Author Topic: Should I get the Keycool Hero 104 in All White or All Black?  (Read 3673 times)
Offline EscapeVelocity
  • Antiquarian
« on: Mon, 15 June 2015, 21:26:50 »
Black body & Black caps or White body & White Caps?
Im going for Kailh Black switches.
Im leaning towards All White.
Re: Should I get the Keycool Hero 104 in All White or All Black?
« Reply #1 on: Mon, 15 June 2015, 21:33:58 »
you need to slow down on all these new damn threads dude
  • Antiquarian
« Reply #2 on: Mon, 15 June 2015, 21:40:19 »
Im just spergy and over enthusiastic.  Sorry. :))
Offline heedpantsnow
  • Old enough to know better
« Reply #3 on: Mon, 15 June 2015, 22:01:01 »
All black. White shows dirt and grime too easy.
I'm back.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #4 on: Mon, 15 June 2015, 23:25:08 »
  • Antiquarian
« Reply #5 on: Mon, 15 June 2015, 23:54:54 »
Do you like yours Blaise170?  Could you comment on it?
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #6 on: Mon, 15 June 2015, 23:56:34 »
It's my favorite modern keyboard. It is as nice as the Ducky Shines I used to own and it is cheaper too. RGB was a nice bonus. Blue Kailhs feel fine, no issues at all with it.
  • Antiquarian
« Reply #7 on: Tue, 16 June 2015, 00:00:05 »
I have a Blue Kailh Thermaltake Tt Sports Poseidon ZX, they are nice. Looking for something a little quieter.
Offline Lain1911
  • God of the Wired
« Reply #8 on: Tue, 16 June 2015, 00:15:41 »
"Its alright, because it's all white" - Chris Rock.
Offline julayyy
« Reply #9 on: Tue, 16 June 2015, 00:32:13 »
I would go for the all white  :thumb:
QuickfireTK MX Reds         v60 mini MX Clears
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #10 on: Tue, 16 June 2015, 00:39:14 »
gotta get dat post count up doe
« Reply #11 on: Tue, 16 June 2015, 00:53:01 »
i've noticed. earned himself a spot on the ol' ignore list.
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #12 on: Tue, 16 June 2015, 01:00:29 »
Wow! You are approaching TERMINAL Velocity with all these keyboards you have dude!  What really makes me wonder, is are you collecting them or actually using them on a daily basis, I mean er, actually using one for over a day.
It takes time to get the feel of what you really like and appreciate using every single day.  I had a thread that kinda suggested, if you had to make a choice, and you only could have ONE keyboard, what would you choose?
I am seriously curious as to what you actually find to be the perfect keyboard for you.  You have a relentless pursuit and I think it's amazing that you have amassed so much in so little time.  I am sure once you get your list filled, you will tell us soon enough!
Amazing!
P.S.  Get BOTH if you can't decide.
Edit: I mean this.  You will get one and regret you didn't get the other.
« Last Edit: Tue, 16 June 2015, 01:04:10 by Snowdog993 »
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #13 on: Tue, 16 June 2015, 01:53:12 »
He only has 12.333 posts/day... :rolleyes:
  • Antiquarian
« Reply #14 on: Tue, 16 June 2015, 02:49:06 »
Amazing!
It's great to have some fellow enthusiastic noobs around here!   :p
« Reply #15 on: Tue, 16 June 2015, 05:57:36 »
I have an older KeyCool 87 which is whiter than white.
If this is the same white white, and not an off-white as so many are, I'd say go for white.
Offline Oobly
« Reply #16 on: Tue, 16 June 2015, 07:22:13 »
or more to the point higher force key switches (in the realm of the sweet spot identified by IBM long ago)
I also prefer tactile switches to linear switches...so the Cherry MX Blacks didnt make my favs list.  I probably prefer the Blues to the Blacks...but the Browns are pushing it.
So he buys a board with Blacks... ;)
The black keycaps look awesome with the backlight showing through and the white may show the finger grime really easily, but I do prefer the "cleanness" of white on white, I'd replace the keycaps almost immediately anyway and white cases are pretty rare, so I'd probably go for the white one.
TBH, I don't bother with commercial boards any more, considering I have to do so much modifying to the switches (trampolines, springs, etc) and boards (case, plate, etc) to make them acceptable anyway.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
