Author Topic: Keyboard suggestion for my company  (Read 5485 times)
Offline Ngt
« on: Tue, 23 June 2015, 05:07:26 »
Hi guys!
I created a start-up back in March this year and I'm now looking for mech board for my 2 others colleagues.
One wants a board with MX Brown and the other one prefers MX Black. I'm looking for sturdy cases so most possibly aluminium/steel made. At first I was looking for boards with good quality stock key caps but as they are not touch typing they want to keep their AZERTY french layout. It is really hard to find these kind of board and I don't want to hunt through the classifieds or whatnot for months just to find one at an expensive price tag hence I'm lowering my key caps requirements. Here comes the ****ty thin ABS key caps!  :'(
I know that Photeqk (already contacted him) is selling some Raptor boards with doubleshot and AZERTY layout stock but the one who wants the MX Black feels that the board is too big for him. In terms of sturdy cases at a reasonable price (120-150€ max per board) I thought of Ducky as I had one before and it seems that they have aluminium/steel cases. Do you have other suggestions, dear GH friends? :-*
Re: Keyboard suggestion for my company
« Reply #1 on: Tue, 23 June 2015, 05:12:37 »
I'd suspect a metal (aluminium?) case would be the most difficult requirement to satisfy, so your best bet might be to start there, and find some keyboard internals that you can put into it.
Massdrop has a few aluminium keyboard drops going at the moment.
Offline Ngt
« Reply #2 on: Tue, 23 June 2015, 07:06:23 »
I don't have the time to build full custom for them and I doubt they'd want it anyway.
Aren't Ducky keyboards made of steel/aluminum? They feel sturdier than a QFR IIRC.
Offline azhdar
  • Praise the AZERTY god
« Reply #3 on: Tue, 23 June 2015, 08:22:52 »
There's that too: http://www.mechkeyboards.eu/#!product/prd1/1281765091/ducky-zero-azerty-brown-switch
But you get thin abs caps. For the one that want black, I could possibly swap the original browns with gater blacks ;)
Azerty Propagandiste
« Reply #4 on: Tue, 23 June 2015, 08:30:05 »
No they just have more substantial plastic cases. The only Ducky board with a metal case is the Ducky Mini.
Offline Ngt
« Reply #5 on: Tue, 23 June 2015, 08:49:41 »
Yeah this is my first mechanical board (pretty much as I had the Ducky Zero Shine Zone, the same but with LED). That's what I was considering at first but I thought that maybe there would be other choices that I didn't think of. Thanks anyway.
Fair enough, after some inspection on the Ducky of a friend you are definitely right. I guess my only last requirements is down as well now. But hasn't it a ALU/steel plate or something similar?
« Reply #6 on: Tue, 23 June 2015, 08:50:56 »
Should have a stainless steel plate, just like a QFR. Carter has told me the design trade off in a QFR was a super thick stainless steel plate but a less substantial case.
Offline Ngt
« Reply #7 on: Tue, 23 June 2015, 08:56:33 »
The only Ducky I found in MX Black in a french store was the Shine 4 which is too expensive (200€).
What do you guys think of the SteelSeries 6Gv2? Did you get to try it?
http://www.materiel.net/clavier/steelseries-steelkeys-6gv2-62638.html
Offline Ngt
« Reply #8 on: Tue, 23 June 2015, 08:57:41 »
Ok thank you.
« Last Edit: Tue, 23 June 2015, 09:01:37 by Ngt »
« Reply #9 on: Tue, 23 June 2015, 08:58:09 »
It's not bad but if your friends want to get into keycap swapping, the layout is a no-go. Otherwise it's not a bad board at all.
Offline azhdar
Offline Ngt
« Reply #11 on: Tue, 23 June 2015, 09:07:07 »
Hum I didn't know that it has a different layout. I don't know if they'll want to swap the key caps. In terms of build quality, would a G80-3000 be similar except the non regular layout?
http://www.keyboardco.com/keyboard/french-filco-majestouch-2-nkr-mechanical-keyboards.asp
http://www.keyboardco.com/keyboard/french-filco-majestouch-2-tenkeyless-nkr-mechanical-keyboards.asp
Maybe pricey with convert rate and shipping.
They would be a bit too pricey I think. I'll see with them what they think of it. Thanks again for the suggestions.
« Reply #12 on: Tue, 23 June 2015, 09:08:49 »
Look at the 6GV2 carefully. The enter is an L shape.
G80-3000 doesn't have a plate. I like Cherry boards but I like them better with a plate.
Offline Ngt
« Reply #13 on: Tue, 23 June 2015, 09:10:31 »
Do you mean no plate as PCB-mounted or as in an HHKB?
« Reply #14 on: Tue, 23 June 2015, 09:12:21 »
HHKB is the only board that does the mounting in that fashion AFAIK.
By no plate, I mean PCB mounted.
Offline azhdar
« Reply #15 on: Tue, 23 June 2015, 09:17:37 »
btw ngt the raptor is cherry style so pcb mounted too.
Offline Ngt
« Reply #16 on: Tue, 23 June 2015, 09:27:53 »
Ok I didn't know that the HHKB is the only one with that kind of plate.[size=78%]  [/size]
I didn't know either that cherry style is PCB mounted.
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #17 on: Tue, 23 June 2015, 09:37:47 »
I was going to suggest 1800s but they seem to be ruled out, but why is the board too large for him?
Offline Tyrosh22
« Reply #18 on: Tue, 23 June 2015, 10:00:41 »
Employer of the year confirmed! :)
Meow.
« Reply #19 on: Tue, 23 June 2015, 10:01:31 »
1800 for work is my preference. I'm using one now and it's amazing.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #20 on: Tue, 23 June 2015, 11:30:11 »
Yeah, I use one at home because of the convenience of them. I will soon be upgrading my Dolch with a leeku PCB, which will be pretty cool
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #21 on: Tue, 23 June 2015, 11:31:08 »
Offline Ngt
« Reply #22 on: Wed, 24 June 2015, 03:17:42 »
He doesn't have a big desk ATM so if he takes a larger board he won't have anymore spaces at all. Do they come with AZERTY ISO layout?
Thank you ;) they are not really my employees but my associates.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #23 on: Wed, 24 June 2015, 03:18:48 »
I think the raptor is azerty
Offline Ngt
« Reply #24 on: Wed, 24 June 2015, 03:19:47 »
Oh OK I didn't make the link between 1800 and the raptor. I thought it was another keyboard.
Offline azhdar
« Reply #25 on: Wed, 24 June 2015, 03:20:16 »
The one photekq is selling are Azerty.
Dude I bring mine to your place once :x
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #26 on: Wed, 24 June 2015, 07:44:01 »
Ever tried asking Imsto what a dyesub set would cost?
|||My other keyboards :
x
Offline Ngt
« Reply #27 on: Thu, 25 June 2015, 02:54:29 »
I know that the raptor are Azerty what I didn't know is that a raptor is a 1800. I thought they were 2 different boards. :)
Nope never thought of it. I don't think they want to have a custom keycaps set as it will be the property of the company if it buys it.
