Author Topic: Model Fs - Cheap XT and Terminal  (Read 4779 times)
Offline ch_123
Offline AndrewZorn
« Reply #1 on: Sat, 26 September 2009, 16:44:31 »
i thought terminal and XT always go really cheap
Offline ch_123
« Reply #2 on: Sat, 26 September 2009, 16:56:58 »
Depends. Sometimes they go for crazy money. Both are useful for modding projects, particularly the Terminal ones.
Offline ch_123
« Reply #3 on: Sat, 26 September 2009, 17:19:54 »
They're real-deal Model F ones, not some plasticky Unicomps. Although it seems that all you need to do to make them PC compatible is swap the cable.
Offline ch_123
« Reply #4 on: Sat, 26 September 2009, 17:55:46 »
Im pretty sure Kbdbabel has diagrams showing that the old terminal boards have different scancodes. Also, I'm the protocol would be quite different given the parallel vs serial communication methods. Even if the scancodes were the same, you're going to need an adaptor to convert the 15-pin to PS/2 or USB.
« Last Edit: Sat, 26 September 2009, 18:05:05 by ch_123 »
Offline AndrewZorn
« Reply #5 on: Sat, 26 September 2009, 18:30:54 »
well yeah, a cheap adapter would be preferable to paying so much for the AT board itself... more info?
Offline ch_123
« Reply #6 on: Sat, 26 September 2009, 18:47:23 »
All you need (in theory) is a regular PS/2 cable. This can be connected to the keyboard's controller. When you connect it this way, the keyboard behaves like a 84-key AT keyboard. You need some of the guides that describe the various setup procedures elsewhere. I believe it is more easy to do in Linux than with Windows, but JohnElliot wrote a nice Windows driver anyway.
Offline AndrewZorn
« Reply #7 on: Sat, 26 September 2009, 19:08:33 »
so i can order an XT model F and an XT to PS2 adapter (or splice a ps2 cable into the XT cable?) and use a model F on linux now, and kinda on windows?
Offline ch_123
« Reply #8 on: Sat, 26 September 2009, 19:16:19 »
No, we were talking about the Terminal ones. The XT ones require an active adaptor.
Offline ch_123
« Reply #9 on: Sat, 26 September 2009, 19:19:41 »
When you speak of this software fix for Linux... Does that require some kind of parallel adaptor?
Offline AndrewZorn
« Reply #10 on: Sat, 26 September 2009, 19:20:34 »
oh, i thought the terminal ones suffered the same problem, but okay, if i buy a terminal one, i can basically make it work in a few easy steps?
are they pretty close to the one everyone loves?
Offline ch_123
« Reply #11 on: Sat, 26 September 2009, 19:21:52 »
Theyre probably better in terms of build quality compared with the AT ones.
I'm sure Kishy or John Elliot can talk you through the steps. The latter certainly got his up and running with his PC.
Offline ch_123
« Reply #12 on: Sat, 26 September 2009, 19:48:47 »
And how easy is it to acquire or make one of these adapters?
