Author Topic: Keycool Hero 84 - info wanted  (Read 2360 times)
Offline flamf
« on: Wed, 10 June 2015, 13:19:56 »
Hi, I'm looking into buying the Keycool 84 currently on Massdrop. Now, I gather from a few posts, that the case is glued together, and I thus want to hear if anyone has had luck opening it and modding the switches? The older versions appear to have had PCB mounted switches, anyone know if this is still the accurate? Grateful for any assistance  :)
Re: Keycool 84 - info wanted
« Reply #1 on: Wed, 10 June 2015, 13:21:29 »
I don't have any info on the glued together case but I thought Keycool 84's were always plate mounted.
Offline flamf
Re: Keycool Hero 84 - info wanted
« Reply #2 on: Wed, 10 June 2015, 13:27:27 »
It seems I'm not terrible well-informed...
Offline flamf
« Reply #3 on: Wed, 10 June 2015, 13:28:16 »
But that's why I'm here, I suppose :D
Offline Defect
« Reply #4 on: Wed, 10 June 2015, 14:34:41 »
Old ones were plate mount with Cherry Stabilizers (Noppoo is plate mount with costar, and RACE was PCB mount).
Not sure about the Hero 84.
Offline flamf
« Reply #5 on: Wed, 10 June 2015, 14:45:51 »
Right thx, but have you had it opened, and if that is the case, does it allow switch-modding?
« Reply #6 on: Wed, 10 June 2015, 15:27:08 »
If you are referring to aftermarket plates that have cut outs that allow for switch opening without desoldering, I have never seen a stock plate that was made that way.
Offline flamf
« Reply #7 on: Wed, 10 June 2015, 15:45:21 »
Yes, just that, so the the only possibility would be if it was in fact PCB-mounted switches?
« Reply #8 on: Wed, 10 June 2015, 15:59:44 »
Pretty much with a stock board yes.
