Author Topic: Need a recommendation for a new kb  (Read 1633 times)
Offline Roner
« on: Tue, 16 June 2015, 20:02:58 »
Currently I have a fmj2 on reds. I currently am looking for PCB mounted switches on MX greens and nonlit tkl. Any recommendations?
Offline EscapeVelocity
  • Antiquarian
Re: Need a recommendation for a new kb
« Reply #1 on: Tue, 16 June 2015, 20:19:09 »
There is a CM Storm Quick Fire Stealth TKL with Cherry MX Greens on Massdrop right now. Sounds right up your alley.
$85 https://www.massdrop.com/buy/cm-storm-quick-fire-stealth-cherry-mx-green?s=green
Offline user 18
« Reply #2 on: Tue, 16 June 2015, 20:35:05 »
I believe QF stealth is plate mount, not PCB.
That said, most keyboards in that size range are. Can't think of any off the top of my head that are PCB mount.
Avatar by ashdenej
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #3 on: Tue, 16 June 2015, 22:05:11 »
Is there a specific reason you want PCB mount?
I personally always liked the poker X because I enjoyed PCB mount clears and browns. Maybe that is why I love stock HHKB so much... softer landing.
Offline Roner
« Reply #4 on: Wed, 17 June 2015, 00:15:21 »
Yes i want a pcb mounted kb because im afraid i wont like greens even though i like blues and blacks
Offline Roner
« Reply #5 on: Wed, 17 June 2015, 01:39:37 »
Or well i guess i would just like a tkl pcb mounted nonbacklit keyboard.
