Author Topic: How to open Model M Terminal Keyboard?  (Read 6037 times)
Offline joerush25
« on: Fri, 05 June 2015, 13:43:26 »
How do I open this specific model?
Acrylic Tofu w/ Lubed Tealios
Offline thelectronicnub
  • drowning in keyboards
Re: How to open Model M Terminal Keyboard?
« Reply #1 on: Fri, 05 June 2015, 18:31:55 »
KUL ES-87 w/MX Greens
B/S/T Thread
« Reply #2 on: Fri, 05 June 2015, 18:48:02 »
Just remember that it needs to be "thin-walled" to get in there.
Auto parts stores are your best bet.
- D Trump 2026-10-24
Offline joerush25
« Reply #3 on: Fri, 05 June 2015, 20:29:57 »
can anyone find me a good ebay / amazon link for one of these screw drivers?
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #5 on: Fri, 05 June 2015, 21:54:42 »
Or just go to your local Lowe's or Home Depot and get one from the hardware dept for about $3 or less.
(I can't even remember now, it was very inexpensive.  If you get the Kobalt one from Lowes P/N #0338157, it can be used as-is!  It works well!  No ratchet or driver needed!)
« Last Edit: Fri, 05 June 2015, 21:57:29 by Snowdog993 »
Offline joerush25
« Reply #6 on: Fri, 05 June 2015, 22:35:59 »
Just bought this one
How did I do?
« Last Edit: Sat, 06 June 2015, 09:27:04 by joerush25 »
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #7 on: Sat, 06 June 2015, 06:28:20 »
Hard to say, it looks fairly thick at the head. If the terminal M is anything like the normal M, the bolt wells are quite narrow. I suppose you'll find out soon enough :p .
Offline njbair
    • nickbair.net
« Reply #8 on: Sat, 06 June 2015, 08:08:40 »
I bought this set from Amazon and it's perfect.
5 pc Metric Nut Driver Assortment https://www.amazon.com/dp/B000BQ4XPQ/ref=cm_sw_r_awd_.bVCvb0FYSAZT
My boards:
Offline joerush25
« Reply #9 on: Sat, 06 June 2015, 09:27:36 »
i accidentally had the wrong image. The one that was there before was one of the 3/16 one
Offline joerush25
« Reply #10 on: Sat, 06 June 2015, 09:28:14 »
no canada delivery.
