Author Topic: Introducing the Pokerdox  (Read 4155 times)
Offline smellz
« on: Mon, 08 June 2015, 21:10:12 »
This was my first ever custom keyboard project and it was a pretty awesome experience.
103103-0
It all started about six months ago when I was inspired by the keyboards that I saw people making on this site. I remember thinking that the planck was pretty cool but I wanted a number row. I decided that I wanted a 60% keyboard with some sort of matrix layout.
Once I got an ergodox, I realized that I really liked the top four rows of the layout; I also realized that it could fit in a universal 60% case (without vertical stagger or splitting of course).
The bottom row was something that I couldn't figure out for a long time. The layout that I used in the end was what I thought was the best looking and it also fits my thumbs quite well. The only downside is that the bottom row screw hole interferes with a stabilizer. When assembling, I decided just to omit that screw.
I got the plate made by Big Blue Saw, and the firmware is Hasu's TMK firmware, of course. The switches are black Gaterons, from Shadovved and hwood's groupbuy.
103107-2
103109-3
103111-4
103113-5
103115-6
103117-7
Fitting everything into the 60% case was a bit of a challenge. The teensy's usb port makes it just a bit too thick and it caused two keys to keep popping up (I didn't glue the switches in which was a mistake). So I took a router bit to the case and made room (Sorry no pics of this). The internal usb cable was causing a similar issue, but trimming of the switch and the cable eventually allowed everything to fit.
Thanks to everybody who helped me helped me along the way!
« Last Edit: Mon, 08 June 2015, 21:27:00 by smellz »
Re: Introducing the Pokerdox
« Reply #1 on: Tue, 09 June 2015, 03:06:15 »
More pics would have been great but that is an interesting board you've got.  Please can you share your keymap?  There are a lot of larger keys I'm intrigued by :)
« Reply #2 on: Tue, 09 June 2015, 06:03:44 »
I came in here expecting to see a poker cut in half. :P
Nice board though, also curious of your layout?
Offline smellz
« Reply #3 on: Tue, 09 June 2015, 06:21:19 »
Thanks! My layout is basically the same as what I use on my ergodox, which is probably quite different from what most people use.
103148-0
This doesn't show everything but should give a good idea of the two main layers. There's also a qwerty layer with a space bar in a better position for gaming, and an experimental layer that has f1-f12 and some mouse controls. I'll add the actual code from the firmware below.
I like having access to all the same keys you have on a normal 60% without putting punctuation keys in the bottom row or the function layer. Hence the '`' (or ~) and '\' keys being in the center columns.
Code: [Select]
#include "keymap_common.h"
const uint8_t PROGMEM keymaps[][MATRIX_ROWS][MATRIX_COLS] = {
    /* 0: colemak */
    KEYMAP(
        ESC,   1,    2,   3,   4,   5,  FN2, FN1,  6,   7,      8,    9,     0,    EQL, \
        TAB,   Q,    W,   F,   P,   G, LBRC, RBRC, J,   L,      U,    Y,  SCLN,   MINS, \
        LCTRL, A,    R,   S,   T,   D,             H,   N,      E,    I,     O,   QUOT, \
        LSFT,  Z,    X,   C,   V,   B,  GRV, BSLS, K,   M,   COMM,  DOT,  SLSH,   RSFT, \
        FN3, DEL, LALT, FN0,            ENT, BSPC,            SPC, LGUI,   FN0,     FN3 ),
/*1: qwerty gaming */
KEYMAP(
        ESC,   1,    2,   3,   4,   5,  FN2,  FN2, 6,   7,      8,    9,     0,    EQL, \
        TAB,   Q,    W,   E,   R,   T, LBRC, RBRC, Y,   U,      I,    O,     P,   MINS, \
        LCTRL, A,    S,   D,   F,   G,             H,   J,      K,    L,  SCLN,   QUOT, \
        LSFT,  Z,    X,   C,   V,   B,  GRV, BSLS, N,   M,   COMM,  DOT,  SLSH,   RSFT, \
        FN3, DEL, LALT, SPC,            FN0,  ENT,           BSPC, LGUI,   FN0,     FN3 ),
/*2: fn main */
KEYMAP(
        NO,      NO,    NO,    NO,    NO,   NO,  FN1,   FN1, FN1, PSLS,  PAST,  PMNS,    NO,    EQL, \
        NO,    PGUP,  HOME,    UP,   END, VOLU, CAPS,  PDOT,  P7,   P8,    P9,  PPLS,  SCLN,   MINS, \
        LCTRL, PGDN,  LEFT,  DOWN, RIGHT, VOLD,               P4,   P5,    P6,  COMM,    NO,   QUOT, \
        LSFT,   F13,   F14,   F15,   F16, PSCR,  DEL,    P0,  P1,   P2,    P3,   ENT,  SLSH,   RSFT, \
        FN3,    DEL,  LALT,   FN0,               FN0,   BSPC,             SPC,  LGUI,   FN0,    FN3 ),
/*3: f keys and mouse */
KEYMAP(
NO,    NO,    NO,    NO,    NO,    NO,    NO,    NO,    NO,    NO,    NO,    NO,    NO,    NO,    \
NO,    F1,    F2,    F3,    F4,    NO,    NO,    NO,    NO,    NO,  BTN4,  BTN3,  BTN5,    NO,    \
LCTRL, F5,    F6,    F7,    F8,    NO,                  NO,  WH_U,  BTN1,  MS_U,  BTN2,    RCTRL,    \
LSFT,  F9,   F10,   F11,   F12,    NO,    NO,    NO,    NO,  WH_D,  MS_L,  MS_D,  MS_R,    RSFT,    \
FN3,   NO,  LALT,    NO,                  NO,    NO,                  NO,  LGUI,   FN0,    FN3 ),
const uint16_t PROGMEM fn_actions[] = {
    /* Poker Layout */
    [0] = ACTION_LAYER_MOMENTARY(2),
    [1] = ACTION_LAYER_TOGGLE(2),
    [2] = ACTION_LAYER_TOGGLE(1),
    [3] = ACTION_LAYER_MOMENTARY(3),
« Last Edit: Tue, 09 June 2015, 06:25:06 by smellz »
Offline wlhlm
« Reply #4 on: Tue, 09 June 2015, 06:51:41 »
This reminds me of the Molecular (65%) keyboard layout ideas from Jack:
https://docs.google.com/forms/d/1438cNYMFXT7x3ISfVGosvlDlTgzEs17jJGb-97hddB0/viewform
Offline berserkfan
« Reply #5 on: Tue, 09 June 2015, 13:38:09 »
great work, but I think author should have gone with split layout to allow his shoulders to relax.
Offline smellz
« Reply #6 on: Tue, 09 June 2015, 17:41:10 »
I had been thinking of my layout for a long time and I found it interesting when I first saw Jack's idea. Very similar, but mine fits in a universal 60% case  ;)
Offline technomancy
« Reply #7 on: Wed, 10 June 2015, 03:22:47 »
Nice job; looks good.
Fitting everything into the 60% case was a bit of a challenge. The teensy's usb port makes it just a bit too thick and it caused two keys to keep popping up.
I had this problem too, switching away to an A-Star controller (using USB micro) helped a lot.
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #8 on: Wed, 10 June 2015, 03:39:58 »
Nice board.
With all these interesting layouts/builds, I really wish people would make short typing vids to show the advantages they gain.
Offline smellz
« Reply #9 on: Wed, 10 June 2015, 16:27:46 »
Thanks technomancy  :)
That's pretty cool. If I make another one (with a slimmer case), I will definitely get that controller.
Good idea. If I can think of a way to do this with my extremely limited photography hardware (just my phone), I will.
