Author Topic: Solder problems  (Read 2449 times)
Offline GoatMaster
  • Formerly Franatic89
Solder problems
« on: Tue, 07 July 2015, 04:23:22 »
Hey,
I have some problems with soldering. I have soldered ergo clears on my PokerX PCB, everything works fine expect the numer 1 key.
Here are some pics of the soldering.
On the top the circle of the left whole in the bottom is missing, so there is no contact anymore I guess.
What can I do now?
Thanks in advance.
Re: Solder problems
« Reply #1 on: Tue, 07 July 2015, 04:44:32 »
Do you have a small piece of wire to test with? If so plug it in to a computer and touch the top pin of Q or Esc to the bottom pin of 1 (in the first pic) - one of them should type a 1 (looks to be Esc, but that's a strange design...)  If it does you can solder the wire to the broken pin on 1 to bypass the broken trace.
If not a pic of a larger area of board may help see what's going on, but having a plate in the way is not going to be helpful!
« Last Edit: Tue, 07 July 2015, 04:57:46 by suicidal_orange »
Offline GoatMaster
Re: Solder problems
« Reply #2 on: Tue, 07 July 2015, 05:26:45 »
Sorry for the bad picture, and thanks for your answer I will try it when I am at home later. Can I use any cable for example a cable from a computer fan?
Re: Solder problems
« Reply #3 on: Tue, 07 July 2015, 05:30:59 »
You can use any wire as the current going through a keyboard is tiny, it just needs to be thin enough to fit in the case and have insulation so it doesn't short :)
Offline GoatMaster
Re: Solder problems
« Reply #4 on: Tue, 07 July 2015, 12:36:27 »
Finnaly finished with soldering. Everything is working now! Thank you very much for your help.
Now I am waiting for the Hyperfuse Set...
Re: Solder problems
« Reply #5 on: Tue, 07 July 2015, 21:17:24 »
Yay for happy endings! Thanks for showing us how you fixed it. I always get confused when trying to figure out where the jumper wire should go.
Offline absyrd
  • CPT HYPE PADAWAN
Re: Solder problems
« Reply #6 on: Tue, 07 July 2015, 21:19:26 »
suicidal_orange comes through yet again.
Nice fix.
Re: Solder problems
« Reply #7 on: Wed, 08 July 2015, 03:40:43 »
Glad to hear it's working and great pic - don't use a red wire to hide try and hide it, show your fix off with pride :thumb:
I'd love to see the other side of this board, the trace heads up and left but still connects down and right, as it should :confused:
