Author Topic: Help with switch ID  (Read 1811 times)
Offline Blaise170
  • ALPS キーボード
    • XYZ
Help with switch ID
« on: Sun, 14 June 2015, 12:33:43 »
Looks like some kind of Alps mount dome but not sure.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: Help with switch ID
« Reply #1 on: Sun, 14 June 2015, 14:54:12 »
Well now that certainly is... unique...
Offline Firebolt1914
  • POM Overlord
« Reply #2 on: Sun, 14 June 2015, 15:11:04 »
Do you have any more pictures/access to the keyboard?
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #3 on: Sun, 14 June 2015, 18:54:27 »
FCC ID doesn't even have listings for A80. If it is Alps compatible I really want those keycaps... But if not I don't want to waste my money.
« Reply #4 on: Mon, 15 June 2015, 07:18:36 »
Metal backplate = most likely membrane.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #5 on: Mon, 15 June 2015, 09:54:53 »
Yeah I kind of figured it was membrane. I'm still hoping for Alps-mount though.  :-\
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #6 on: Mon, 15 June 2015, 09:55:22 »
Yes it have Alps mount, same keycaps for editing program were on some of their older Alps/Alps clone switch boards. Those model are just slider over domes. I don't see any reason all the non stabilized keys wouldn't work on any other Alps mount.
