Author Topic: 1TB Samsung 850 Evo - $336.34  (Read 2370 times)
Offline missalaire
  • Great Finder of Great Finds
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
Re: 1TB Samsung 850 Evo - $336.34
« Reply #1 on: Fri, 15 May 2015, 04:41:28 »
http://www.amazon.com/Samsung-2-5-Inch-Internal-MZ-75E1T0B-AM/dp/B00OBRFFAS
So you've never heard of the current disaster relating to all current 840 EVO SSD's?
The Model you've linked to uses that exact same type of memory, so be aware of the money lost due to perhaps the current OCZ style of company that can not fix their mistake of using poor quality, cheap memory as storage devices.
Word to the wise, if you want complete safety in storage, relating to SSD's - ALWAYS buy an Intel based product because it comes with the BEST replacement warranty compared to the current thieves at Samsung Central.
« Last Edit: Fri, 15 May 2015, 04:43:45 by Elrick »
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #2 on: Fri, 15 May 2015, 04:52:19 »
I'm assuming the 840 pro models aren't affected? I've always steered clear of the bottom of the barrel SSD's so I'm hoping paying a bit more has helped this time.
Offline Lpwl
  • lpwl.bigcartel.com
    • My O-ring Store
« Reply #3 on: Fri, 15 May 2015, 05:00:01 »
No worries !
840 PRO : MLC NAND
vs
840 EVO : TLC NAND
850 EVO : TLC V-NAND
Offline missalaire
« Reply #4 on: Fri, 15 May 2015, 09:22:48 »
The 850 EVO series aren't affected afaik and apparently Samsung came out with firmware updates for the 840 EVOs.
Offline Elrick
  • Hype Master
« Reply #5 on: Fri, 15 May 2015, 21:39:21 »
Then you should visit OCN and see the results of that so-called "fixed" firmware  ;D .    Many still have severe drops in speeds despite their Magician software loading into memory to constantly refresh the old data.  Samsung's problem is that they used poor quality TLC NAND which is atrocious and not worth risking any of your work on.
People only found out about their problem product some years later after it was released everywhere, and more people still kept buying their dodgey gear.   Word to the wise, don't buy any of their SSDs ever, because you have other manufacturers that have a fine history of quality hardware releases such as Intel, plus their warranty is far superior than Samsung's when it comes to anything related to their SSD's.
« Last Edit: Fri, 15 May 2015, 21:42:35 by Elrick »
Offline Vanilla
  • 110% Snuggable
« Reply #6 on: Sat, 16 May 2015, 01:13:00 »
I can vouch for what elrick says personally.
I have an 840 EVO and noticed after refreshing my windows rating score due to new GPU drivers that it had dipped to a new score. That low score came from HDD performance which had dipped to the lowest score. Read up on that issue and applied the band-aid update and it went back for now.
Ehhh I got it for dirt cheap stacking on discounts. All good things must come to an end nonetheless.
