Author Topic: NeXT Keyboards?  (Read 1945 times)
Offline Norman_the_Owl
NeXT Keyboards?
« on: Sat, 16 May 2015, 05:49:16 »
Were any of them mechanical?
I know apple keyboards from roughly the same time used alps switches, but what about ol Jobs' NeXT keyboards?
There was a non-adb version with no name for the connector, and an ADB version. Has anyone encountered one?
I could buy one for science i suppose.
Offline t13
Re: NeXT Keyboards?
« Reply #1 on: Sat, 16 May 2015, 08:35:48 »
The first gen were, and were fantastic ALPS. Best sheer *typing* keyboard I've used. Gen 2 (ADB) were rubber dome.
I've got one first get (bought it from http://www.blackholeinc.com), and I'm still messing with an Adruino system to get it to work right. The wiring is right, but the programming needs some work (it won't properly do a CMD-TAB to switch programs, for instance). A basic primer on this (you'll need a DIN-5 connector) is found here: https://learn.adafruit.com/usb-next-keyboard-with-arduino-micro.
If anyone knows of an updated driver (within the past year or so) for this, I'd love to hear about it. Thanks!
Offline hasu
  • @tmk
Re: NeXT Keyboards?
« Reply #2 on: Sat, 16 May 2015, 09:37:31 »
My Next keyboard(Non-ADB) also has black Alps switches.
https://geekhack.org/index.php?topic=41989.msg1480364;topicseen#msg1480364
I could convert it successfully with bcg's converter based on the adafruit work. I don't remember any apparent problem,
https://github.com/tmk/tmk_keyboard/tree/master/converter/next_usb
Re: NeXT Keyboards?
« Reply #3 on: Sat, 16 May 2015, 11:32:16 »
Alright, thanks guys.
I'd never heard of them before yesterday (I don't know how i hadn't) and there was very little info available.
Offline t13
Re: NeXT Keyboards?
« Reply #4 on: Sat, 16 May 2015, 22:43:14 »
Do you know of any guides for converting this so it can be compiled via the Arduino application? I had no problem with the Adafruit code; this is a few steps of complexity greater. Thanks!
