Author Topic: Has anyone ever colored an HHKB case  (Read 4314 times)
Offline Overside
« on: Wed, 13 May 2015, 16:45:57 »
Basically I don't like the boring greyish white of my HHKB type-s case anymore and want to try some new exciting colors but I'm not sure which way is the best to paint/dye a plastic keyboard case...or if i even should attempt it.
If anyone has done it before pleeeeease let me know how it worked out.
Thanks,
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
Re: Has anyone ever colored an HHKB case
« Reply #1 on: Wed, 13 May 2015, 16:51:46 »
People have used idye poly in the past to success with their keycaps, I would be hesitant to dye my HHKB, though. As it's much more risky and not replaceable.
I have never seen it done with an ABS case before. You'd be much better off getting it hydro dipped or something of that nature. The only cases I seen dyed are the IBM cases that are PBT.
« Reply #2 on: Wed, 13 May 2015, 16:55:13 »
How is dying the case more risky than the caps? The stock caps aren't that easy to come by AFAIK.
And are you sure it's ABS? If so, I know idye poly is best used with PBT.
Could always plastidip it. Not sure if hydro-dipping is the best option since I don't know the process so I won't comment on that.
Offline exitfire401
  • The Force is Re/\l
« Reply #3 on: Wed, 13 May 2015, 16:56:32 »
Because the case is ABS
Offline billnye
  • ability man
« Reply #4 on: Wed, 13 May 2015, 16:57:12 »
Someone that was selling clacks on eBay a while ago had a pink HHKB case and it looked pretty cool I think.
« Reply #5 on: Wed, 13 May 2015, 16:58:41 »
Meaning the case is more prone to plastic deformation if heated?
Offline Air tree
« Reply #6 on: Wed, 13 May 2015, 16:59:23 »
You can get sets of HHKB caps on demand, as they are still in production.
And the case is ABS for sure. I don't know a good dye for ABS. You can use iDye on abs at a lower temp and it should be fine. *Should
But if you mess up on the case, you can't get another one without a lot of work.
Offline exitfire401
« Reply #7 on: Wed, 13 May 2015, 17:01:12 »
Exactly.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #8 on: Wed, 13 May 2015, 17:02:56 »
Quality spray paint is fine. I've done a ton of mice and QFRs (some multiple times). I like the look of the HHKBs at home, so haven't done one yet. Maybe when I get really bored...
« Reply #9 on: Wed, 13 May 2015, 17:03:35 »
Exactly.
Got it. Thanks for educating me exitfire and air tree.
Montana!
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #10 on: Wed, 13 May 2015, 17:04:17 »
Montana!
You are SO hip-hop. People need to know this.
Offline Overside
« Reply #11 on: Wed, 13 May 2015, 17:19:47 »
Do you happen to know who/where provides hydodipping for the average guy?
I feel like plastidip adds like a layer of paint that peels off, i want the paint to be more or less part of the plastic itself, would spray paint be better at that? don't know too much about painting :/
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
« Reply #12 on: Wed, 13 May 2015, 17:52:59 »
You can buy hydro dip kits from ebay all day and they are extremely easy to use!!!
I've been kicking the idea around for my HHKB and if I ever get around to it, I'll post pics/write up!!!
Offline FoC_Tow
  • Brokehlicious
« Reply #13 on: Wed, 13 May 2015, 20:33:06 »
Montana!
Molotow!
Honestly great paint tho for any kind of artwork not only writing...
