Author Topic: Picked up a Cherry MX Red keyboard for cheap... Is it any good?  (Read 4405 times)
Offline ThunderPeel2001
Hello all. I'm completely new here. I was looking for a forum filled with knowledgeable keyboard enthusiasts and I decided to give this one a try. I hope my question for assistance falls within what's acceptable here!
I'm not sure if people are too familiar with the QPad MK-85, but I just got my hands on one. From my research I see it was released back in 2012, and at the time is got lots of good reviews, like this one: http://www.vortez.net/articles_pages/qpad_mk85_mechanical_gaming_keyboard,8.html and still has good reviews on Amazon. The biggest complaint at the time was its price, and indeed, it still usually sells for �100+, even if not for the full �134 it originally retailed for.
I was lucky enough to put up one, brand new, at the MCM Comicon here in London. I was wondering what people's thoughts are on this old Cherry MX Red keyboard. Have things like the Ducky Shine, the Das Keyboard, and the Corsair K95 overtaken it?
Looking online it appears that the QPad MK-85 is just a rebranding of something sold by other manufacturers. For example, the XArmor-U9BL (seen here: http://blog.controlspace.org/2010/08/review-xarmor-u9bl-illuminated_11.html) and the iOne Scorpius U9BL (seen here: http://www.ione-usa.com/ione-scorpius-u9bl-backlit-mechanical-keyboard.html) look IDENTICAL. Is this a bad thing?
Thanks for any assistance understanding why there's others on the market that look identical, and whether or not modern mechanicals are substantially better.
« Last Edit: Sun, 21 June 2015, 10:56:35 by ThunderPeel2001 »
Offline absyrd
  • CPT HYPE PADAWAN
Re: Picked up a super-cheap Cherry MX Red keyboard... Is it any good?
« Reply #1 on: Sun, 24 May 2015, 09:10:44 »
It is fine for that price.
I looks identical to the iOne because I believe they are the OEM.
The ducky shine will be of better quality, so you can choose to just flip the one you got (don't think you'll get much more than you paid) or just keep it as a test run for your first mech kb.
« Reply #2 on: Sun, 24 May 2015, 09:53:25 »
Thanks for the quick and helpful response. I'm surprised I couldn't get more on eBay, they still sell on Amazon for £97 (http://www.amazon.co.uk/dp/B00C40HSY0/ ) but maybe that's Amazon being weird.
Could you tell me what the difference would be with a more modern mechanical keyboard? How could they be worth nearly 3x the cost of this one?
Thanks.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #3 on: Sun, 24 May 2015, 10:22:59 »
If you search GH, you'll find that iOnes have been said to have QC issues.
In general, the one you linked seems to be one of their more gimmicky, plastic feeling models.
The Blackwidow from 2012 is notorious for being a POS. Not sure if this is the same.
« Reply #4 on: Sun, 24 May 2015, 12:43:46 »
I´ve searched through the forums and it seems that the QPAD has different internals to the Blackwidow, XArmour and Scorpius. For a start the QPAD has full USB nkey rollover and onboard memory. It´s not just an OEM of those other keyboards, but an OEM of something else, I guess.
« Last Edit: Sun, 24 May 2015, 12:49:32 by ThunderPeel2001 »
Offline user 18
« Reply #5 on: Sun, 24 May 2015, 13:07:35 »
Note that the QPAD is also identical to MaxKeyboards 'Nighthawk' series of boards. They're solid boards, all you're really missing would be some lighting modes that you might find on a newer Ducky or something. They're all built on pretty much the same tech (MX), so it doesn't matter much anyway.
Keycaps are okay, IMO, but a nonstandard bottom row makes things difficult for getting new ones. You need a 6u spacebar, which is the real issue with new sets.
Avatar by ashdenej
« Reply #6 on: Sun, 24 May 2015, 18:22:02 »
Yes, thanks. From more research it does seem the QPad MK-85 is identical to the MaxKeyboard Nighthawk in literally every single way apart from the caps on the Q and the Spacebar.
Aside from *looking* like the Blackwidow and the XArmour, they are very different it seems.
« Last Edit: Sun, 24 May 2015, 18:45:04 by ThunderPeel2001 »
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #7 on: Tue, 26 May 2015, 13:56:34 »
iOne is the OEM for all of these. There are more out there I'm sure.
Max Keyboard Nighthawk, Rosewill Apollo, Monoprice Macro, Qpad MK-85, QUMAX Xarmor U9W, etc.
Offline nightdriver
  • life is like t. rex
« Reply #8 on: Tue, 26 May 2015, 18:41:37 »
i thought MaxKeyboard made their own higher quality PCB for it?  could be wrong...
Offline user 18
« Reply #9 on: Tue, 26 May 2015, 18:47:16 »
That may or may not be true. I've never opened my Nighthawk, so I wouldn't know for sure.
Avatar by ashdenej
« Reply #10 on: Wed, 27 May 2015, 05:48:34 »
I could be wrong, but I believe this idea comes from people making the same mistake as absyrd. I've read in a few places that the MaxKeyboard is identical to the others mentioned here. Maybe one day someone will open one up and we'll know for sure :)
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #11 on: Wed, 27 May 2015, 06:39:13 »
Hey... I'm happy to be wrong. I take it you are going to keep it and drive it? In that case, you can open the sucker up. :p
Offline nightdriver
« Reply #12 on: Wed, 27 May 2015, 18:01:28 »
seems like it comes from maxkeyboard themselves.
http://www.overclock.net/t/1291381/max-mechanical-keyboard-nighthawk-x8-x9
« Reply #13 on: Thu, 28 May 2015, 18:13:07 »
I guess it's possible that Max Keyboard make this... It's the QPad MK-85... possibly the MK stands for Max Keyboard?
« Last Edit: Sun, 14 June 2015, 14:39:41 by ThunderPeel2001 »
« Reply #14 on: Sun, 14 June 2015, 14:28:39 »
I've been doing a bit of research to try and get to the bottom of all the different OEMs. Some of these are still on the market, so hopefully this is useful to somebody.
Basically, the main difference from the "bad" keyboards (like the iOne Scorpius U9BL) and the "good" keyboards (like the Max Keyboard Nighthawk series) appears to be this: Full N-KEY Rollover over USB, onboard memory, and a PS/2 connector. These are the features that indicate different internals.
The following are "bad" keyboards -- (identified by: no full N-Key rollover with USB, no onboard memory):
iOne Scorpius U9BL (apparently known as XArmour instead of Scorpius in some territories -- literally the same keyboard, both are branded iOne, although it seems that they're often mistaken for being two different keyboards)
Whereas these are "good" (identifiable by: full N-Key rollover with USB, onboard memory):
QPad MK-85
Rosewill Apollo RK-9100xR
Finally, I came across a third one, which is different to all the others:
Monoprice 9181
This only has 64-key rollover with USB -- so clearly has different internals.
Externally they all look completely identical -- apart from the lack of a braided cable on the iOne model -- but they're clearly very different internally.
Contrary to some of the posts here, I would find no evidence that the QUMAX Xarmor U9W (which is actually a Wireless keyboard) or the Razer Blackwidow (which is completely different from what I can gather) are the same to any of these.
Happy to be corrected on this, but hopefully my research is of some use!
« Last Edit: Sun, 21 June 2015, 10:54:41 by ThunderPeel2001 »
« Reply #15 on: Sun, 14 June 2015, 17:42:04 »
Agh. Basically all my research was pretty much in this thread anyway. Ah well, I appear to have confirmed it's conclusions, either way!
https://geekhack.org/index.php?topic=37861.0
(Great thread!)
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #16 on: Sun, 14 June 2015, 19:01:11 »
Well the Xarmor U9W is a rebranded U9... The W just means it is wireless.
Offline Oobly
« Reply #17 on: Mon, 15 June 2015, 01:33:07 »
I'd use it as long as I can stand the stock keycaps, then either harvest the switches from it or sell it and buy a board with standard layout so you can put some decent keycaps on.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline exit
« Reply #18 on: Tue, 16 June 2015, 04:30:57 »
Max Keyboard does their own PCB which a few other brands such as Tesoro and Func use. Qpad mk-85 could use that PCB too.
Offline fknraiden
« Reply #19 on: Tue, 16 June 2015, 04:34:41 »
regarding that 6u spacebar, ivan's most recent PBT4 GB includes a 6u space.
« Reply #20 on: Sun, 21 June 2015, 10:51:59 »
I actually really like the keycaps on the QPad MK-85 :)
