Author Topic: Is this a slider/dome or a different switch type?  (Read 1636 times)
Offline Blaise170
  • ALPS キーボード
    • XYZ
« on: Fri, 22 May 2015, 23:09:35 »
Got this the other day. Has a spring underneath the keycap. Looks like it is probably a cheap slider over rubber dome but it doesn't feel bad to type on.
Offline SamFlynn
  • Location: From inside the hive, behind your eyes, and off the grid...into the Black.
  • Type until there is no need...
    • Firefly Online Forum
Re: Is this a slider/dome or a different switch type?
« Reply #1 on: Sat, 23 May 2015, 00:39:11 »
I wonder where that keyboard has been, yuk...oh you were asking about a switch type: I say yes, it is definitely a place where a key goes, my money is on membrane...any other pictures?
<Press Any Key>
« Reply #2 on: Sat, 23 May 2015, 00:42:24 »
Rubber dome.
« Reply #3 on: Sat, 23 May 2015, 01:14:29 »
That is most probably a Key Tronic foam and foil switch.
If there is a model number and it starts with an E and then four or eight digits then it is definitely a Key Tronic keyboard.
They are capacitative so they should have n-key rollover. The foam discs have sometimes deteriorated too much in older keyboards so that they no longer work - but there are ways to make new foam discs at home, or buy from eBay.
« Last Edit: Sat, 23 May 2015, 01:20:17 by Findecanor »
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #4 on: Sat, 23 May 2015, 02:45:57 »
Yep looks exactly the same to me. Keyboard is a Harris-Lanier 301-2100. The only other marking besides serial number is this one. F/N: ET3182A51-C
