Author Topic: question about old keyboard  (Read 2781 times)
Offline ether22
« on: Sat, 23 May 2015, 11:05:29 »
hi.
i have an old hp pavilion keyboard, purchased maybe around 10 years ago (came as part of a home pc set). looks like this (but with printed keycaps) (yes iso layout) (with correctly installed keycaps) (picture found on the internet)
http://i.imgur.com/Bg2OGgI.jpg
can you tell me what keyboard this is and whether it is a so called 'mechanical keyboard'?
Re: question about old keyboard
« Reply #1 on: Sat, 23 May 2015, 11:10:53 »
Typically OEM systems come with rubber dome keyboards.
Offline E TwentyNine
    • Some of My Keyboards
« Reply #2 on: Sat, 23 May 2015, 11:16:33 »
Not seeing a wire, but if there is one that's an HP KB-0228 (whatever the ISO model number is).  If it's not it's the wireless version of that.
https://www.google.com/search?q=KB-0228+HP&tbm=isch
It's rubber dome, but it may be a metal backplate which is the better kind of rubber dome, but still rubber dome.
Not mechanical.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #3 on: Sat, 23 May 2015, 11:21:56 »
I see TONS of these in thrift stores and e-cycler. I get no special feels from it. Sorry.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #4 on: Sat, 23 May 2015, 11:40:10 »
As a general rule, almost every keyboard with media keys and sleep keys and all that stuff is a cheap rubber dome keyboard, NOT a mechanical one.
