Author Topic: Redscarf III fried?  (Read 3919 times)
Offline minh278
  • In life we will only fall, How far will we fall?
Redscarf III fried?
« on: Sun, 24 May 2015, 19:14:14 »
So i finished soldering it then plugged it in to test the rgb pcb then unlugged it. Now i cant get the pcb leds to even work did i fry it?
Keyboards:  Final Fantasy XI XIth Anniversary keyboard (topre 45g) | Realforce Rgb (topre 45g, Eva Noctilucous keyset) | Mionix Zibal 60 (mx black, Vortex doubleshot) | Greymark (white alps) | IBM model M (found in the trash!)
Re: Redscarf III fried?
« Reply #1 on: Sun, 24 May 2015, 19:47:33 »
we're going to need more info than that to properly answer this question.
For example: Did it work the first time you plugged it in (to test the RGB PCB) and then no any time after? What did you plug it into (just the computer? something else?) etc etc.
Offline minh278
« Reply #2 on: Sun, 24 May 2015, 20:00:35 »
It worked first time i plugged it in. Did not work any time after. I just plugged it into my computer in a usb 2.0 slot running windows 8
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« Reply #3 on: Sun, 24 May 2015, 20:03:26 »
try another keyboard. the driver could have crashed.
Offline minh278
« Reply #4 on: Sun, 24 May 2015, 20:18:46 »
Its working fine with my other keyboard(realforce). Maybe the problem was they were plugged in at the same time?
-note still not responding
« Last Edit: Sun, 24 May 2015, 20:27:45 by minh278 »
Offline Bromono
  • Wanabe Cicerone
« Reply #5 on: Sun, 24 May 2015, 20:51:39 »
hmm well uninstall your current driver and plug in the redscarf. the firmware should be plug and play.
Offline minh278
« Reply #6 on: Sun, 24 May 2015, 21:08:58 »
I plug it into another computer no response :O
-no driver install
Offline poog
« Reply #7 on: Sun, 24 May 2015, 22:38:51 »
if you hold escape as you plug it in does it load as a printer?
Offline minh278
« Reply #8 on: Sun, 24 May 2015, 22:51:07 »
I couldnt even get the layout on it yet and i just tried what you said but no driver to download(not even showing up)
« Reply #9 on: Mon, 25 May 2015, 03:25:18 »
does it show up in device manager at all?
The driver is for USB HID devices.
Offline minh278
« Reply #10 on: Mon, 25 May 2015, 11:23:24 »
When i unplug and replug i notice no change in device manager.
Offline Spopepro
« Reply #11 on: Tue, 26 May 2015, 01:00:16 »
Minh,
Assuming you have the firmware that is normally shipped with the board, RedScarf reports as "RedScarf III" in the "devices and printers" if working properly.  If it is in bootloader mode, it will report as "Generic/Text Only".
If it is doing neither, then there might be a conflict somewhere.  Try to unplug other devices to see if that eliminates a conflict (i.e. you are overloading the power that can be provided on a usb hub (another side note: a fully loaded RedScarf pulls down a lot of current!)).  If you go into device manager, is there anything that says "unknown device"?  If there is, try and right click and uninstall that.  Can you put the keyboard into eeprom programming mode (hold down esc while plugging the usb cable in) or firmware programming mode (hold down both esc and F1 while plugging the usb in)?  Either the caps lock led, or both the caps and num lock led should flash respectively.  If that's happening, the controller and the core software is still good, and you can reload and go from there.
It's unlikely you can fry a keyboard with normal use.
Offline minh278
« Reply #12 on: Tue, 26 May 2015, 08:41:25 »
So far it seems that holding escape does nothing(maybe due to me not having a layout programmed before?) same for f1 I cannot see and led change should i go and plug in some leds or would it be the ppcb ones. I am plugging it into a computer usb port that has no other source that would take away energy from it. I dont even think it is showing in device manager.
Offline Spopepro
« Reply #13 on: Tue, 26 May 2015, 13:43:53 »
The RSIII has two sets of LEDs: there's the RGB ones on the back that are pre-soldered, and the backlighting leds which you need to solder in.  If there isn't an led soldered under the capslock and numlock keys, you should consider doing so since the bootloader gives visual feedback through those LEDs.
Something else to try is holding down space and backspace together while plugging the USB cable in.  This clears the EEPROM, in case that's what's causing trouble.
Also: just making sure, but does the USB cable you are using work with another device?  Have you tried a different cable?
Offline minh278
« Reply #14 on: Tue, 26 May 2015, 17:39:48 »
The usb cable i am using works with a external hard drive. I installed sip sockets and plugged leds into those, they wont light up when i am pressing the esc and f1, esc, backspace and spacebar. I dont think im doing it wrong but if its not too much work could someone upload a video maybe?
Offline Spopepro
« Reply #15 on: Tue, 26 May 2015, 17:43:54 »
just to make sure:
1) Unplug keyboard
2) Press ESC + F1.  Do not let go.
3) Plug in USB Cable
4) Let go of ESC + F1.
If Capslock and Numlock leds are not blinking, then yes, there's another issue since you can't access the bootloader.  If they are blinking, then awesome-I can tell you exactly what to do next.
Offline minh278
« Reply #16 on: Tue, 26 May 2015, 18:32:16 »
Its as dead a door knob. I even tried flipping the leds in-case polarity got weird. No blinking whatsoever :O
-I really appreciate your help though, it gives me hope that i may not have an expensive paperweight.
« Last Edit: Tue, 26 May 2015, 18:37:31 by minh278 »
Offline Spopepro
« Reply #17 on: Tue, 26 May 2015, 19:42:04 »
Bummer. Do you have a multimeter?
Offline minh278
« Reply #18 on: Tue, 26 May 2015, 19:59:54 »
I can get access to one
Offline hasu
  • @tmk
« Reply #19 on: Wed, 27 May 2015, 01:49:36 »
I don't know exactly what this PCB is and how many LED are soldered on.
But many LED on PCB reminds me power problem, are you sure PCB is fed enough power?
Or USB connector comes off PCB?
No reactions from PC at all? if so this comes to mind.
Offline minh278
« Reply #20 on: Wed, 27 May 2015, 03:09:19 »
The usb connector seems firmly rooted(soldered) on the pcb- No visible damage to that area
The connector is enough to power a external hard drive. I will retry plugging into the back of the motherboard (should be way more than enough power)
-No leds are soldered on at the moment except the two i stuck in the sip socket and those that are already on the pcb at the caps lock and the num lock
