Author Topic: How to ensure switches are straight  (Read 2125 times)
Offline bcredbottle
« on: Fri, 15 May 2015, 13:13:50 »
I replaced two switches on my ****ty Adesso numpad but after I soldered in the new switches I noticed they were not aligned with the rest of the keys. Does anyone have experience or tips regarding this?
Offline njbair
    • nickbair.net
Re: How to ensure switches are straight
« Reply #1 on: Fri, 15 May 2015, 21:00:03 »
I'm not sure how the spacing works out, but if you have a long keycap with multiple stems and the spacing is right, you could use that to hold the switch in alignment as you solder it. Just a guess.
My boards:
Offline VoteForDavid
    • Vote For David
« Reply #2 on: Fri, 15 May 2015, 22:19:20 »
Remove the solder
Rotate the switches to what looks about right
Solder one joint
Check orientation
If minor correction is needed, heat the solder and rotate switch again
If correction is not needed, finish soldering, test, and button it up.
Jesus loves you.
Offline jonathanyu
« Reply #3 on: Fri, 15 May 2015, 22:42:17 »
use a ruler to push the switch
Offline fknraiden
« Reply #4 on: Fri, 15 May 2015, 22:43:59 »
I ran into this problem on mine, I just made sure to keep it in place before adding solder, the top someone mentioned will work too
Offline Zukoi
  • ****posting at 90wpm
« Reply #5 on: Sat, 16 May 2015, 11:08:30 »
They should snap in place if they are straight. I would apply pressure from the stem side and use a ruler or something to ensure they are inline with everything else.
