Author Topic: repair needed  (Read 1502 times)
Offline johnoh
repair needed
« on: Fri, 19 June 2015, 14:25:34 »
does anyone know if a person or place that can repair adesso-mck84 keyboards?  I'm in the san jose area but can ship if needed.  thanks
Offline Blaise170
  • ALPS キーボード
    • XYZ
Re: repair needed
« Reply #1 on: Fri, 19 June 2015, 15:30:47 »
What kind of repair?
Offline johnoh
Re: repair needed
« Reply #2 on: Sat, 20 June 2015, 10:10:52 »
"What kind of repair?"
Is there such a thing as a keyboard overhaul to make it good as new? I have three of these keyboards. One escape key needs to be re-soldered (I took apart the switch to see), and a couple keys on each keyboard work only 80% of the time so you have to strike them twice. I've taken them apart and de-oxit'ed them which seems to help, but then the key to the left of the one I just cleaned will stop working too. Once the keyboard has been in use for 10 minutes or so the letter keys are okay, but the space bar is intermittent (I have not tried to take it apart yet).
Offline Blaise170
  • ALPS キーボード
    • XYZ
Re: repair needed
« Reply #3 on: Sat, 20 June 2015, 10:40:59 »
It would probably be easy enough to fix. Maybe a couple of bad switches that need to be resoldered. A bunch of people here could do it for you if you're comfortable with that.
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
Re: repair needed
« Reply #4 on: Sat, 20 June 2015, 11:11:29 »
Yeah solder just needs to be reflowed. You could probably get a half-decent iron and do it yourself as well.
