Author Topic: Keyboard like Noppo Lolita Spyder but with Cherry switches  (Read 3935 times)
Offline loki993
« on: Fri, 29 May 2015, 06:34:19 »
Are there any keyboards out there like the Noppo Lolita Spyder but has Cherry switches, I dont want Kailh switches? Or just something with a very low profile case and exposed/ floating keys? TLK or even 75 or 60 percent is good too. Oh and it would be nice if it didn't break the bank.
reference in case someone hasnt seen it
http://www.amazon-associate.com/Mechanical-Keyboard-Noppoo-Lolita-Spyder/dp/B00T1P6F1S
« Last Edit: Fri, 29 May 2015, 06:36:32 by loki993 »
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: Keyboard like Noppo Lolita Spyder but with Cherry switches
« Reply #1 on: Fri, 29 May 2015, 06:41:06 »
Maybe you could vote for them to drop the Varmilo VB87M on Massdrop again. Low profile TKL with Gateron switches
« Reply #2 on: Fri, 29 May 2015, 07:39:53 »
If you don't mind a red keyboard with black keys: the Arachnid Recore. Cherry MX Red. Really inexpensive also.
Offline loki993
« Reply #3 on: Mon, 01 June 2015, 06:36:02 »
Im not sure Reds may be a little light for my taste but the rest is fine. Where do you get that though? There also seems to be a flashget brand of the same keyboard but that seems to be hard to find as well.
Offline MAR82
  • Keyboard Addict
« Reply #4 on: Mon, 01 June 2015, 07:30:47 »
The cheapest board I can think of that would fit with what you're looking for would be the FlashGet G600. I paid around 45€ for it, however I can't really recommend it seeing how cheap the board was (but it does use Cherry MX switches)
Offline loki993
« Reply #5 on: Mon, 01 June 2015, 08:04:08 »
Whats wrong with it, why couldnt you recommend it?
Offline MAR82
  • Keyboard Addict
« Reply #6 on: Mon, 01 June 2015, 08:14:50 »
I wouldn't say that there's anything wrong with it, other than mine uses MX Black, and I'm not a fan of that switch. It's just that it's a cheap board and the driver (not really needed) don't give the feel of a nice quality keyboard. But if you still get it knowing that, it should be fine. just don't get it and be expecting very much from it
