reply #4 on: Wed, 13 May 2015, 10:25:56 »
They are passive and require support from the keyboard itself.
http://deskthority.net/wiki/Adapter
Offline JunkFace
« Reply #5 on: Wed, 13 May 2015, 10:32:04 »
Is there a way to get around this then?  I'd think there would be some way to configure a teensie to allow this.  Somehow....
Offline user 18
« Reply #6 on: Wed, 13 May 2015, 10:53:21 »
Active adaptors do exist, but they tend to be expensive, and would be notably more complex to make work. I'm not sure off the top of my head exactly what would need to be done, but it's a lot more complex than the passive version.
If you have the space, it's probably much easier to get a QFR or similar and use its passive PS/2 adaptor than to try and hack an adaptor together. Likely, you would need to use a microcontroller to emulate a USB host device, translate the incoming signals into proper PS/2 interrupts, and send those interrupts via a PS/2 keyboard interface -- none of which is native behaviour for a teensy. This isn't my area of expertise by a long shot, so it's possible I'm off, but it's definitely not as easy as going in the other direction.
Using a TKL board like a QFR gives you significant space savings over a Model M. You could also check and see if any iteration of the Poker has PS/2 capability, although I don't believe it does.
Avatar by ashdenej
Offline Hzza
« Reply #7 on: Wed, 13 May 2015, 10:56:14 »
The original PokerX is native PS2 IIRC; I recall hasu saying he kept one around to test his firmware.
Not sure of any of the other variants are though.
Offline hasu
  • @tmk
« Reply #8 on: Wed, 13 May 2015, 20:36:11 »
On USB side you can use Circuit@Home USB Host Shield and its library to host USB keyboard.
https://github.com/felis/USB_Host_Shield_2.0
And as for PS/2 you will be able to find and reuse codes from PS2AVR.
https://github.com/showjean/ps2avrU
Just buy Arduino Leonardo and HostShield to start developping!
Offline ricercar
  • mostly abides
« Reply #9 on: Wed, 13 May 2015, 22:01:30 »
nevermind.
« Last Edit: Wed, 13 May 2015, 22:04:34 by ricercar »
Offline VoteForDavid
    • Vote For David
« Reply #10 on: Wed, 13 May 2015, 22:02:55 »
Going the other way, this is a non-issue.  There is no need to DIY anything, its $5 on ebay.  These things get pitched out all the time, your IT department may even have one laying around they'll donate to the cause. If the little plastic adapter like shown above doesn't work then you want the kind with two PS/2 ends and a blob in the middle with the "active" converter chip.  When PS/2 was what everybody had, the newfangled USB keyboards were often able to be used with a passive converter like azhdar showed.  Since "nobody" uses PS/2 and it's a bit of a constraint anyway, the newer USB boards won't play nice with PS/2 anymore.
Going from a USB keyboard to a PS/2 KVM is proving shockingly hard to find cheap.  Here's an example of the expensive variety
http://www.overstock.com/Electronics/Minicom-by-Tripp-Lite-PS-2-to-USB-Converter/6697341/product.html?cid=143974&track=CSEShopping&utm_source=ecn&utm_medium=cse&utm_campaign=ecn&srccode=cii_13736960&cpncode=41-47176680-2
This bothers me.  I looked.  I read discussions on other forums.  If your keyboard was not MADE to work with a passive PS/2 adaptor, it may never do. Apparently going TO PS/2 is a hassle, and usually people aren't as picky as GH members about using a decent keyboard ;)
Oooooh yes!  A question: JunkFace, are you restarting the KVM when you plug in your keyboard?  It may work with the simple passive converter, but PS/2 is not hot-pluggable and your stuff might need to re-initialize with a keyboard plugged in, to recognize it.
« Last Edit: Wed, 13 May 2015, 22:28:39 by VoteForDavid »
Jesus loves you.
