Author Topic: GMK QMX-Clip  (Read 15128 times)
Offline LXXXIX
  • Just remember all caps when you spell the man name
GMK QMX-Clip
« on: Mon, 01 June 2015, 08:53:38 »
Apparently GMK is trying out some pretty cool new stuff.
https://www.youtube.com/watch?v=W-hq_91BEX4at
Would anyone be interested in these? I know I would.
What do you all think? :cool:
Re: GMK QMX-Clip
« Reply #1 on: Mon, 01 June 2015, 08:56:20 »
Just FYI, there's been some discussion on this in this thread about GMK Uniqey. I'm personally interested in anything new and weird so it'll be cool to see how this works. I'd love to get my hands on some samples.
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
Re: GMK QMX-Clip
« Reply #2 on: Mon, 01 June 2015, 08:56:30 »
My bottoming out though...
Offline LXXXIX
Re: GMK QMX-Clip
« Reply #3 on: Mon, 01 June 2015, 09:01:11 »
TY I didn't find anything through the search. My apologies. :'(
Re: GMK QMX-Clip
« Reply #4 on: Mon, 01 June 2015, 09:09:45 »
You're fine, there's no worries. Just an FYI, not a "you're a bad thread maker". :)
Offline Peddamann
Re: GMK QMX-Clip
« Reply #5 on: Mon, 01 June 2015, 11:05:10 »
ill get a sample from GMK "in the next few weeks" :)
Offline gameaholic
Re: GMK QMX-Clip
« Reply #6 on: Mon, 01 June 2015, 11:30:23 »
interested
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
Offline asgeirtj
Re: GMK QMX-Clip
« Reply #7 on: Mon, 01 June 2015, 16:19:04 »
I like o-rings for I disike clack and like shorter travel so I'm interested.  So am I getting this right, this dampens the clack but ALSO dampens the upclack? (which is what is new with this) and it's only works with pcb mount?
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
Offline Peddamann
Re: GMK QMX-Clip
« Reply #8 on: Mon, 01 June 2015, 17:07:13 »
yep u understood that perfectly fine :) i think i will make a small comparison video with and without that clip when the sample arrives here and share my experience with it... im really curious how that sample looks like... hopefully a complete little switch tester with :D *dreams*
Offline Jokrik
Re: GMK QMX-Clip
« Reply #9 on: Mon, 01 June 2015, 20:09:11 »
sound absorption ? never
Clicky is the way of life :p
Offline HPE1000
  • Keycap Paparazzo
Re: GMK QMX-Clip
« Reply #10 on: Mon, 01 June 2015, 20:10:30 »
One day you will realize how superior linear switches are.
Offline digi
  • elite af tbh
  • keyboard game on fleek
Re: GMK QMX-Clip
« Reply #11 on: Mon, 01 June 2015, 20:16:28 »
Switch condoms?!?! I like!
Offline Jokrik
Re: GMK QMX-Clip
« Reply #12 on: Tue, 02 June 2015, 04:18:45 »
One day you will realize how superior clicky switches are.
ftfy bro
Offline Synjin
Re: GMK QMX-Clip
« Reply #13 on: Tue, 02 June 2015, 04:20:23 »
Topres don't click but they do Thock :p  :p
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: GMK QMX-Clip
« Reply #14 on: Tue, 02 June 2015, 12:00:45 »
I was going to see if I couldn't get some of these to send out with Miami Nights if it goes through. Just a couple per order or something, just so they can be tried out.
Offline Latin00032
Re: GMK QMX-Clip
« Reply #15 on: Tue, 02 June 2015, 12:06:06 »
I wanted these qmx-clip things to try out but it looks like they only work if there isnt a plate-mount.
Re: GMK QMX-Clip
« Reply #16 on: Tue, 02 June 2015, 12:08:23 »
This is a cool idea, hopefully GMK goes for it.
Offline Neo.X
Re: GMK QMX-Clip
« Reply #17 on: Tue, 02 June 2015, 15:39:57 »
Can't wait for this. The down stroke and up stoke noise always bothers me.
But I can't figure out how they reduce the upstroke noise, in other words, what's the difference between this and landing pad.
Hope there will be a actually typing video for this.
All those keyboards will be lost in time....
Re: GMK QMX-Clip
« Reply #18 on: Tue, 02 June 2015, 20:51:28 »
It looks like its a plastic housing that clips onto the switch and has a rubber gasket attached to it that has a large enough hole for a round cap stem to fit through.  It looks like a much better solution than o-rings since it actually dampens at the point of contact of housing to housing instead of adding mushiness to the feel.  It seems like a more refined version of soft landing pads.
It should also be interesting to see how easy it is to mod the housing.
Offline luckyryan333
  • #There'sNoToolForTyping
Re: GMK QMX-Clip
« Reply #19 on: Tue, 02 June 2015, 22:14:32 »
That's what i'm thinking about.
No PaiN, No GaiN
How to order from Taobao from outside of China and WITHOUT an Agent
daily driver: C70 w/ Oblivion
on the way: d65_12/gmkblk_3
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
Re: GMK QMX-Clip
« Reply #20 on: Tue, 02 June 2015, 22:16:30 »
You are right, they only work on PCB mount without a plate
Offline rm-rf
Re: GMK QMX-Clip
« Reply #21 on: Tue, 02 June 2015, 22:27:36 »
well, either way i need one.
Re: GMK QMX-Clip
« Reply #22 on: Thu, 10 September 2015, 18:39:43 »
No PaiN, No GaiN
Offline quake4mhg
Re: GMK QMX-Clip
« Reply #23 on: Thu, 10 September 2015, 18:57:41 »
Shut up and take my money ;D
Offline baldgye
  • Will Smith Disciple
Re: GMK QMX-Clip
« Reply #24 on: Fri, 11 September 2015, 05:43:21 »
FYI
https://www.keychatter.com/2015/09/10/gmk-qmx-clip-sound-test/
It only really seems to work for reds and blacks, for the other switch type it just kind of muffles the sound... interesting
Offline Giorgio
Re: GMK QMX-Clip
« Reply #25 on: Sat, 12 September 2015, 07:47:14 »
Is a 60%without a plate any good?
Re: GMK QMX-Clip
« Reply #26 on: Sat, 12 September 2015, 14:20:02 »
All personal preference.
Offline nightdriver
  • life is like t. rex
Re: GMK QMX-Clip
« Reply #27 on: Fri, 26 February 2016, 21:58:20 »
does anybody know if these would work on the team wolf keyboards with the swappable switches?  it looks like the switch mount may be low enough to allow room, but maybe it's too close to plate mount anyway...
Offline blai5000
Re: GMK QMX-Clip
« Reply #28 on: Fri, 26 February 2016, 22:22:59 »
Doubt it would work.  The current massdrop page says it won't work with the Vortex Poker, which has the same mounting "height" as the team wolf board.  You'll need a true PCB-mount board for these clips.
Offline nightdriver
Re: GMK QMX-Clip
« Reply #29 on: Fri, 26 February 2016, 22:29:57 »
bummer.  the only plate mount i've got at the moment is a numpad.  may get some anyway just to try them out, though.
Offline blai5000
Re: GMK QMX-Clip
« Reply #30 on: Thu, 03 March 2016, 21:25:12 »
Soooooo anybody have any idea what boards are/can be PCB mounted, besides customs and G80s?
Offline munch
Re: GMK QMX-Clip
« Reply #31 on: Thu, 03 March 2016, 22:45:18 »
KBC Poker X as well. discontinued now though.
Offline Giorgio
Re: GMK QMX-Clip
« Reply #32 on: Fri, 04 March 2016, 16:42:31 »
Plum96 (it seems that only the older ones are pcb mounted)
https://geekhack.org/index.php?topic=39685.0
Remember that there are two models, the g80-3000 and the g80-1800.
« Last Edit: Fri, 04 March 2016, 16:44:45 by Giorgio »
